[petsc-users] MATIS and DMDA in petsc4py
Loic Gouarin
loic.gouarin at math.u-psud.fr
Mon Apr 23 06:25:11 CDT 2018
Thanks Lawrence for your reply.
Le 23/04/2018 à 12:36, Lawrence Mitchell a écrit :
>> On 23 Apr 2018, at 11:32, Loic Gouarin <loic.gouarin at math.u-psud.fr> wrote:
>> Hi,
>> I try to use MATIS from petsc4py but I am not able to use setValuesLocal (I have a segmentation fault). And I don't understand why.
>> Could you tell me if I did a mistake or if it's a bug ?
> This code works for me with:
> PETSc: 7bfdb6492ce
> petsc4py: 9137bf78e
> Perhaps you have a mismatching petsc4py/PETSc combo?
The problem probably comes from the conda package. I reinstalled a new
environment and tried again but I still have this issue.
Did you compile petsc and petsc4py ?
The versions that I use are those given on conda-forge : petsc-3.8.4 and
petsc4py-3.8.1.
I did the following thing
conda create -n petsc_tmp
source activate petsc_tmp
conda install petsc4py -c conda-forge
and execute my script.
Loic
> Lawrence
>> My example
>> from petsc4py import PETSc
>> import numpy as np
>> n = 10
>> da = PETSc.DMDA().create([n, n], dof=1, stencil_width=1)
>> da.setMatType(PETSc.Mat.Type.IS)
>> A = da.createMatrix()
>> #ltog = da.getLGMap()
>> #A.setLGMap(ltog, ltog)
>> elem = da.getElements()
>> melem = np.ones((4, 4))
>> for e in elem:
>> A.setValuesLocal(e, e, melem, PETSc.InsertMode.ADD_VALUES)
>> Thanks,
>> Loic
>> Tel: 01 69 15 60 14
>> http://www.math.u-psud.fr/~gouarin
>> https://github.com/gouarin
Tel: 01 69 15 60 14
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180423/e7dfd331/attachment.html>
