[petsc-users] How to access Vector data properly
Hong hzhang at mcs.anl.gov
Mon Apr 9 09:04:31 CDT 2018
Songtao :
You may need adding PetscSynchronizedFlush() to the end.
See petsc/src/dm/examples/tests/ex43.c
Hong
> Hello,
>     I am just a beginner. Now I get confused on how to correctly use Vec
> and DMDA.
>     I set 1D DMDA global vector with natural values for a test. Then use
> VecView and DMDAVecGetArray to view the data, but the results are
> different. I don't know why.
> this is the code:
> PetscMPIInt     rank;
> PetscErrorCode  ierr;
> Vec             global,local,natural;
> DM              da;
> PetscReal       *xnatural,*val;
> PetscInt        i,start,end,x,xm;
> ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
> ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
> ierr = DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,5,1,1,NULL,&da);CHKERRQ(ierr);
> ierr = DMSetUp(da);CHKERRQ(ierr);
> ierr = DMCreateGlobalVector(da,&global);CHKERRQ(ierr);
> ierr = DMDACreateNaturalVector(da,&natural);CHKERRQ(ierr);
> ierr = VecGetOwnershipRange(natural,&start,&end);CHKERRQ(ierr);
> ierr = VecGetArray(natural,&xnatural);CHKERRQ(ierr);
> for (i=start; i<end; i++) {
>     xnatural[i-start] = i;
> ierr = VecRestoreArray(natural,&xnatural);CHKERRQ(ierr);
> ierr = DMDANaturalToGlobalBegin(da,natural,INSERT_VALUES,global);CHKERRQ(ierr);
> ierr = DMDANaturalToGlobalEnd(da,natural,INSERT_VALUES,global);CHKERRQ(ierr);
> ierr = VecDestroy(&natural);CHKERRQ(ierr);
> VecView(global,PETSC_VIEWER_STDOUT_WORLD);
> ierr = DMDAGetCorners(da,&x,NULL,NULL,&xm,NULL,NULL);CHKERRQ(ierr);
> ierr = DMDAVecGetArray(da, global, &val);CHKERRQ(ierr);
> ierr = PetscSynchronizedPrintf(PETSC_COMM_SELF, "Rank=%d\n", rank);CHKERRQ(ierr);
> for (i = x; i < x + xm; ++i) {
>     ierr = PetscSynchronizedPrintf(PETSC_COMM_SELF, "%4.f ", val[i]);CHKERRQ(ierr);
> ierr = DMDAVecRestoreArray(da, global, &val);CHKERRQ(ierr);
> and the results are:
> $ ./test0
> Vec Object: 1 MPI processes
>   type: seq
> Vec Object: Vec_0x7ffff3cbc500_0 1 MPI processes
>   type: mpi
> Process [0]
> 0.
> 1.
> 2.
> 3.
> 4.
> Rank=0
>    0    1    2    3    4
> $ mpiexec -n 2 ./test0
> Vec Object: 2 MPI processes
>   type: mpi
> Vec Object: Vec_0x7fffcf948a90_0 2 MPI processes
>   type: mpi
> Process [0]
> 0.
> 1.
> 2.
> Process [1]
> 3.
> 4.
> Rank=0
>    0    0    0 Rank=1
>    0    0
> the seq version is correct, but the mpi version is wrong. Every element in
> val is 0.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180409/13a049b3/attachment.html>
