[petsc-users] FIELDSPLIT preconditioner in parallel
Rossi, Simone
srossi at email.unc.edu
Fri Apr 13 10:45:18 CDT 2018
It looks like the problem was solved in one of the updates. I cannot reproduce that behavior with the latest PETSc. Thanks!
I'll let you know if it happens again.
Simone
Sent: Friday, April 13, 2018 10:52:13 AM
To: Rossi, Simone
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] FIELDSPLIT preconditioner in parallel
1) Is this with the latest PETSc? some of these issues may have been fixed.
2) Please send use something that reproduces the problem and we will fix it. We aren't aware of this problem.
Barry
> On Apr 13, 2018, at 9:50 AM, Rossi, Simone <srossi at email.unc.edu> wrote:
> Hello,
> I'm trying to use PCFIELDSPLIT to solve a two by two block system and it is working pretty nicely (thanks a lot for that!).
> I'm still having some issues in parallel though: the ksp solver throws an error when one of the fields does not have DOFs on a processor. Is there a way around it?
> Thanks a lot for the help,
> Simone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180413/d835ef76/attachment.html>
