[petsc-users] question on VecPointwiseMax
Xiangdong
epscodes at gmail.com
Tue Apr 17 10:33:51 CDT 2018
Hello everyone,
When I call VecPointwiseMax(x,x,y) , I got an error message "object is in
wrong state. Vec is locked read only, argument #1."
However, In the online manual of output parameters of VecPointwiseMax, it
says:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecPointwiseMax.html
Output Parameter*w *-the result
Notes: any subset of the x, y, and w may be the same vector. For complex
numbers compares only the real part
However, in the implementation of VecPointwiseMax_Seq,
http://www.mcs.anl.gov/petsc/petsc-current/src/vec/vec/impls/seq/bvec2.c.html#VecPointwiseMax_Seq
it seems that xin is read locked, and win and xin cannot be the same
vectors.
*PetscErrorCode
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
VecPointwiseMax_Seq(Vec
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/Vec.html#Vec>
win,Vec <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/Vec.html#Vec>
xin,Vec <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/Vec.html#Vec>
yin)* 17: { 19: PetscInt
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
n = win->map->n,i; 20: PetscScalar
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscScalar.html#PetscScalar>
*ww,*xx,*yy; /* cannot make xx or yy const since might be ww */
23: VecGetArrayRead
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(xin,(const
PetscScalar <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscScalar.html#PetscScalar>**)&xx);
24: VecGetArrayRead
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArrayRead.html#VecGetArrayRead>(yin,(const
PetscScalar <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscScalar.html#PetscScalar>**)&yy);
25: VecGetArray
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArray.html#VecGetArray>(win,&ww);
27: for (i=0; i<n; i++) ww[i] = PetscMax
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMax.html#PetscMax>(PetscRealPart(xx[i]),PetscRealPart(yy[i]));
29: VecRestoreArrayRead
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecRestoreArrayRead.html#VecRestoreArrayRead>(xin,(const
30: VecRestoreArrayRead
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecRestoreArrayRead.html#VecRestoreArrayRead>(yin,(const
31: VecRestoreArray
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecRestoreArray.html#VecRestoreArray>(win,&ww);
32: PetscLogFlops
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Profiling/PetscLogFlops.html#PetscLogFlops>(n);
33: return(0); 34: }
Can w and x really be same vector in the VecPointwiseMax? Thanks.
Best,
Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180417/783e71cb/attachment.html>
