[petsc-users] DMPlexGetCone in Fortran
Bernardo Rocha
bernardomartinsrocha at gmail.com
Sat Apr 7 14:13:07 CDT 2018
OK, here is the entire code.
I created a simple mesh to test DMPlex.
As you can see, the GetCone is not working.
As I said, I followed one of the examples for DMPlex using Fortran, I'm not
an exper in F90.
Best regards,
Bernardo M. Rocha
On Fri, Apr 6, 2018 at 11:48 PM, Matthew Knepley <knepley at gmail.com> wrote:
> If you send the whole code, we can try it here. I am assuming that the
> examples run for you.
> Matt
> On Fri, Apr 6, 2018 at 5:47 PM, Bernardo Rocha <
> bernardomartinsrocha at gmail.com> wrote:
>> Hello,
>> I can't get a a simple code to work for DMPlexGetCone.
>> I have tried different ways of handling the array/pointer which is the
>> third argument of DMPlexGetCone,
>> but neither of them worked for me.
>> The last version that I got compiling is this one, which is very much
>> based on the
>> following example: .../petsc-3.7.6/src/dm/impls/p
>> lex/examples/tutorials/ex1f90.F
>> PetscInt, target, dimension(6) :: icone
>> PetscInt, pointer :: pIcone(:)
>> call DMPlexCreateFromCellList(PETSC_COMM_WORLD,
>> & ndim,numel,numnp,nen,PETSC_TRUE,
>> & ielement,ndim,xnodes,dm,ierr)
>> call DMPlexGetCone(dm,0,pIcone,ierr)
>> write(*,*) icone(1),icone(2),icone(3),icone(4),icone(5),icone(6)
>> call DMPlexRestoreCone(dm,0,pIcone,ierr)
>> I always get a segmentation fault.
>> I've created a simple cuboid mesh with 2x2x2 hexaedral elements.
>> Many other routines are working and give reasonable results.
>> Output of DMView
>> DM Object: 1 MPI processes
>> type: plex
>> DM_0x84000000_0 in 3 dimensions:
>> 0-cells: 27
>> 1-cells: 66
>> 2-cells: 44
>> 3-cells: 8
>> Labels:
>> depth: 4 strata of sizes (27, 66, 44, 8)
>> On Thu, Apr 5, 2018 at 10:57 PM, Bernardo Rocha <
>>> OK, thanks a lot.
>>> I had to rename the files and add -ffixed-form as argument to the
>>> compiler.
>>> Best regards,
>>> Bernardo
>>> On Thu, Apr 5, 2018 at 8:21 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Apr 5, 2018 at 7:16 PM, Bernardo Rocha <
>>>>> Hello everyone,
>>>>> I've been trying to use DMPlex in a Fortran 77 application
>>>>> (unfortunately this is legacy code and I can't move to F90).
>>>>> Is there a way to use DMPlexGetCone on it?
>>>>> Although the documentation online says it is only available for F90,
>>>>> I'm wondering if there is a trick like the ones in the users manual
>>>>> for routines
>>>>> that return an array. I tried, but I'm not sure it it is right.
>>>> We have standardized our array handling with F90, and I don't think we
>>>> will go back
>>>> to supporting new things for F77-style arrays.
>>>> That being said, I think all you have to do is compile that source with
>>>> an F90 compiler. You
>>>> should not have to change anything. If you want the F90 array to look
>>>> like an F77 array,
>>>> just pass it as a function argument (I think this works).
>>>> Thanks,
>>>> Matt
>>>>> Best regards,
>>>>> Bernardo M. Rocha
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180407/a3bd48d5/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180407/a3bd48d5/attachment-0001.bin>
