[petsc-users] Scaling problem when cores > 600
TAY wee-beng zonexo at gmail.com
Sat Apr 21 10:34:22 CDT 2018
I have found some time to work on this scaling problem again. I am now
using:
mpirun ./a.out -log_view -poisson_pc_type gamg
-poisson_pc_gamg_agg_nsmooths 1
I have attached the log_view output for 288, 600, 960, 1440 procs for
comparison.
Please give some comments.
Thank you very much
Yours sincerely,
TAY Wee-Beng 郑伟明 (Zheng Weiming)
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 7/3/2018 11:58 PM, Smith, Barry F. wrote:
>     What are you using for Poisson log.
>     If it is a Poisson problem then almost for sure you should be using Hypre BoomerAMG?.
>     It sounds like your matrix does not change. You will need to discuss the scaling with the hypre people.
>     Barry
>> On Mar 7, 2018, at 5:38 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> On 7/3/2018 6:22 AM, Smith, Barry F. wrote:
>>>     The speed up for "Poisson log" is 1.6425364214878704 = 5.0848e+02/3.0957e+02
>>>      This is lower than I would expect for Hypre BoomerAMG?
>>>      Are you doing multiple solves with the same matrix with hypre or is each solve a new matrix? If each solve is a new matrix then you may be getting expected behavior since the multigrid AMG construction process does not scale as well as the application of AMG once it is constructed.
>>>      I am forwarding to the hypre team since this is their expertise not ours
>>>     Barry
>> Hi,
>> My LHS of the eqn does not change. Only the RHS changes at each time step. So should this be expected?
>> So maybe I should change to BoomerAMG and compare?
>> Will PETSc GAMG give better performance?
>> Also, I must add that I only partition in the x and y direction. Will this be a factor?
>> Thanks.
>>>> On Mar 5, 2018, at 11:19 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 5/3/2018 11:43 AM, Smith, Barry F. wrote:
>>>>> 360 process
>>>>> KSPSolve              99 1.0 2.6403e+02 1.0 6.67e+10 1.1 2.7e+05 9.9e+05 5.1e+02 15100 17 42 19  15100 17 42 19 87401
>>>>> 1920 processes
>>>>> KSPSolve              99 1.0 2.3184e+01 1.0 1.32e+10 1.2 1.5e+06 4.3e+05 5.1e+02  4100 17 42 19   4100 17 42 19 967717
>>>>> Ratio of number of processes 5.33 ratio of time for KSPSolve  11.388 so the time for the solve is scaling very well (extremely well actually). The problem is
>>>>> due to "other time" that is not in KSP solve. Note that the percentage of the total time in KSPSolve went from 15 percent of the runtime to 4 percent. This means something outside of KSPSolve is scaling very poorly. You will need to profile the rest of the code to determine where the time is being spent. PetscLogEventRegister()  and PetscLogEventBegin/End() will be needed in your code. Already with 360 processes the linear solver is only taking 15 percent of the time.
>>>>>    Barry
>>>> Hi,
>>>> I have attached the new logging results with the HYPRE Poisson eqn solver. However, due to some problems, I am now using Intel 2018. Should be quite similar to 2016 in terms of runtime. Using 360 processes can't work this time, and I'm not sure why though.
>>>>>> On Mar 4, 2018, at 9:23 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>> On 1/3/2018 12:14 PM, Smith, Barry F. wrote:
>>>>>>>> On Feb 28, 2018, at 8:01 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>>>> On 1/3/2018 12:10 AM, Matthew Knepley wrote:
>>>>>>>>> On Wed, Feb 28, 2018 at 10:45 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I have a CFD code which uses PETSc and HYPRE. I found that for a certain case with grid size of 192,570,048, I encounter scaling problem when my cores > 600. At 600 cores, the code took 10min for 100 time steps. At 960, 1440 and 2880 cores, it still takes around 10min. At 360 cores, it took 15min.
>>>>>>>>> So how can I find the bottleneck? Any recommended steps?
>>>>>>>>> For any performance question, we need to see the output of -log_view for all test cases.
>>>>>>>> Hi,
>>>>>>>> To be more specific, I use PETSc KSPBCGS and HYPRE geometric multigrid (entirely based on HYPRE, no PETSc) for the momentum and Poisson eqns in my code.
>>>>>>>> So can log_view be used in this case to give a meaningful? Since part of the code uses HYPRE?
>>>>>>>    Yes, just send the logs.
>>>>>> Hi,
>>>>>> I have attached the logs, with the number indicating the no. of cores used. Some of the new results are different from the previous runs, although I'm using the same cluster.
>>>>>> Thanks for the help.
>>>>>>>> I also program another subroutine in the past which uses PETSc to solve the Poisson eqn. It uses either HYPRE's boomeramg, KSPBCGS or KSPGMRES.
>>>>>>>> If I use boomeramg, can log_view be used in this case?
>>>>>>>> Or do I have to use KSPBCGS or KSPGMRES, which is directly from PETSc? However, I ran KSPGMRES yesterday with the Poisson eqn and my ans didn't converge.
>>>>>>>> Thanks.
>>>>>>>>>   I must also mention that I partition my grid only in the x and y direction. There is no partitioning in the z direction due to limited code development. I wonder if there is a strong effect in this case.
>>>>>>>>> Maybe. Usually what happens is you fill up memory with a z-column and cannot scale further.
>>>>>>>>>    Thanks,
>>>>>>>>>       Matt
>>>>>>>>> Thank you very much
>>>>>>>>> Yours sincerely,
>>>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <log960.txt><log600.txt><log360.txt><log1920.txt>
>>>> <log1920_2.txt><log600_2.txt><log960_2.txt><log1440_2.txt>
  0.000000000000000E+000  3.700000000000000E-002  0.000000000000000E+000
  0.000000000000000E+000  0.000000000000000E+000  0.000000000000000E+000
  0.000000000000000E+000  0.400000000000000                0     -400000
 AB,AA,BB,CC   -3.30400006193668        3.62600007723086
   3.22400005813688        3.22400005813688
 size_x,size_y,size_z 718x718x285
 total grid size =    146924340
 recommended cores (50k / core) =    2938.48680000000
 min_area,max_area,min_grid_area,ratio  9.229464518072358E-005
  0.108728370237650       4.000000000000000E-004   271.820925594124
 ratio bet max_area,min_grid_area not ideal
 max element length should be  2.828427124746190E-002
 body_cg_ini -2.750916668409921E-003  2.695116216584833E-004
   6.75873529067005
 Warning - length difference between element and cell
 max_element_length,min_element_length,min_delta
  0.558213960965656       4.851715434749100E-003  2.000000000000000E-002
 maximum ngh_surfaces and ngh_vertics are            4           3
 minimum ngh_surfaces and ngh_vertics are            1           1
 min IIB_cell_no           0
 max IIB_cell_no         435
 IIB_cell_no_sum       71637
 min equal_size        1560
 max equal_size        1820
 min I_cell_no           0
 max I_cell_no        2310
 I_cell_no_sum      264465
 size(IIB_cell_u),size(I_cell_u),size(IIB_equal_cell_u),size(I_equal_cell_u),siz
 e(IIB_global_cell_u),size(I_global_cell_u)
         435        2310         435        2310       71637      264465
 IIB_equal_cell_no_u1_max         435
 I_equal_cell_no_u1_max        2310
 IIB_I_cell_no_uvw_total1       71637           0           0      264465
           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur         435       17201
 local IIB_cells size exceed, to increase size
 size(I_cell_u),I_cell_no_max_cur        2310       84869
 local I_cells size exceed, to increase size
 IIB_cell_no_u1_max,I_cell_no_u1_max       25801      127303
 size(IIB_cell_u),IIB_cell_no_max_cur         435         845
 IIB_equal_cell_no_u1_max        1267
 size(I_cell_u),I_cell_no_max_cur        2310        5060
 I_equal_cell_no_u1_max        7590
 size(I_global_cell_u1),I_global_cell_no_u1_max_cur      264465      264586
 I global cells size exceed, to increase size
 IIB_global_cell_no_u1_max,I_global_cell_no_u1_max       71637      396879
 time,IIB_I_cell_no_uvw_total1           2       71589           0           0
      264586           0           0
 size(I_cell_u),I_cell_no_max_cur        7590        7728
 I_equal_cell_no_u1_max       11592
 time,IIB_I_cell_no_uvw_total1           3       71237           0           0
      264577           0           0
 time,IIB_I_cell_no_uvw_total1           4       70676           0           0
      264504           0           0
 time,IIB_I_cell_no_uvw_total1           5       70909           0           0
      264557           0           0
 escape_time reached, so abort
 Recommended no for final_IIB_equal_no1,final_IIB_no1,final_IIB_global_no1,final
 _I_equal_no1,final_I_no1,final_I_global_no1
        1583       32251       89546       14490      159128      496098
   6.75873529067005
       32251      159128        1583       14490       89546      496098
 IIB_I_cell_no_uvw_total1       71637       71704       71732      264465
      264616      264595
       1      0.00150000      0.00000000      0.00000000      0.00000000  0.00000000E+00  0.00000000E+00  0.00000000E+00
 cd_cl_cs_mom_implicit1
 -0.203649100207704       -3.78579022968484       -142.426095309958
   3.49125655195658       -18.5255013193465        194.110055674799
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a  named std0771 with 600 processors, by tsltaywb Sat Apr 21 00:23:03 2018
Using Petsc Release Version 3.9.0, Apr, 07, 2018
                         Max       Max/Min        Avg      Total
Time (sec):           1.293e+02      1.00002   1.293e+02
Objects:              8.450e+02      1.00118   8.440e+02
Flop:                 2.402e+10      1.16509   2.255e+10  1.353e+13
Flop/sec:            1.858e+08      1.16510   1.744e+08  1.046e+11
MPI Messages:         1.668e+05      3.35829   1.236e+05  7.419e+07
MPI Message Lengths:  1.466e+09      2.16566   1.103e+04  8.180e+11
MPI Reductions:       1.451e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.2932e+02 100.0%  1.3533e+13 100.0%  7.419e+07 100.0%  1.103e+04      100.0%  1.442e+03  99.4%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided          5 1.0 1.1753e-02 5.7 0.00e+00 0.0 2.9e+04 4.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF        67 1.0 1.6764e+00 4.1 0.00e+00 0.0 1.3e+05 1.4e+05 0.0e+00  1  0  0  2  0   1  0  0  2  0     0
VecDot                 8 1.0 1.9643e-01 3.4 1.24e+07 1.1 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1 35902
VecDotNorm2            4 1.0 1.4356e-0119.8 1.24e+07 1.1 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0 49124
VecMDot              100 1.0 3.0183e-01 2.7 6.25e+07 1.1 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  7   0  0  0  0  7 117627
VecTDot              248 1.0 1.0376e+00 2.0 1.28e+08 1.1 0.0e+00 0.0e+00 2.5e+02  1  1  0  0 17   1  1  0  0 17 70231
VecNorm              247 1.0 4.7946e+00 8.8 9.16e+07 1.1 0.0e+00 0.0e+00 2.5e+02  1  0  0  0 17   1  0  0  0 17 10858
VecScale             110 1.0 6.2954e-03 2.2 6.25e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 563963
VecCopy              672 1.0 2.3515e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              2431 1.0 1.4385e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              258 1.0 2.8743e-01 1.2 1.29e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 255784
VecAYPX             5280 1.0 1.2274e+00 2.0 4.28e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0 198344
VecAXPBYCZ          2588 1.0 7.0963e-01 1.5 7.58e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 606609
VecWAXPY               8 1.0 4.5665e-02 1.4 1.24e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 154437
VecMAXPY             110 1.0 9.0745e-02 1.2 7.38e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 462386
VecAssemblyBegin      34 1.0 2.7867e-01 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        34 1.0 6.3419e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      55 1.0 1.9400e-02 3.0 3.12e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 91507
VecScatterBegin     5448 1.0 1.1685e+00 2.6 0.00e+00 0.0 7.0e+07 1.1e+04 0.0e+00  1  0 94 94  0   1  0 94 94  0     0
VecScatterEnd       5448 1.0 1.1562e+01 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
VecSetRandom           5 1.0 7.0169e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         110 1.0 1.0416e-01 2.0 1.87e+07 1.1 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  8   0  0  0  0  8 102254
MatMult             4102 1.0 2.2797e+01 1.2 1.15e+10 1.2 6.2e+07 1.1e+04 0.0e+00 16 48 84 86  0  16 48 84 86  0 283196
MatMultAdd           645 1.0 2.0686e+00 1.9 5.99e+08 1.2 3.8e+06 3.7e+03 0.0e+00  1  2  5  2  0   1  2  5  2  0 163213
MatMultTranspose     645 1.0 2.3167e+00 2.2 5.99e+08 1.2 3.8e+06 3.7e+03 0.0e+00  1  2  5  2  0   1  2  5  2  0 145734
MatSolve             14111.8 9.9322e-01 1.2 6.80e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 388324
MatSOR              3925 1.0 2.3818e+01 1.4 8.20e+09 1.1 0.0e+00 0.0e+00 0.0e+00 17 34  0  0  0  17 34  0  0  0 194060
MatLUFactorSym         1 1.0 3.9697e-0457.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 5.6432e-01 1.4 2.52e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 252133
MatILUFactorSym        1 1.0 2.5929e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 6.1710e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              16 1.0 1.8764e-01 1.3 4.80e+07 1.2 7.8e+04 1.0e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 144625
MatResidual          645 1.0 3.9151e+00 1.5 1.69e+09 1.2 1.0e+07 1.0e+04 0.0e+00  2  7 14 13  0   2  7 14 13  0 243152
MatAssemblyBegin     102 1.0 1.4931e+00 2.5 0.00e+00 0.0 1.3e+05 1.4e+05 0.0e+00  1  0  0  2  0   1  0  0  2  0     0
MatAssemblyEnd       102 1.0 6.1704e+00 1.0 0.00e+00 0.0 6.2e+05 2.7e+03 2.2e+02  5  0  1  0 15   5  0  1  0 15     0
MatGetRow         852087 1.1 1.0557e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 2.0 3.6955e-0538.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        4 1.0 1.3800e+00 1.0 0.00e+00 0.0 1.3e+04 1.6e+02 6.4e+01  1  0  0  0  4   1  0  0  0  4     0
MatGetOrdering         2 2.0 1.5060e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 1.3929e-01 1.1 0.00e+00 0.0 2.6e+06 1.3e+03 1.0e+02  0  0  4  0  7   0  0  4  0  7     0
MatZeroEntries         5 1.0 8.9250e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 7.8287e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             5 1.0 2.4963e+00 1.0 1.31e+07 1.2 4.6e+05 5.3e+03 6.2e+01  2  0  1  0  4   2  0  1  0  4  2956
MatMatMultSym          5 1.0 2.3848e+00 1.0 0.00e+00 0.0 3.8e+05 4.3e+03 6.0e+01  2  0  1  0  4   2  0  1  0  4     0
MatMatMultNum          5 1.0 1.0086e-01 1.0 1.31e+07 1.2 7.8e+04 1.0e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 73170
MatPtAP                5 1.0 6.8432e+00 1.0 4.11e+08 1.5 8.6e+05 4.6e+04 7.7e+01  5  2  1  5  5   5  2  1  5  5 33013
MatPtAPSymbolic        5 1.0 1.8684e+00 1.0 0.00e+00 0.0 4.5e+05 4.6e+04 3.5e+01  1  0  1  3  2   1  0  1  3  2     0
MatPtAPNumeric         5 1.0 4.9728e+00 1.0 4.11e+08 1.5 4.1e+05 4.6e+04 4.0e+01  4  2  1  2  3   4  2  1  2  3 45430
MatTrnMatMult          1 1.0 9.3095e-01 1.0 2.61e+07 1.2 1.8e+04 1.7e+05 1.6e+01  1  0  0  0  1   1  0  0  0  1 15887
MatTrnMatMultSym       1 1.0 6.6997e-01 1.0 0.00e+00 0.0 1.6e+04 8.7e+04 1.6e+01  1  0  0  0  1   1  0  0  0  1     0
MatTrnMatMultNum       1 1.0 2.6105e-01 1.0 2.61e+07 1.2 2.3e+03 7.7e+05 0.0e+00  0  0  0  0  0   0  0  0  0  0 56658
MatGetLocalMat        17 1.0 7.8735e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         15 1.0 1.2452e-01 1.8 0.00e+00 0.0 5.5e+05 3.3e+04 0.0e+00  0  0  1  2  0   0  0  1  2  0     0
SFSetGraph             5 1.0 4.0531e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                5 1.0 1.6538e-02 1.9 0.00e+00 0.0 8.6e+04 4.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin         114 1.0 1.0221e-02 4.0 0.00e+00 0.0 2.5e+06 1.2e+03 0.0e+00  0  0  3  0  0   0  0  3  0  0     0
SFBcastEnd           114 1.0 3.8953e-02 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       100 1.0 3.6761e-01 2.0 1.25e+08 1.1 0.0e+00 0.0e+00 1.0e+02  0  1  0  0  7   0  1  0  0  7 193158
KSPSetUp              20 1.0 4.3537e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.8e+01  0  0  0  0  2   0  0  0  0  2     0
KSPSolve               9 1.0 6.5676e+01 1.0 2.40e+10 1.2 7.4e+07 1.1e+04 1.2e+03 51100100 96 83  51100100 96 83 205797
PCGAMGGraph_AGG        5 1.0 6.6401e-01 1.0 1.31e+07 1.2 1.9e+05 5.4e+03 6.0e+01  1  0  0  0  4   1  0  0  0  4 11114
PCGAMGCoarse_AGG       5 1.0 1.1636e+00 1.0 2.61e+07 1.2 2.7e+06 3.3e+03 1.2e+02  1  0  4  1  9   1  0  4  1  9 12711
PCGAMGProl_AGG         5 1.0 4.3104e-01 1.0 0.00e+00 0.0 1.7e+05 9.3e+03 8.0e+01  0  0  0  0  6   0  0  0  0  6     0
PCGAMGPOpt_AGG         5 1.0 3.0145e+00 1.0 2.28e+08 1.2 1.2e+06 8.4e+03 2.1e+02  2  1  2  1 14   2  1  2  1 14 42573
GAMG: createProl       5 1.0 5.2617e+00 1.0 2.67e+08 1.2 4.3e+06 5.1e+03 4.7e+02  4  1  6  3 32   4  1  6  3 33 28604
  Graph               10 1.0 6.5672e-01 1.0 1.31e+07 1.2 1.9e+05 5.4e+03 6.0e+01  1  0  0  0  4   1  0  0  0  4 11237
  MIS/Agg              5 1.0 1.3933e-01 1.1 0.00e+00 0.0 2.6e+06 1.3e+03 1.0e+02  0  0  4  0  7   0  0  4  0  7     0
  SA: col data         5 1.0 8.9589e-02 1.1 0.00e+00 0.0 1.1e+05 1.2e+04 2.0e+01  0  0  0  0  1   0  0  0  0  1     0
  SA: frmProl0         5 1.0 3.3868e-01 1.0 0.00e+00 0.0 5.2e+04 3.5e+03 4.0e+01  0  0  0  0  3   0  0  0  0  3     0
  SA: smooth           5 1.0 2.6009e+00 1.0 1.78e+07 1.2 4.6e+05 5.3e+03 7.2e+01  2  0  1  0  5   2  0  1  0  5  3844
GAMG: partLevel        5 1.0 8.3094e+00 1.0 4.11e+08 1.5 8.8e+05 4.5e+04 1.8e+02  6  2  1  5 12   6  2  1  5 12 27188
  repartition          3 1.0 2.4631e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 7.8353e-0291.3 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.1592e-02 1.2 0.00e+00 0.0 2.0e+03 8.5e+02 3.4e+01  0  0  0  0  2   0  0  0  0  2     0
  Move P               2 1.0 1.3714e+00 1.0 0.00e+00 0.0 1.1e+04 2.8e+01 3.4e+01  1  0  0  0  2   1  0  0  0  2     0
PCSetUp                4 1.0 1.4434e+01 1.0 9.30e+08 1.3 5.1e+06 1.2e+04 6.8e+02 11  4  7  7 47  11  4  7  7 47 35935
PCSetUpOnBlocks      133 1.0 8.3417e-01 1.3 2.52e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0 170569
PCApply              141 1.0 4.7204e+01 1.1 2.13e+10 1.2 6.9e+07 9.5e+03 1.0e+02 36 89 92 80  7  36 89 92 80  7 254450
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector   363            363    223074648     0.
              Matrix   150            150   1237480116     0.
      Matrix Coarsen     5              5         3180     0.
    Distributed Mesh    18             18        94176     0.
           Index Set   128            128     23259280     0.
   IS L to G Mapping    18             18     10397096     0.
   Star Forest Graph    41             41        35424     0.
     Discrete System    18             18        16632     0.
         Vec Scatter    58             58     17003440     0.
       Krylov Solver    20             20       314880     0.
      Preconditioner    15             15        15212     0.
         PetscRandom    10             10         6460     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 1.64032e-05
Average time for zero size MPI_Send(): 5.4582e-06
#PETSc Option Table entries:
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-mpi-dir=/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64 --with-blaslapack-dir=/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mkl/lib/intel64 --download-hypre=/home/users/nus/tsltaywb/scratch/source/v2.14.0.tar.gz --download-ml=/home/users/nus/tsltaywb/scratch/source/ml-v6.2-p4.tar.gz --with-debugging=0 --prefix=/home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel --with-shared-libraries=0 --known-mpi-shared-libraries=0 --with-fortran-interfaces=1 --CFLAGS="-xHost -g -O2" --CXXFLAGS="-xHost -g -O2" --FFLAGS="-xHost -g -O2"
Libraries compiled on 2018-04-17 05:50:35 on nus02
Machine characteristics: Linux-2.6.32-696.18.7.el6.x86_64-x86_64-with-redhat-6.9-Santiago
Using PETSc directory: /home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel
Using PETSc arch:
Using C compiler: /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpicc -xHost -g -O2
Using Fortran compiler: /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90 -xHost -g -O2
Using include paths: -I/home/users/nus/tsltaywb/lib//include -I/home/users/nus/tsltaywb/lib///include -I/home/users/nus/tsltaywb/lib//include -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
Using C linker: /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpicc
Using Fortran linker: /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
Using libraries: -Wl,-rpath,/home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel/lib -L/home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel/lib -lpetsc -Wl,-rpath,/home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel/lib -L/home/users/nus/tsltaywb/lib/petsc-3.9.0_intel_rel/lib -Wl,-rpath,/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mkl/lib/intel64 -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mkl/lib/intel64 -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/ippcp/lib/intel64 -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/ipp/lib/intel64 -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/compiler/lib/intel64_lin -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mkl/lib/intel64_lin -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/tbb/lib/intel64/gcc4.4 -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/daal/lib/intel64_lin -L/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -Wl,-rpath,/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/lib -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lHYPRE -lml -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lX11 -lstdc++ -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lgcc_s -lirc_s -lstdc++ -ldl
			Resource Usage on 2018-04-21 00:23:08.128316:
	JobId: 6808395.wlm01
	Project: 11000324
	Exit Status: 0
	NCPUs Requested: 600				NCPUs Used: 600
							CPU Time Used: 00:50:53
	Memory Requested: 2400gb 				Memory Used: 53653576kb
							Vmem Used: 75059520kb
	Walltime requested: 00:05:00 			Walltime Used: 00:02:25
	Execution Nodes Used: (std0771:ncpus=24:mem=100663296kb)+(std0772:ncpus=24:mem=100663296kb)+(std0866:ncpus=24:mem=100663296kb)+(std0867:ncpus=24:mem=100663296kb)+(std0871:ncpus=24:mem=100663296kb)+(std0872:ncpus=24:mem=100663296kb)+(std0901:ncpus=24:mem=100663296kb)+(std0902:ncpus=24:mem=100663296kb)+(std0903:ncpus=24:mem=100663296kb)+(std0904:ncpus=24:mem=100663296kb)+(std0905:ncpus=24:mem=100663296kb)+(std0906:ncpus=24:mem=100663296kb)+(std0907:ncpus=24:mem=100663296kb)+(std0908:ncpus=24:mem=100663296kb)+(std0909:ncpus=24:mem=100663296kb)+(std0910:ncpus=24:mem=100663296kb)+(std0911:ncpus=24:mem=100663296kb)+(std0912:ncpus=24:mem=100663296kb)+(std0913:ncpus=24:mem=100663296kb)+(std0914:ncpus=24:mem=100663296kb)+(std0915:ncpus=24:mem=100663296kb)+(std0916:ncpus=24:mem=100663296kb)+(std0917:ncpus=24:mem=100663296kb)+(std0918:ncpus=24:mem=100663296kb)+(std0919:ncpus=24:mem=100663296kb)
   6.75873529067005
 maximum ngh_surfaces and ngh_vertics are            4           4
 min IIB_cell_no           0
 max IIB_cell_no         592
 min equal_size        3600
 max equal_size        4096
 min I_cell_no           0
 max I_cell_no        4352
         592        4352         592        4352       71637      264465
 IIB_equal_cell_no_u1_max         592
 I_equal_cell_no_u1_max        4352
           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur         592       18100
 size(I_cell_u),I_cell_no_max_cur        4352       70137
 IIB_cell_no_u1_max,I_cell_no_u1_max       27150      105205
 size(IIB_cell_u),IIB_cell_no_max_cur         592        1296
 IIB_equal_cell_no_u1_max        1944
 size(I_cell_u),I_cell_no_max_cur        4352        9324
 I_equal_cell_no_u1_max       13986
      264586           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur        1944        2004
 IIB_equal_cell_no_u1_max        3006
 size(I_cell_u),I_cell_no_max_cur       13986       13992
 I_equal_cell_no_u1_max       20988
      264577           0           0
      264504           0           0
      264557           0           0
        3757       33937       89546       26235      131506      496098
   6.75873529067005
       33937      131506        3757       26235       89546      496098
      264616      264595
 -0.203707530878565       -3.78586926105787       -142.425572181451
   3.49109646861912       -18.5191982260976        194.106345316573
./a.out on a  named std0442 with 288 processors, by tsltaywb Fri Apr 20 22:40:33 2018
Time (sec):           2.523e+02      1.00002   2.523e+02
Flop:                 4.819e+10      1.10663   4.730e+10  1.362e+13
Flop/sec:            1.910e+08      1.10663   1.875e+08  5.400e+10
MPI Messages:         9.780e+04      3.18949   7.382e+04  2.126e+07
MPI Message Lengths:  1.951e+09      2.12277   2.441e+04  5.190e+11
MPI Reductions:       1.416e+03      1.00000
 0:      Main Stage: 2.5229e+02 100.0%  1.3623e+13 100.0%  2.126e+07 100.0%  2.441e+04      100.0%  1.407e+03  99.4%
Phase summary info:
BuildTwoSided          5 1.0 3.7102e-0213.7 0.00e+00 0.0 8.5e+03 4.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF        67 1.0 8.4729e+00 2.0 0.00e+00 0.0 4.9e+04 2.5e+05 0.0e+00  3  0  0  2  0   3  0  0  2  0     0
VecDot                 8 1.0 7.0657e-01 5.3 2.48e+07 1.1 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1  9981
VecDotNorm2            4 1.0 4.9834e-0155.8 2.48e+07 1.1 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0 14152
VecMDot              100 1.0 1.2717e+00 2.4 1.25e+08 1.1 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  7   0  0  0  0  7 27905
VecTDot              244 1.0 2.3305e+00 3.3 2.52e+08 1.1 0.0e+00 0.0e+00 2.4e+02  1  1  0  0 17   1  1  0  0 17 30766
VecNorm              245 1.0 4.0297e+0117.5 1.81e+08 1.1 0.0e+00 0.0e+00 2.4e+02  9  0  0  0 17   9  0  0  0 17  1277
VecScale             110 1.0 4.8598e-02 2.2 1.25e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 73019
VecCopy              662 1.0 7.8418e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              2395 1.0 6.5509e-01 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              254 1.0 1.0951e+00 2.1 2.55e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 66060
VecAYPX             5198 1.0 2.9301e+00 2.4 8.43e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0 81748
VecAXPBYCZ          2548 1.0 1.9207e+00 2.1 1.49e+09 1.1 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 220650
VecWAXPY               8 1.0 1.9802e-01 2.7 2.48e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 35614
VecMAXPY             110 1.0 2.6582e-01 1.6 1.48e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 157767
VecAssemblyBegin      34 1.0 4.0356e-01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        34 1.0 6.3658e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      55 1.0 4.0215e-02 1.7 6.24e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 44121
VecScatterBegin     5366 1.0 1.6781e+00 3.0 0.00e+00 0.0 2.0e+07 2.4e+04 0.0e+00  0  0 95 94  0   0  0 95 94  0     0
VecScatterEnd       5366 1.0 7.0576e+01 7.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 17  0  0  0  0  17  0  0  0  0     0
VecSetRandom           5 1.0 1.4006e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         110 1.0 1.1545e+00 4.5 3.75e+07 1.1 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  8   0  0  0  0  8  9221
MatMult             4040 1.0 8.7491e+01 1.8 2.25e+10 1.1 1.7e+07 2.6e+04 0.0e+00 25 46 81 86  0  25 46 81 86  0 72363
MatMultAdd           635 1.0 1.3872e+01 7.7 1.17e+09 1.1 1.4e+06 6.2e+03 0.0e+00  2  2  7  2  0   2  2  7  2  0 23814
MatMultTranspose     635 1.0 1.4661e+01 7.5 1.17e+09 1.1 1.4e+06 6.2e+03 0.0e+00  2  2  7  2  0   2  2  7  2  0 22532
MatSolve             13911.6 2.7498e+00 1.6 1.38e+09 1.1 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0 142785
MatSOR              3865 1.0 7.5148e+01 2.3 1.71e+10 1.1 0.0e+00 0.0e+00 0.0e+00 18 36  0  0  0  18 36  0  0  0 64645
MatLUFactorSym         1 1.0 5.1308e-0474.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.8094e+00 2.2 5.16e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0 80741
MatILUFactorSym        1 1.0 6.5920e+0014.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatConvert             5 1.0 4.5344e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              16 1.0 5.1112e-01 1.5 9.57e+07 1.1 2.2e+04 2.3e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 52984
MatResidual          635 1.0 1.6918e+01 3.2 3.31e+09 1.1 2.8e+06 2.3e+04 0.0e+00  4  7 13 12  0   4  7 13 12  0 55100
MatAssemblyBegin     102 1.0 8.2371e+00 1.8 0.00e+00 0.0 4.9e+04 2.5e+05 0.0e+00  3  0  0  2  0   3  0  0  2  0     0
MatAssemblyEnd       102 1.0 6.0627e+00 1.2 0.00e+00 0.0 2.4e+05 4.6e+03 2.2e+02  2  0  1  0 15   2  0  1  0 15     0
MatGetRow        1702611 1.1 1.6791e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 2.0 5.6982e-04597.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        4 1.0 3.1587e-01 1.0 0.00e+00 0.0 6.8e+03 3.7e+02 6.4e+01  0  0  0  0  5   0  0  0  0  5     0
MatGetOrdering         2 2.0 4.2314e-0117.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 1.6996e-01 1.2 0.00e+00 0.0 5.9e+05 3.1e+03 7.5e+01  0  0  3  0  5   0  0  3  0  5     0
MatZeroEntries         5 1.0 1.8760e-0112.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 2.1740e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             5 1.0 1.3280e+00 1.0 2.61e+07 1.1 1.4e+05 1.1e+04 6.2e+01  1  0  1  0  4   1  0  1  0  4  5527
MatMatMultSym          5 1.0 1.1175e+00 1.0 0.00e+00 0.0 1.2e+05 8.9e+03 6.0e+01  0  0  1  0  4   0  0  1  0  4     0
MatMatMultNum          5 1.0 2.0309e-01 1.1 2.61e+07 1.1 2.2e+04 2.3e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 36141
MatPtAP                5 1.0 1.2759e+01 1.0 8.09e+08 1.3 3.2e+05 7.9e+04 7.7e+01  5  2  1  5  5   5  2  1  5  5 17465
MatPtAPSymbolic        5 1.0 3.8273e+00 1.0 0.00e+00 0.0 1.4e+05 9.0e+04 3.5e+01  1  0  1  2  2   1  0  1  2  2     0
MatPtAPNumeric         5 1.0 9.0744e+00 1.0 8.09e+08 1.3 1.7e+05 7.0e+04 4.0e+01  4  2  1  2  3   4  2  1  2  3 24556
MatTrnMatMult          1 1.0 4.0050e+00 1.0 5.17e+07 1.1 8.5e+03 2.4e+05 1.6e+01  2  0  0  0  1   2  0  0  0  1  3656
MatTrnMatMultSym       1 1.0 2.7167e+00 1.0 0.00e+00 0.0 7.4e+03 1.2e+05 1.6e+01  1  0  0  0  1   1  0  0  0  1     0
MatTrnMatMultNum       1 1.0 1.2892e+00 1.0 5.17e+07 1.1 1.1e+03 1.1e+06 0.0e+00  1  0  0  0  0   1  0  0  0  0 11357
MatGetLocalMat        17 1.0 2.1107e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         15 1.0 2.0231e-01 2.1 0.00e+00 0.0 1.5e+05 7.5e+04 0.0e+00  0  0  1  2  0   0  0  1  2  0     0
SFSetGraph             5 1.0 5.2452e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                5 1.0 4.1750e-02 3.9 0.00e+00 0.0 2.5e+04 8.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          85 1.0 8.3704e-03 4.0 0.00e+00 0.0 5.6e+05 2.9e+03 0.0e+00  0  0  3  0  0   0  0  3  0  0     0
SFBcastEnd            85 1.0 2.3875e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       100 1.0 1.4133e+00 2.0 2.50e+08 1.1 0.0e+00 0.0e+00 1.0e+02  0  1  0  0  7   0  1  0  0  7 50219
KSPSetUp              20 1.0 2.1678e+00 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.8e+01  1  0  0  0  2   1  0  0  0  2     0
KSPSolve               9 1.0 1.8116e+02 1.0 4.81e+10 1.1 2.1e+07 2.4e+04 1.2e+03 72100100 96 82  72100100 96 83 75103
PCGAMGGraph_AGG        5 1.0 3.1132e+00 1.0 2.61e+07 1.1 5.4e+04 1.2e+04 6.0e+01  1  0  0  0  4   1  0  0  0  4  2358
PCGAMGCoarse_AGG       5 1.0 4.3671e+00 1.0 5.17e+07 1.1 6.1e+05 9.0e+03 9.5e+01  2  0  3  1  7   2  0  3  1  7  3352
PCGAMGProl_AGG         5 1.0 4.7506e-01 1.0 0.00e+00 0.0 5.5e+04 1.8e+04 8.0e+01  0  0  0  0  6   0  0  0  0  6     0
PCGAMGPOpt_AGG         5 1.0 2.6141e+00 1.0 4.53e+08 1.1 3.6e+05 1.9e+04 2.1e+02  1  1  2  1 15   1  1  2  1 15 48912
GAMG: createProl       5 1.0 1.0569e+01 1.0 5.31e+08 1.1 1.1e+06 1.3e+04 4.4e+02  4  1  5  3 31   4  1  5  3 31 14178
  Graph               10 1.0 3.1086e+00 1.0 2.61e+07 1.1 5.4e+04 1.2e+04 6.0e+01  1  0  0  0  4   1  0  0  0  4  2361
  MIS/Agg              5 1.0 1.7001e-01 1.2 0.00e+00 0.0 5.9e+05 3.1e+03 7.5e+01  0  0  3  0  5   0  0  3  0  5     0
  SA: col data         5 1.0 6.0319e-02 1.1 0.00e+00 0.0 3.4e+04 2.6e+04 2.0e+01  0  0  0  0  1   0  0  0  0  1     0
  SA: frmProl0         5 1.0 3.9480e-01 1.0 0.00e+00 0.0 2.1e+04 5.6e+03 4.0e+01  0  0  0  0  3   0  0  0  0  3     0
  SA: smooth           5 1.0 1.6144e+00 1.0 3.53e+07 1.1 1.4e+05 1.1e+04 7.2e+01  1  0  1  0  5   1  0  1  0  5  6158
GAMG: partLevel        5 1.0 1.3111e+01 1.0 8.09e+08 1.3 3.2e+05 7.7e+04 1.8e+02  5  2  2  5 13   5  2  2  5 13 16996
  repartition          2 1.0 1.3661e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 3.1821e-0235.4 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 8.8933e-03 1.1 0.00e+00 0.0 1.5e+03 1.5e+03 3.4e+01  0  0  0  0  2   0  0  0  0  2     0
  Move P               2 1.0 3.0897e-01 1.0 0.00e+00 0.0 5.3e+03 3.4e+01 3.4e+01  0  0  0  0  2   0  0  0  0  2     0
PCSetUp                4 1.0 3.1552e+01 1.2 1.86e+09 1.2 1.4e+06 2.8e+04 6.5e+02 11  4  7  7 46  11  4  7  7 46 16441
PCSetUpOnBlocks      131 1.0 7.7258e+00 5.2 5.16e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0 18910
PCApply              139 1.0 1.3946e+02 1.3 4.28e+10 1.1 2.0e+07 2.1e+04 1.0e+02 49 89 92 79  7  49 89 92 79  7 86847
              Vector   363            363    438680928     0.
              Matrix   150            150   2506664764     0.
           Index Set   128            128     44378656     0.
   IS L to G Mapping    18             18     19585328     0.
         Vec Scatter    58             58     33956736     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 0.
Average time for MPI_Barrier(): 1.54018e-05
Average time for zero size MPI_Send(): 5.56641e-06
-log_view
Using PETSc arch:
			Resource Usage on 2018-04-20 22:40:36.157718:
	JobId: 6800949.wlm01
	Project: 11000324
	Exit Status: 0
	NCPUs Requested: 288				NCPUs Used: 288
							CPU Time Used: 01:39:53
	Memory Requested: 1152gb 				Memory Used: 97346692kb
							Vmem Used: 117893608kb
	Walltime requested: 00:05:00 			Walltime Used: 00:04:26
	Execution Nodes Used: (std0442:ncpus=24:mem=100663296kb)+(std0116:ncpus=24:mem=100663296kb)+(std0162:ncpus=24:mem=100663296kb)+(std0207:ncpus=24:mem=100663296kb)+(std0215:ncpus=24:mem=100663296kb)+(std0218:ncpus=24:mem=100663296kb)+(std0227:ncpus=24:mem=100663296kb)+(std0254:ncpus=24:mem=100663296kb)+(std0256:ncpus=24:mem=100663296kb)+(std0303:ncpus=24:mem=100663296kb)+(std0313:ncpus=24:mem=100663296kb)+(std0363:ncpus=24:mem=100663296kb)
   6.75873529067005
 minimum ngh_surfaces and ngh_vertics are            1           3
 min IIB_cell_no           0
 max IIB_cell_no         227
 min equal_size         560
 max equal_size         792
 min I_cell_no           0
 max I_cell_no         960
         227         960         227         960       71637      264465
 IIB_equal_cell_no_u1_max         227
 I_equal_cell_no_u1_max         960
           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur         227        6585
 size(I_cell_u),I_cell_no_max_cur         960       36719
 IIB_cell_no_u1_max,I_cell_no_u1_max        9877       55078
 size(IIB_cell_u),IIB_cell_no_max_cur         227         385
 IIB_equal_cell_no_u1_max         577
 size(I_cell_u),I_cell_no_max_cur         960        2002
 I_equal_cell_no_u1_max        3003
      264586           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur         577         606
 IIB_equal_cell_no_u1_max         909
 size(I_cell_u),I_cell_no_max_cur        3003        3328
 I_equal_cell_no_u1_max        4992
      264577           0           0
      264504           0           0
      264557           0           0
        1136       12346       89546        6240       68847      496098
   6.75873529067005
       12346       68847        1136        6240       89546      496098
      264616      264595
 -0.203573203414587       -3.78836120073860       -142.428735523722
   3.49076187897078       -18.4949348357545        194.047090449719
./a.out on a  named std0930 with 1440 processors, by tsltaywb Sat Apr 21 20:13:18 2018
Time (sec):           1.077e+02      1.00011   1.077e+02
Objects:              8.780e+02      1.00114   8.770e+02
Flop:                 9.807e+09      1.27406   9.576e+09  1.379e+13
Flop/sec:            9.107e+07      1.27409   8.893e+07  1.281e+11
MPI Messages:         1.693e+05      8.99238   7.795e+04  1.122e+08
MPI Message Lengths:  1.007e+09      2.35317   1.203e+04  1.351e+12
MPI Reductions:       1.583e+03      1.00000
 0:      Main Stage: 1.0768e+02 100.0%  1.3789e+13 100.0%  1.122e+08 100.0%  1.203e+04      100.0%  1.574e+03  99.4%
Phase summary info:
BuildTwoSided          5 1.0 2.0495e-02 4.7 0.00e+00 0.0 4.0e+04 4.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF        69 1.0 1.4551e+00 2.8 0.00e+00 0.0 2.4e+05 1.3e+05 0.0e+00  1  0  0  2  0   1  0  0  2  0     0
VecDot                 8 1.0 2.0908e-0121.8 4.96e+06 1.2 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1 33730
VecDotNorm2            4 1.0 1.9284e-0193.1 4.96e+06 1.2 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0 36571
VecMDot              100 1.0 2.6590e-01 2.0 2.51e+07 1.2 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  6   0  0  0  0  6 133692
VecTDot              260 1.0 7.6737e-01 1.7 5.38e+07 1.2 0.0e+00 0.0e+00 2.6e+02  0  1  0  0 16   0  1  0  0 17 99561
VecNorm              253 1.0 3.7218e+00 3.7 3.79e+07 1.2 0.0e+00 0.0e+00 2.5e+02  2  0  0  0 16   2  0  0  0 16 14464
VecScale             110 1.0 2.4757e-03 2.5 2.51e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 1435901
VecCopy              702 1.0 7.9543e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              2542 1.0 5.8362e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              270 1.0 1.0637e-01 1.5 5.42e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 724347
VecAYPX             5526 1.0 3.6515e-01 2.1 1.80e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 698807
VecAXPBYCZ          2708 1.0 3.5396e-01 2.3 3.17e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 1272430
VecWAXPY               8 1.0 2.0493e-02 1.7 4.96e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 344131
VecMAXPY             110 1.0 4.1608e-02 1.9 2.96e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 1009728
VecAssemblyBegin      35 1.0 2.0360e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        35 1.0 6.2466e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      55 1.0 7.8759e-03 3.4 1.25e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 225683
VecScatterBegin     5695 1.0 9.3908e-01 3.8 0.00e+00 0.0 1.0e+08 1.2e+04 0.0e+00  1  0 93 94  0   1  0 93 94  0     0
VecScatterEnd       5695 1.0 8.3244e+00 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
VecSetRandom           5 1.0 2.8300e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         110 1.0 2.0694e-01 1.6 7.52e+06 1.2 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  7   0  0  0  0  7 51535
MatMult             4288 1.0 1.1565e+01 1.4 4.89e+09 1.4 8.9e+07 1.3e+04 0.0e+00  9 49 79 86  0   9 49 79 86  0 589627
MatMultAdd           675 1.0 2.5995e+00 5.2 2.54e+08 1.3 7.6e+06 3.1e+03 0.0e+00  2  3  7  2  0   2  3  7  2  0 137560
MatMultTranspose     675 1.0 1.8251e+00 4.0 2.54e+08 1.3 7.6e+06 3.1e+03 0.0e+00  1  3  7  2  0   1  3  7  2  0 195931
MatSolve             14712.2 7.5874e-01 2.6 2.64e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 494325
MatSOR              4105 1.0 9.8198e+00 2.0 3.15e+09 1.2 0.0e+00 0.0e+00 0.0e+00  8 32  0  0  0   8 32  0  0  0 452389
MatLUFactorSym         1 1.0 5.6100e-0481.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 4.5086e-01 3.0 9.66e+07 1.4 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 302823
MatILUFactorSym        1 1.0 3.1375e-01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 2.7598e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              16 1.0 7.8282e-02 1.7 1.93e+07 1.3 1.1e+05 1.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 348309
MatResidual          675 1.0 2.4201e+00 2.1 7.25e+08 1.4 1.4e+07 1.2e+04 0.0e+00  1  7 13 13  0   1  7 13 13  0 417100
MatAssemblyBegin     106 1.0 1.3056e+00 2.1 0.00e+00 0.0 2.4e+05 1.3e+05 0.0e+00  1  0  0  2  0   1  0  0  2  0     0
MatAssemblyEnd       106 1.0 7.0611e+00 1.0 0.00e+00 0.0 1.5e+06 1.8e+03 2.3e+02  7  0  1  0 15   7  0  1  0 15     0
MatGetRow         341706 1.2 3.7706e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 2.0 3.4308e-04359.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        6 1.0 2.0243e+00 1.0 0.00e+00 0.0 1.6e+05 1.1e+03 9.6e+01  2  0  0  0  6   2  0  0  0  6     0
MatGetOrdering         2 2.0 1.5898e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 1.1609e-01 1.1 0.00e+00 0.0 4.7e+06 1.8e+03 1.7e+02  0  0  4  1 11   0  0  4  1 11     0
MatZeroEntries         5 1.0 4.3550e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 5.6949e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             5 1.0 1.1438e+00 1.0 5.37e+06 1.4 6.8e+05 5.7e+03 6.2e+01  1  0  1  0  4   1  0  1  0  4  6537
MatMatMultSym          5 1.0 1.0687e+00 1.0 0.00e+00 0.0 5.7e+05 4.6e+03 6.0e+01  1  0  1  0  4   1  0  1  0  4     0
MatMatMultNum          5 1.0 6.2605e-02 1.1 5.37e+06 1.4 1.1e+05 1.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 119436
MatPtAP                5 1.0 5.8088e+00 1.0 1.73e+08 1.9 1.7e+06 3.8e+04 7.7e+01  5  2  2  5  5   5  2  2  5  5 40397
MatPtAPSymbolic        5 1.0 9.7437e-01 1.0 0.00e+00 0.0 7.0e+05 4.9e+04 3.5e+01  1  0  1  3  2   1  0  1  3  2     0
MatPtAPNumeric         5 1.0 4.8295e+00 1.0 1.73e+08 1.9 1.0e+06 3.0e+04 4.0e+01  4  2  1  2  3   4  2  1  2  3 48588
MatTrnMatMult          1 1.0 5.1030e-01 1.0 1.06e+07 1.3 4.4e+04 1.1e+05 1.6e+01  0  0  0  0  1   0  0  0  0  1 29433
MatTrnMatMultSym       1 1.0 3.3892e-01 1.0 0.00e+00 0.0 3.9e+04 5.5e+04 1.6e+01  0  0  0  0  1   0  0  0  0  1     0
MatTrnMatMultNum       1 1.0 1.7566e-01 1.0 1.06e+07 1.3 5.6e+03 4.8e+05 0.0e+00  0  0  0  0  0   0  0  0  0  0 85507
MatGetLocalMat        17 1.0 3.4708e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         15 1.0 9.4534e-02 2.1 0.00e+00 0.0 7.4e+05 4.1e+04 0.0e+00  0  0  1  2  0   0  0  1  2  0     0
SFSetGraph             5 1.0 5.0068e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                5 1.0 2.3274e-02 2.1 0.00e+00 0.0 1.2e+05 4.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin         177 1.0 9.6838e-03 4.3 0.00e+00 0.0 4.6e+06 1.7e+03 0.0e+00  0  0  4  1  0   0  0  4  1  0     0
SFBcastEnd           177 1.0 2.8875e-02 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       100 1.0 2.8578e-01 1.8 5.01e+07 1.2 0.0e+00 0.0e+00 1.0e+02  0  1  0  0  6   0  1  0  0  6 248784
KSPSetUp              20 1.0 4.2640e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.8e+01  0  0  0  0  2   0  0  0  0  2     0
KSPSolve               9 1.0 3.5276e+01 1.0 9.79e+09 1.3 1.1e+08 1.2e+04 1.3e+03 33100100 97 84  33100100 97 84 390407
PCGAMGGraph_AGG        5 1.0 3.0630e-01 1.0 5.37e+06 1.4 2.5e+05 6.3e+03 6.0e+01  0  0  0  0  4   0  0  0  0  4 24412
PCGAMGCoarse_AGG       5 1.0 6.6444e-01 1.0 1.06e+07 1.3 4.8e+06 3.5e+03 1.9e+02  1  0  4  1 12   1  0  4  1 12 22605
PCGAMGProl_AGG         5 1.0 1.0120e-01 1.0 0.00e+00 0.0 2.7e+05 9.1e+03 8.0e+01  0  0  0  0  5   0  0  0  0  5     0
PCGAMGPOpt_AGG         5 1.0 1.4647e+00 1.0 9.23e+07 1.3 1.7e+06 9.5e+03 2.1e+02  1  1  2  1 13   1  1  2  1 13 88410
GAMG: createProl       5 1.0 2.5337e+00 1.0 1.08e+08 1.3 7.1e+06 5.3e+03 5.3e+02  2  1  6  3 34   2  1  6  3 34 59989
  Graph               10 1.0 3.0478e-01 1.0 5.37e+06 1.4 2.5e+05 6.3e+03 6.0e+01  0  0  0  0  4   0  0  0  0  4 24533
  MIS/Agg              5 1.0 1.1613e-01 1.1 0.00e+00 0.0 4.7e+06 1.8e+03 1.7e+02  0  0  4  1 11   0  0  4  1 11     0
  SA: col data         5 1.0 1.8581e-02 1.1 0.00e+00 0.0 1.6e+05 1.3e+04 2.0e+01  0  0  0  0  1   0  0  0  0  1     0
  SA: frmProl0         5 1.0 7.7043e-02 1.0 0.00e+00 0.0 1.1e+05 2.5e+03 4.0e+01  0  0  0  0  3   0  0  0  0  3     0
  SA: smooth           5 1.0 1.2110e+00 1.0 7.25e+06 1.4 6.8e+05 5.7e+03 7.2e+01  1  0  1  0  5   1  0  1  0  5  8362
GAMG: partLevel        5 1.0 8.0089e+00 1.0 1.73e+08 1.9 1.9e+06 3.5e+04 2.3e+02  7  2  2  5 15   7  2  2  5 15 29299
  repartition          3 1.0 5.4121e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          3 1.0 1.5763e-0122.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Move A               3 1.0 8.4985e-01 1.0 0.00e+00 0.0 9.2e+04 1.8e+03 5.1e+01  1  0  0  0  3   1  0  0  0  3     0
  Move P               3 1.0 1.1894e+00 1.0 0.00e+00 0.0 6.4e+04 6.2e+01 5.1e+01  1  0  0  0  3   1  0  0  0  3     0
PCSetUp                4 1.0 1.1349e+01 1.0 3.78e+08 1.5 9.0e+06 1.1e+04 7.9e+02 10  4  8  8 50  10  4  8  8 50 46098
PCSetUpOnBlocks      139 1.0 7.7229e-01 3.2 9.66e+07 1.4 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 176788
PCApply              147 1.0 2.1472e+01 1.1 8.70e+09 1.3 1.0e+08 1.1e+04 1.0e+02 19 89 91 80  7  19 89 91 80  7 569588
              Vector   369            369     92175624     0.
              Matrix   158            158    487572844     0.
           Index Set   144            144     10541668     0.
   IS L to G Mapping    18             18      4620592     0.
         Vec Scatter    61             61      6861288     0.
              Viewer     1              0            0     0.
Average time for MPI_Barrier(): 0.000318766
Average time for zero size MPI_Send(): 8.26998e-06
-log_view
Using PETSc arch:
			Resource Usage on 2018-04-21 20:13:23.909068:
	JobId: 6809210.wlm01
	Project: 11000324
	Exit Status: 0
	NCPUs Requested: 1440				NCPUs Used: 1440
							CPU Time Used: 00:42:12
	Memory Requested: 5760gb 				Memory Used: 29886936kb
							Vmem Used: 53296508kb
	Walltime requested: 00:05:00 			Walltime Used: 00:02:04
	Execution Nodes Used: (std0930:ncpus=24:mem=100663296kb)+(std0931:ncpus=24:mem=100663296kb)+(std0932:ncpus=24:mem=100663296kb)+(std0933:ncpus=24:mem=100663296kb)+(std0934:ncpus=24:mem=100663296kb)+(std0935:ncpus=24:mem=100663296kb)+(std0936:ncpus=24:mem=100663296kb)+(std0937:ncpus=24:mem=100663296kb)+(std0938:ncpus=24:mem=100663296kb)+(std0939:ncpus=24:mem=100663296kb)+(std0940:ncpus=24:mem=100663296kb)+(std0941:ncpus=24:mem=100663296kb)+(std0942:ncpus=24:mem=100663296kb)+(std0953:ncpus=24:mem=100663296kb)+(std0954:ncpus=24:mem=100663296kb)+(std0955:ncpus=24:mem=100663296kb)+(std0956:ncpus=24:mem=100663296kb)+(std0957:ncpus=24:mem=100663296kb)+(std0958:ncpus=24:mem=100663296kb)+(std0959:ncpus=24:mem=100663296kb)+(std0960:ncpus=24:mem=100663296kb)+(std0961:ncpus=24:mem=100663296kb)+(std0962:ncpus=24:mem=100663296kb)+(std0963:ncpus=24:mem=100663296kb)+(std1101:ncpus=24:mem=100663296kb)+(std1103:ncpus=24:mem=100663296kb)+(std1105:ncpus=24:mem=100663296kb)+(std1108:ncpus=24:mem=100663296kb)+(std1109:ncpus=24:mem=100663296kb)+(std1111:ncpus=24:mem=100663296kb)+(std1113:ncpus=24:mem=100663296kb)+(std1114:ncpus=24:mem=100663296kb)+(std1116:ncpus=24:mem=100663296kb)+(std1118:ncpus=24:mem=100663296kb)+(std1120:ncpus=24:mem=100663296kb)+(std1121:ncpus=24:mem=100663296kb)+(std1127:ncpus=24:mem=100663296kb)+(std1129:ncpus=24:mem=100663296kb)+(std1131:ncpus=24:mem=100663296kb)+(std1136:ncpus=24:mem=100663296kb)+(std1138:ncpus=24:mem=100663296kb)+(std1139:ncpus=24:mem=100663296kb)+(std1140:ncpus=24:mem=100663296kb)+(std1141:ncpus=24:mem=100663296kb)+(std1154:ncpus=24:mem=100663296kb)+(std1247:ncpus=24:mem=100663296kb)+(std1248:ncpus=24:mem=100663296kb)+(std1250:ncpus=24:mem=100663296kb)+(std1251:ncpus=24:mem=100663296kb)+(std1253:ncpus=24:mem=100663296kb)+(std1255:ncpus=24:mem=100663296kb)+(std1256:ncpus=24:mem=100663296kb)+(std1262:ncpus=24:mem=100663296kb)+(std1263:ncpus=24:mem=100663296kb)+(std1264:ncpus=24:mem=100663296kb)+(std1265:ncpus=24:mem=100663296kb)+(std1268:ncpus=24:mem=100663296kb)+(std1269:ncpus=24:mem=100663296kb)+(std1466:ncpus=24:mem=100663296kb)+(std0630:ncpus=24:mem=100663296kb)
   6.75873529067005
 min IIB_cell_no           0
 max IIB_cell_no         324
 min equal_size         910
 max equal_size        1232
 min I_cell_no           0
 max I_cell_no        1440
         324        1440         324        1440       71637      264465
 IIB_equal_cell_no_u1_max         324
 I_equal_cell_no_u1_max        1440
           0           0
 size(IIB_cell_u),IIB_cell_no_max_cur         324       11334
 size(I_cell_u),I_cell_no_max_cur        1440       62615
 IIB_cell_no_u1_max,I_cell_no_u1_max       17001       93922
 size(IIB_cell_u),IIB_cell_no_max_cur         324         577
 IIB_equal_cell_no_u1_max         865
 size(I_cell_u),I_cell_no_max_cur        1440        3168
 I_equal_cell_no_u1_max        4752
      264586           0           0
 size(I_cell_u),I_cell_no_max_cur        4752        4896
 I_equal_cell_no_u1_max        7344
      264577           0           0
      264504           0           0
      264557           0           0
        1081       21251       89546        9180      117402      496098
   6.75873529067005
       21251      117402        1081        9180       89546      496098
      264616      264595
 -0.203534875831958       -3.78723081611176       -142.427697164364
   3.49017516030323       -18.5098557775327        194.067816292935
./a.out on a  named std0864 with 960 processors, by tsltaywb Sat Apr 21 01:26:50 2018
Time (sec):           1.168e+02      1.00008   1.168e+02
Flop:                 1.506e+10      1.20490   1.414e+10  1.358e+13
Flop/sec:            1.289e+08      1.20492   1.211e+08  1.162e+11
MPI Messages:         1.469e+05      9.74171   7.679e+04  7.372e+07
MPI Message Lengths:  1.183e+09      2.27657   1.417e+04  1.044e+12
MPI Reductions:       1.547e+03      1.00000
 0:      Main Stage: 1.1681e+02 100.0%  1.3576e+13 100.0%  7.372e+07 100.0%  1.417e+04      100.0%  1.538e+03  99.4%
Phase summary info:
BuildTwoSided          5 1.0 1.2648e-02 7.1 0.00e+00 0.0 3.0e+04 4.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF        69 1.0 1.2455e+00 4.1 0.00e+00 0.0 1.5e+05 1.6e+05 0.0e+00  0  0  0  2  0   0  0  0  2  0     0
VecDot                 8 1.0 1.1479e-01 9.0 7.75e+06 1.1 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1 61436
VecDotNorm2            4 1.0 1.0597e-0111.8 7.75e+06 1.1 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0 66552
VecMDot              100 1.0 2.2530e-01 3.0 3.91e+07 1.1 0.0e+00 0.0e+00 1.0e+02  0  0  0  0  6   0  0  0  0  7 157690
VecTDot              252 1.0 9.9791e-01 1.7 8.14e+07 1.1 0.0e+00 0.0e+00 2.5e+02  1  1  0  0 16   1  1  0  0 16 74204
VecNorm              249 1.0 3.8511e+00 4.9 5.79e+07 1.1 0.0e+00 0.0e+00 2.5e+02  2  0  0  0 16   2  0  0  0 16 13672
VecScale             110 1.0 2.6612e-03 1.8 3.91e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 1334996
VecCopy              682 1.0 1.4146e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              2470 1.0 7.4235e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              262 1.0 1.7395e-01 1.2 8.21e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 429416
VecAYPX             5362 1.0 6.6165e-01 2.3 2.72e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0 373910
VecAXPBYCZ          2628 1.0 3.9758e-01 1.5 4.81e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 1099671
VecWAXPY               8 1.0 3.3081e-02 1.7 7.75e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 213183
VecMAXPY             110 1.0 5.6687e-02 1.3 4.62e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 740673
VecAssemblyBegin      35 1.0 1.7896e-01 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        35 1.0 6.3896e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      55 1.0 1.2317e-02 3.1 1.95e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 144216
VecScatterBegin     5531 1.0 1.0172e+00 2.6 0.00e+00 0.0 6.9e+07 1.4e+04 0.0e+00  1  0 93 94  0   1  0 93 94  0     0
VecScatterEnd       5531 1.0 9.3496e+00 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
VecSetRandom           5 1.0 4.4341e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         110 1.0 7.5254e-02 1.7 1.17e+07 1.1 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  7   0  0  0  0  7 141630
MatMult             4164 1.0 1.5945e+01 1.4 7.33e+09 1.3 5.9e+07 1.5e+04 0.0e+00 12 49 80 86  0  12 49 80 86  0 413057
MatMultAdd           655 1.0 3.4669e+00 5.3 3.82e+08 1.2 4.8e+06 3.8e+03 0.0e+00  2  3  6  2  0   2  3  6  2  0 99404
MatMultTranspose     655 1.0 1.7476e+00 3.1 3.82e+08 1.2 4.8e+06 3.8e+03 0.0e+00  1  3  6  2  0   1  3  6  2  0 197203
MatSolve             14311.9 6.1919e-01 1.3 4.20e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 615183
MatSOR              3985 1.0 1.3915e+01 1.5 5.00e+09 1.2 0.0e+00 0.0e+00 0.0e+00 11 33  0  0  0  11 33  0  0  0 324223
MatLUFactorSym         1 1.0 4.4298e-0464.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 3.3439e-01 1.4 1.55e+08 1.3 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 417768
MatILUFactorSym        1 1.0 1.6124e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 3.8676e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              16 1.0 1.1365e-01 1.3 3.01e+07 1.2 7.2e+04 1.4e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 239293
MatResidual          655 1.0 2.7324e+00 1.8 1.08e+09 1.3 9.5e+06 1.4e+04 0.0e+00  2  7 13 13  0   2  7 13 13  0 355949
MatAssemblyBegin     106 1.0 1.1344e+00 2.3 0.00e+00 0.0 1.5e+05 1.6e+05 0.0e+00  1  0  0  2  0   1  0  0  2  0     0
MatAssemblyEnd       106 1.0 5.9141e+00 1.0 0.00e+00 0.0 9.2e+05 2.3e+03 2.3e+02  5  0  1  0 15   5  0  1  0 15     0
MatGetRow         533004 1.1 5.9415e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMat        6 1.0 1.6832e+00 1.0 0.00e+00 0.0 1.3e+05 1.2e+03 9.6e+01  1  0  0  0  6   1  0  0  0  6     0
MatGetOrdering         2 2.0 9.6362e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             5 1.0 9.3870e-02 1.1 0.00e+00 0.0 3.1e+06 1.8e+03 1.4e+02  0  0  4  1  9   0  0  4  1  9     0
MatZeroEntries         5 1.0 5.8362e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 7.1930e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             5 1.0 1.8777e+00 1.0 8.28e+06 1.3 4.5e+05 6.8e+03 6.2e+01  2  0  1  0  4   2  0  1  0  4  3954
MatMatMultSym          5 1.0 1.8023e+00 1.0 0.00e+00 0.0 3.8e+05 5.5e+03 6.0e+01  2  0  1  0  4   2  0  1  0  4     0
MatMatMultNum          5 1.0 6.5588e-02 1.0 8.28e+06 1.3 7.2e+04 1.4e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0 113198
MatPtAP                5 1.0 5.6372e+00 1.0 2.61e+08 1.6 1.0e+06 4.9e+04 7.7e+01  5  2  1  5  5   5  2  1  5  5 40626
MatPtAPSymbolic        5 1.0 1.2509e+00 1.0 0.00e+00 0.0 4.6e+05 5.7e+04 3.5e+01  1  0  1  3  2   1  0  1  3  2     0
MatPtAPNumeric         5 1.0 4.3676e+00 1.0 2.61e+08 1.6 5.7e+05 4.2e+04 4.0e+01  4  2  1  2  3   4  2  1  2  3 52436
MatTrnMatMult          1 1.0 6.8610e-01 1.0 1.64e+07 1.2 2.9e+04 1.3e+05 1.6e+01  1  0  0  0  1   1  0  0  0  1 21707
MatTrnMatMultSym       1 1.0 5.0253e-01 1.0 0.00e+00 0.0 2.6e+04 6.7e+04 1.6e+01  0  0  0  0  1   0  0  0  0  1     0
MatTrnMatMultNum       1 1.0 1.8408e-01 1.0 1.64e+07 1.2 3.7e+03 5.9e+05 0.0e+00  0  0  0  0  0   0  0  0  0  0 80908
MatGetLocalMat        17 1.0 4.8088e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         15 1.0 1.0984e-01 2.0 0.00e+00 0.0 5.1e+05 4.6e+04 0.0e+00  0  0  1  2  0   0  0  1  2  0     0
SFSetGraph             5 1.0 4.5300e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                5 1.0 1.6025e-02 2.4 0.00e+00 0.0 9.1e+04 4.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin         153 1.0 9.5887e-03 3.8 0.00e+00 0.0 3.0e+06 1.7e+03 0.0e+00  0  0  4  0  0   0  0  4  0  0     0
SFBcastEnd           153 1.0 1.4909e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       100 1.0 2.6370e-01 2.2 7.82e+07 1.1 0.0e+00 0.0e+00 1.0e+02  0  1  0  0  6   0  1  0  0  7 269452
KSPSetUp              20 1.0 2.7623e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.8e+01  0  0  0  0  2   0  0  0  0  2     0
KSPSolve               9 1.0 4.4800e+01 1.0 1.50e+10 1.2 7.3e+07 1.4e+04 1.3e+03 38100100 96 84  38100100 96 84 302653
PCGAMGGraph_AGG        5 1.0 3.6210e-01 1.0 8.28e+06 1.3 1.9e+05 6.8e+03 6.0e+01  0  0  0  0  4   0  0  0  0  4 20504
PCGAMGCoarse_AGG       5 1.0 8.4045e-01 1.0 1.64e+07 1.2 3.1e+06 4.0e+03 1.6e+02  1  0  4  1 11   1  0  4  1 11 17721
PCGAMGProl_AGG         5 1.0 1.0871e-01 1.0 0.00e+00 0.0 1.9e+05 9.9e+03 8.0e+01  0  0  0  0  5   0  0  0  0  5     0
PCGAMGPOpt_AGG         5 1.0 2.2764e+00 1.0 1.43e+08 1.2 1.2e+06 1.1e+04 2.1e+02  2  1  2  1 13   2  1  2  1 13 56612
GAMG: createProl       5 1.0 3.5835e+00 1.0 1.68e+08 1.2 4.7e+06 6.1e+03 5.1e+02  3  1  6  3 33   3  1  6  3 33 42190
  Graph               10 1.0 3.5973e-01 1.0 8.28e+06 1.3 1.9e+05 6.8e+03 6.0e+01  0  0  0  0  4   0  0  0  0  4 20639
  MIS/Agg              5 1.0 9.3908e-02 1.1 0.00e+00 0.0 3.1e+06 1.8e+03 1.4e+02  0  0  4  1  9   0  0  4  1  9     0
  SA: col data         5 1.0 1.9782e-02 1.1 0.00e+00 0.0 1.2e+05 1.4e+04 2.0e+01  0  0  0  0  1   0  0  0  0  1     0
  SA: frmProl0         5 1.0 8.2424e-02 1.0 0.00e+00 0.0 7.3e+04 3.0e+03 4.0e+01  0  0  0  0  3   0  0  0  0  3     0
  SA: smooth           5 1.0 1.9676e+00 1.0 1.12e+07 1.3 4.5e+05 6.8e+03 7.2e+01  2  0  1  0  5   2  0  1  0  5  5110
GAMG: partLevel        5 1.0 7.4519e+00 1.0 2.61e+08 1.6 1.2e+06 4.4e+04 2.3e+02  6  2  2  5 15   6  2  2  5 15 30733
  repartition          3 1.0 3.1521e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          3 1.0 1.2159e-0116.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Move A               3 1.0 6.3250e-01 1.0 0.00e+00 0.0 8.8e+04 1.8e+03 5.1e+01  1  0  0  0  3   1  0  0  0  3     0
  Move P               3 1.0 1.0553e+00 1.0 0.00e+00 0.0 4.4e+04 6.4e+01 5.1e+01  1  0  0  0  3   1  0  0  0  3     0
PCSetUp                4 1.0 1.1538e+01 1.0 5.84e+08 1.4 5.8e+06 1.4e+04 7.7e+02 10  4  8  8 50  10  4  8  8 50 45060
PCSetUpOnBlocks      135 1.0 4.9708e-01 1.3 1.55e+08 1.3 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 281031
PCApply              143 1.0 3.0010e+01 1.1 1.34e+10 1.2 6.7e+07 1.2e+04 1.0e+02 25 89 91 80  7  25 89 91 80  7 401277
              Vector   369            369    141361368     0.
              Matrix   158            158    768281328     0.
           Index Set   144            144     15496224     0.
   IS L to G Mapping    18             18      6803624     0.
         Vec Scatter    61             61     10664952     0.
              Viewer     1              0            0     0.
Average time for MPI_Barrier(): 1.81675e-05
Average time for zero size MPI_Send(): 4.80612e-06
-log_view
Using PETSc arch:
			Resource Usage on 2018-04-21 01:26:55.164851:
	JobId: 6808435.wlm01
	Project: 11000324
	Exit Status: 0
	NCPUs Requested: 960				NCPUs Used: 960
							CPU Time Used: 00:45:58
	Memory Requested: 3840gb 				Memory Used: 38583332kb
							Vmem Used: 60953164kb
	Walltime requested: 00:05:00 			Walltime Used: 00:02:12
	Execution Nodes Used: (std0864:ncpus=24:mem=100663296kb)+(std1142:ncpus=24:mem=100663296kb)+(std1143:ncpus=24:mem=100663296kb)+(std1144:ncpus=24:mem=100663296kb)+(std1146:ncpus=24:mem=100663296kb)+(std1147:ncpus=24:mem=100663296kb)+(std1150:ncpus=24:mem=100663296kb)+(std1151:ncpus=24:mem=100663296kb)+(std1152:ncpus=24:mem=100663296kb)+(std1153:ncpus=24:mem=100663296kb)+(std1204:ncpus=24:mem=100663296kb)+(std1206:ncpus=24:mem=100663296kb)+(std1207:ncpus=24:mem=100663296kb)+(std1211:ncpus=24:mem=100663296kb)+(std1213:ncpus=24:mem=100663296kb)+(std1214:ncpus=24:mem=100663296kb)+(std1216:ncpus=24:mem=100663296kb)+(std1217:ncpus=24:mem=100663296kb)+(std1218:ncpus=24:mem=100663296kb)+(std1220:ncpus=24:mem=100663296kb)+(std1222:ncpus=24:mem=100663296kb)+(std1225:ncpus=24:mem=100663296kb)+(std1226:ncpus=24:mem=100663296kb)+(std1227:ncpus=24:mem=100663296kb)+(std1228:ncpus=24:mem=100663296kb)+(std1229:ncpus=24:mem=100663296kb)+(std1230:ncpus=24:mem=100663296kb)+(std1231:ncpus=24:mem=100663296kb)+(std1232:ncpus=24:mem=100663296kb)+(std1233:ncpus=24:mem=100663296kb)+(std1234:ncpus=24:mem=100663296kb)+(std1235:ncpus=24:mem=100663296kb)+(std1236:ncpus=24:mem=100663296kb)+(std1237:ncpus=24:mem=100663296kb)+(std1238:ncpus=24:mem=100663296kb)+(std1270:ncpus=24:mem=100663296kb)+(std1271:ncpus=24:mem=100663296kb)+(std1272:ncpus=24:mem=100663296kb)+(std1319:ncpus=24:mem=100663296kb)+(std1320:ncpus=24:mem=100663296kb)
