[petsc-users] PETScFE Point Source
Stefano Zampini stefano.zampini at gmail.com
Fri Apr 13 13:07:35 CDT 2018
What do you mean by point sources? Dirac's delta terms ? If so, these
translates into basis function evaluations , and should not be hard to
support it, but it will require a different API. Matt?
Il Ven 13 Apr 2018, 20:51 Robert Walker <rlwalker at usc.edu> ha scritto:
> Ok, let me rephrase that...something like way FEniCS (if i remember
> correctly) handles this ... between two values with a very small difference
> between them on each axis? Is there an example of something like that to
> use as a security blanket from which to expand?
> Robert
> Robert L. Walker
> MS Petroleum Engineering
> Mork Family Department of Chemicals and Materials Sciences
> University of Southern California
> Mobile US: +1 (213) - 290 -7101
> Mobile EU: +34 62 274 66 40
> rlwalker at usc.edu
> On Fri, Apr 13, 2018 at 10:46 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Apr 13, 2018 at 1:40 PM, Robert Walker <rlwalker at usc.edu> wrote:
>>> Hello,
>>> Is there an example of application of a point source in one of the
>>> tutorial  PETScFE style examples? Ideally this would be some point on the
>>> interior, and not necessarily on a boundary.
>>> Thanks, and apologies in advance if this is a stupid question,
>> No, good question. You would have to decide what that meant in FEM terms.
>> All the internal integrals are done
>> with quadrature. So putting the source at a quadrature point would work,
>> although its a little difficult to know where
>> they will be. You could smooth it out a little, and check coordinates in
>> the forcing function. Last, you could check
>> for a "close enough" quadrature point and put it there. I think making a
>> slightly extended source is usually best.
>>   Thanks,
>>      Matt
>>> Robert
>>> Robert L. Walker
>>> rlwalker at usc.edu
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=clK7kQUTWtAVEOVIgvi0NU5BOUHhpN0H8p7CSfnc_gI&r=BWOpUsAp5dvI5cUiP4uZxQ&m=NhwycEffStNWdPC1pT8qnGZOOnaReNM_T0V8yU1UKHE&s=qwCDj6rCWjIJ1T-NmL3j1bZCdrFx5cOVzTA-l0e0W0o&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180413/d9f030c6/attachment-0001.html>
