[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
Randall Mackie
rlmackie862 at gmail.com
Wed Apr 11 02:12:10 CDT 2018
Hi Satish,
Thanks to you and Jeff for taking a look at this. We will submit a bug report to Intel.
Randy
> On Apr 11, 2018, at 2:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 10 Apr 2018, Jeff Hammond wrote:
>> Can you try on a non-KNL host? It's a bug either way but I want to
>> determine if KNL host is the issue.
> Breaks on 'E5-2695 v4' aswell (bebop.lcrc) with '-axcore-avx2' and 'icc (ICC) 18.0.1 20171018'
>> Based only what I see below, Randy doesn't seem to be reporting a
>> KNL-specific issue. Is that incorrect?
> Hardware details weren't mentioned in this thread.
>> Again, there is clearly a bug here, but it helps to localize the problem as
>> much as possible.
>>>>>> On Thu, 5 Apr 2018, Randall Mackie wrote:
>>>>> so I assume this is an Intel bug, but before we submit a bug
>>>>> report I wanted to see if anyone else had similar experiences?
> Randy,
> I'll leave this to you to file a report with Intel.
> Thanks,
> Satish
