[petsc-users] Reuse KSP
Young, Matthew, Adam may at bu.edu
Tue Apr 17 16:25:22 CDT 2018
That all makes sense. Thanks.
Is it okay to MatCreate() and MatDestroy() in each time step or am I just defeating the purpose of preserving the KSP?
Is there a way to tell if the KSP is reusing the factorization (e.g., with -ksp_view)?
Sent: Tuesday, April 17, 2018 5:13:10 PM
To: Young, Matthew, Adam
Cc: Matthew Knepley; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Reuse KSP
   If the matrix has a null space then, in general, direct LU factorizations should fail. If they don't fail they can produce an incorrect answer
   If your matrix has a null space then you should not remove the  [Set nullspace of A with MatSetNullSpace]
   Barry
> On Apr 17, 2018, at 7:48 AM, Young, Matthew, Adam <may at bu.edu> wrote:
> From: Matthew Knepley <knepley at gmail.com>
> Sent: Tuesday, April 17, 2018 8:38 AM
> Cc: petsc-users at mcs.anl.gov
> On Tue, Apr 17, 2018 at 8:33 AM, Young, Matthew, Adam <may at bu.edu> wrote:
> My code (C/C++) uses PETSc to solve a linear system at each iteration in a time-stepping scheme. The PETSc routines are separated out because the scheme that uses them is optional in the larger code.
> At each time step, the PETSc scheme calls a routine that includes:
>   Mat A;
>   Vec x,b;
>   KSP ksp;
>   [Set up A,x,b]
>   KSPCreate(PETSC_COMM_WORLD,&ksp);
>   [Build A and b from simulation data]
>   KSPSetOperators(ksp,A,A);
>   KSPSetFromOptions(ksp);
>   KSPSolve(ksp,b,x);
>   [Write x into an instance of our array class, perform checks, etc.]
>   KSPDestroy(&ksp);
>   return(0);
> My question is: If I want to use superLU_DIST with the option -mat_superlu_dist_fact SamePattern (or SamePattern_SameRowPerm), should I move KSPCreate/Destroy outside of the time-step loop in the larger code?
> 1) Yes
> 2) How are you using LU when A has a nullspace?
> My bad - that code is in there from when I was trying iterative solvers. Should I remove it if I use LU or will PETSc just ignore it?
> 3) You can also move out SetFromOptions().
> Thanks for the advice. So, that means I'll build A and b from simulation data, SetOperators(), Solve(), and carry on?
>   Matt
> Thanks.
> Matthew Young
> PhD Candidate
> Astronomy Department
> Boston University
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180417/4551ddc4/attachment.html>
