[petsc-users] How to access Vector data properly
Matthew Knepley
knepley at gmail.com
Mon Apr 9 10:29:36 CDT 2018
On Mon, Apr 9, 2018 at 11:19 AM, Chu Songtao <st.chu at outlook.com> wrote:
> Hong,
> I added the function to the end, but the results didn't change.
> Then I tested another thing, assigning global by Get(Restore)Array instead
> of DMDANaturalToGlobal. And the results switched. VecView outputs 0
> and PetscSynchronizedPrintf outputs correct values. Strange.
Send the whole code. You have a logic error somewhere.
Matt
> ierr = DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,5,1,1,NULL,&da);CHKERRQ(ierr);
> ierr = DMSetUp(da);CHKERRQ(ierr);
> ierr = DMCreateGlobalVector(da,&global);CHKERRQ(ierr);
> ierr = DMDAGetCorners(da,&x,NULL,NULL,&xm,NULL,NULL);CHKERRQ(ierr);
> ierr = DMDAVecGetArray(da, global, &val);CHKERRQ(ierr);
> ierr = PetscSynchronizedPrintf(PETSC_COMM_SELF, "Rank=%d\n", rank);CHKERRQ(ierr);
> for (i = x; i < x + xm; ++i) {
> val[i] = i;
> ierr = DMDAVecRestoreArray(da, global, &val);CHKERRQ(ierr);
> VecView(global,PETSC_VIEWER_STDOUT_WORLD);
> ierr = PetscSynchronizedPrintf(PETSC_COMM_SELF, "%4.f ", val[i]);CHKERRQ(ierr);
> PetscSynchronizedFlush(PETSC_COMM_SELF, PETSC_STDOUT);
> $ mpiexec -n 2 ./test0
> Rank=0
> Rank=1
> Vec Object: 2 MPI processes
> type: mpi
> Vec Object: Vec_0x7fffd6629a90_0 2 MPI processes
> type: mpi
> Rank=1
> 3 4 Process [0]
> 0.
> 0.
> 0.
> Process [1]
> 0.
> 0.
> Rank=0
> 0 1 2
> Songtao :
> You may need adding PetscSynchronizedFlush() to the end.
> See petsc/src/dm/examples/tests/ex43.c
> Hong
> Hello,
> I am just a beginner. Now I get confused on how to correctly use Vec
> and DMDA.
> I set 1D DMDA global vector with natural values for a test. Then use
> VecView and DMDAVecGetArray to view the data, but the results are
> different. I don't know why.
> this is the code:
> PetscMPIInt rank;
> PetscErrorCode ierr;
> Vec global,local,natural;
> DM da;
> PetscReal *xnatural,*val;
> PetscInt i,start,end,x,xm;
> ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
> ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
> ierr = DMDACreateNaturalVector(da,&natural);CHKERRQ(ierr);
> ierr = VecGetOwnershipRange(natural,&start,&end);CHKERRQ(ierr);
> ierr = VecGetArray(natural,&xnatural);CHKERRQ(ierr);
> for (i=start; i<end; i++) {
> xnatural[i-start] = i;
> ierr = VecRestoreArray(natural,&xnatural);CHKERRQ(ierr);
> ierr = DMDANaturalToGlobalBegin(da,natural,INSERT_VALUES,global);CHKERRQ(ierr);
> ierr = DMDANaturalToGlobalEnd(da,natural,INSERT_VALUES,global);CHKERRQ(ierr);
> ierr = VecDestroy(&natural);CHKERRQ(ierr);
> and the results are:
> $ ./test0
> Vec Object: 1 MPI processes
> type: seq
> Vec Object: Vec_0x7ffff3cbc500_0 1 MPI processes
> type: mpi
> Process [0]
> 0.
> 1.
> 2.
> 3.
> 4.
> Rank=0
> 0 1 2 3 4
> type: mpi
> Vec Object: Vec_0x7fffcf948a90_0 2 MPI processes
> type: mpi
> Process [0]
> 0.
> 1.
> 2.
> Process [1]
> 3.
> 4.
> Rank=0
> 0 0 0 Rank=1
> 0 0
> the seq version is correct, but the mpi version is wrong. Every element in
> val is 0.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180409/06683afd/attachment.html>
