[petsc-users] Cuda libraries and DMDA
Manuel Valera
mvalera-w at sdsu.edu
Mon Apr 9 19:06:04 CDT 2018
i dont have anything for DMSetOptionsPrefix
On Mon, Apr 9, 2018 at 4:55 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> On Mon, Apr 9, 2018 at 4:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Apr 9, 2018 at 7:52 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>>> Ok thanks, i'm learning more every day,
>>> I still get the same error, i am running with -dm_vec_type viennacl
>>> -dm_mat_type aijviennacl -pc_type saviennacl
>> 1) Are you calling DMSetFromOptions()?
> Yes, i get:
> [valera at node50 Src]$ grep DMSetFromOptions *.f90
> DMDAmetrics.f90:call DMSetFromOptions(daDerivs,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daGrid,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daSingle,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daConstants,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daSgs,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daLaplacian,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daMetrics,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daCenters,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daPressureCoeffs,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daDivSgs,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daDummy,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daVelocities,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daScalars,ierr)
> dmdaobjs.f90: call DMSetFromOptions(daDensity,ierr)
> fileIO.f90: call DMSetFromOptions(daWriteCenters,ierr)
> fileIO.f90: call DMSetFromOptions(daWriteUgrid,ierr)
> fileIO.f90: call DMSetFromOptions(daWriteVgrid,ierr)
> fileIO.f90: call DMSetFromOptions(daWriteWgrid,ierr)
> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_u,ierrp)
> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_v,ierrp)
> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_w,ierrp)
> seamountbeamroms.f90: call DMSetFromOptions(daMinPlaneZ,
> ierr)
>> 2) Does your DM have a prefix?
> What does this mean? the one used in the KSPSolve is daDummy
> Thanks,
>> Matt
>>> The error:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: Currently only handles ViennaCL matrices
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9-13-g05d412b GIT
>>> Date: 2018-04-09 08:39:52 -0500
>>> [0]PETSC ERROR: ./gcmBEAM on a cuda-debug named node50 by valera Mon
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug --download-mpich
>>> --with-blaslapack-dir=/usr/lib64 COPTFLAGS=-O2 CXXOPTFLAGS=-O2
>>> FOPTFLAGS=-O2 --with-shared-libraries=1 --download-hypre --with-debugging=1
>>> --with-cuda=1 --CUDAFLAGS=-arch=sm_60 --download-hypre --download-viennacl
>>> --download-cusp --download-cusp-commit=116b090
>>> [0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
>>> [0]PETSC ERROR: #2 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #3 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #4 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #5 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> Finished setting up matrix objects
>>> Exiting PrepareNetCDF
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #6 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #7 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #8 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #9 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.7096996307373047E-002
>>> PETSC_Solve_SSG: 1.7321825027465820E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #10 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #11 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #12 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #13 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2702941894531250E-002
>>> PETSC_Solve_SSG: 1.2929439544677734E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #14 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #15 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #16 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #17 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2219429016113281E-002
>>> PETSC_Solve_SSG: 1.2480735778808594E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #18 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #19 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #20 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #21 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2894392013549805E-002
>>> PETSC_Solve_SSG: 1.3124227523803711E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #22 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #23 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #24 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #25 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2183427810668945E-002
>>> PETSC_Solve_SSG: 1.2410402297973633E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #26 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #27 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #28 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #29 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2546300888061523E-002
>>> PETSC_Solve_SSG: 1.2778043746948242E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #30 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #31 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #32 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #33 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2255668640136719E-002
>>> PETSC_Solve_SSG: 1.2504816055297852E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #34 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #35 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #36 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #37 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.3138055801391602E-002
>>> PETSC_Solve_SSG: 1.3362646102905273E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #38 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #39 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #40 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #41 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2072801589965820E-002
>>> PETSC_Solve_SSG: 1.2319087982177734E-002
>>> Apr 9 16:50:21 2018
>>> [0]PETSC ERROR: #42 PCSetUp_SAVIENNACL() line 47 in
>>> [0]PETSC ERROR: #43 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: #44 KSPSetUp() line 381 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> [0]PETSC ERROR: #45 KSPSolve() line 612 in /home/valera/petsc/src/ksp/ksp
>>> /interface/itfunc.c
>>> PETSC_Solve_Sol: 1.2498617172241211E-002
>>> PETSC_Solve_SSG: 1.2726306915283203E-002
>>> TMain_Loop: 1.1020996570587158
>>> WARNING! There are options you set that were not used!
>>> WARNING! could be spelling mistake, etc!
>>> On Mon, Apr 9, 2018 at 4:45 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Apr 9, 2018 at 7:27 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>>> On Mon, Apr 9, 2018 at 4:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Apr 9, 2018 at 6:12 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>>> wrote:
>>>>>>> Hello guys,
>>>>>>> I've made advances in my CUDA acceleration project, as you remember
>>>>>>> i have a CFD model in need of better execution times.
>>>>>>> So far i have been able to solve the pressure system in the GPU and
>>>>>>> the rest in serial, using PETSc only for this pressure solve, the library i
>>>>>>> got to work was ViennaCL. First question, do i still have to switch
>>>>>>> installations to use either CUDA library? this was a suggestion before, so
>>>>>>> in order to use CUSP instead of ViennaCL, for example, i currently have to
>>>>>>> change installations, is this still the case?
>>>>>> I am not sure what that means exactly. However, you can build a PETSc
>>>>>> with CUDA and ViennaCL support. The type of Vec/Mat is selected at runtime.
>>>>> Karl Rupp wrote in a previous email:
>>>>> * * Right now only one of {native CUDA, CUSP, ViennaCL} can be
>>>>> activated at configure time. This will be fixed later this month.*
>>>>> I was asking if this was already solved in 3.9,
>>>> Karl knows better than I do. I thought that was fixed, but maybe not in
>>>> this release.
>>>>>>> Now, i started working in a fully parallelized version of the model,
>>>>>>> which uses the DMs and DMDAs to distribute the arrays, if i try the same
>>>>>>> flags as before i get an error saying "Currently only handles ViennaCL
>>>>>>> matrices" when trying to solve for pressure, i get this is a feature still
>>>>>>> not implemented? what options do i have to solve pressure, or assign a DMDA
>>>>>>> array update to be done specifically in a GPU device?
>>>>>> If we can't see the error, we are just guessing. Please send the
>>>>>> entire error message.
>>>>> Got it, I will paste the error at the end of this email
>>>> It is asking for a ViennaCL matrix. You must tell the DM to create one:
>>>>>> Note, we only do linear algebra on the GPU, so none of the
>>>>>> FormFunction/FormJacobian stuff for DMDA would be on the GPU.
>>>>> Yes, we only use it for linear algebra, e.g. solving a linear system
>>>>> and updating an array with a problematic algorithm.
>>>>>>> I was thinking of using the VecScatterCreateToZero for a regular
>>>>>>> vector,
>>>>>> Why do you want a serial vector?
>>>>> Because it looks live ViennaCL doesn't handle arrays created with
>>>>> DMDAVec, it was just an idea
>>>> No, it just needs the right type.
>>>>>> but then i would have to create a vector and copy the DMDAVec into it,
>>>>>> I do not understand what it means to copy the DM into the Vec.
>>>>> I meant copying a DMDAVec into a Vec object, the first is created with
>>>>> a DMDA object for it's mapping across processors,
>>>> There is no such thing as a DMDAVec. Everything is just a Vec.
>>>> Thanks,
>>>> Matt
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> is this accomplished with DMDAVecGetArrayReadF90 and then just copy?
>>>>>>> do you think this will generate too much overhead?
>>>>>>> Thanks so much for your input,
>>>>>>> Manuel
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>> The error happens when trying to use KSPSolve() for a vector made with
>>>>> DMDAVec routines, the matrix is created without any DMDA routines
>>>>> Error:
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.8.4-2418-gd9c423b
>>>>> GIT Date: 2018-04-02 11:59:41 +0200
>>>>> [0]PETSC ERROR: ./gcmBEAM on a cuda named node50 by valera Mon Apr 9
>>>>> 16:24:26 2018
>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --download-mpich
>>>>> --download-fblaslapack COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2
>>>>> --with-shared-libraries=1 --download-hypre --with-debugging=no
>>>>> --download-cusp
>>>>> [0]PETSC ERROR: #2 PCSetUp() line 924 in /home/valera/petsc/src/ksp/pc/
>>>>> interface/precon.c
>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>> 16:24:26 2018
>>>>> --download-cusp
>>>>> [0]PETSC ERROR: #5 PCSetUp() line 924 in /home/valera/petsc/src/ksp/pc/
>>>>> interface/precon.c
>>>>> [0]PETSC ERROR: ------------------------------
>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>> probably memory access out of range
>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>> -on_error_attach_debugger
>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>> ocumentation/faq.html#valgrind
>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>>>> OS X to find memory corruption errors
>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>>>> and run
>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>> [0]PETSC ERROR: Signal received
>>>>> 16:24:26 2018
>>>>> --download-cusp
>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in unknown file
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180409/e529a780/attachment-0001.html>
