[petsc-users] Possible DIVERGED_BREAKDOWN reasons and ways to avoid it
Ali Berk Kahraman aliberkkahraman at yahoo.com
Mon Apr 23 02:39:31 CDT 2018
Dear All,
I am trying to solve a Poisson-Neumann Problem which does not have a
solution by itself on an irregular domain with finite differences. This
problem arises in the correction step of a veloicty
prediction-correction scheme of Navier-Stokes equation. It requires a
least squares solution, or a modified solution.
I have asked here before, and with substantial help of Dr. Smith I have
learned about KSPLSQR. It helped for some small-sized problems, but when
the problem size gets larger, for some reason it cannot converge to a
good spot.
I have been trying another method in the literature, with little success
again. The literature suggests that an augmented linear system which has
a solution should be solved. If the poisson neumann problem is Ax=b, the
augmented system is as follows,
|A   1|    |b|
|1   0|     |a|
where a is an arbitrary number.  This system has a solution since vector
1 is the right null space of A (or so I have read). However, when I try
to solve thiss system for larger system sizes than appr. 8000, it causes
a diverged breakdown error for BiCGS with jacobi preconditioning. Is
there any way to avoid a breakdown in BiCGS? Why might it happen?
Best Regards,
Ali Berk Kahraman
Bogazici Uni., Istanbul,Turkey
