[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
Zhang, Hong
hongzhang at anl.gov
Wed Apr 11 10:07:25 CDT 2018
Performance wise, I would suggest to use "-xAVX" instead of "-axcore-avx2". Based on our experience with running PETSc on a variety of Xeon processors (including KNL), using AVX2 yields comparable and sometimes worse performance than using AVX. But if your machine supports AVX-512, it is definitely beneficial to use AVX-512.
Hong (Mr.)
> On Apr 5, 2018, at 10:03 AM, Randall Mackie <rlmackie862 at gmail.com> wrote:
> Dear PETSc users,
> I’m curious if anyone else experiences problems using DMDAVecGetArrayF90 in conjunction with Intel compilers?
> We have had many problems (typically 11 SEGV segmentation violations) when PETSc is compiled in optimize mode (with various combinations of options).
> These same codes run valgrind clean with gfortran, so I assume this is an Intel bug, but before we submit a bug report I wanted to see if anyone else had similar experiences?
> We have basically gone back and replaced our calls to DMDAVecGetArrayF90 with calls to VecGetArrayF90 and pass those pointers into a “local” subroutine that works fine.
> In case anyone is curious, the attached test code shows this behavior when PETSc is compiled with the following options:
> ./configure \
> --with-clean=1 \
> --with-debugging=0 \
> --with-fortran=1 \
> --with-64-bit-indices \
> --download-mpich=../mpich-3.3a2.tar.gz \
> --with-blas-lapack-dir=/opt/intel/mkl \
> --with-cc=icc \
> --with-fc=ifort \
> --with-cxx=icc \
> --FOPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> --COPTFLAGS='-O2 -xSSSE3 -axcore-avx2' \
> --CXXOPTFLAGS='-O2 -xSSSE3 -axcore-avx2’ \
> Thanks, Randy M.
> <cmd_test><makefile><test.F90>
