[petsc-users] Index set does not match blocks
Rongliang Chen
rongliang.chan at gmail.com
Sat Apr 7 00:24:34 CDT 2018
Hello everyone,
I updated my code from petsc-3.6 to petsc-3.8 and got the following
error. But it works well if I set the block size to be 1. I am solving
an unstructured mesh problem. Any suggestions for debugging this are
welcome. Thanks.
Best,
Rongliang
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: Index set does not match blocks
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.8.4, Mar, 24, 2018
[0]PETSC ERROR: ./HiBflow on a 64bit-debug named rongliang-chen by
rlchen Sat Apr 7 13:14:20 2018
[0]PETSC ERROR: Configure options --download-mpich --download-blacs
--download-scalapack --download-metis --download-parmetis
--download-exodusii --download-netcdf --download-hdf5 --with-debugging=1
--download-fblaslapack --download-ctetgen --with-64-bit-indices
[0]PETSC ERROR: #1 MatCreateSubMatrix_SeqBAIJ() line 184 in
/home/rlchen/soft/petsc-3.8.4/src/mat/impls/baij/seq/baij2.c
[0]PETSC ERROR: #2 MatCreateSubMatrices_SeqBAIJ() line 264 in
[0]PETSC ERROR: #3 MatCreateSubMatrices() line 6764 in
/home/rlchen/soft/petsc-3.8.4/src/mat/interface/matrix.c
[0]PETSC ERROR: #4 PCSetUp_ASM() line 326 in
/home/rlchen/soft/petsc-3.8.4/src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: #5 PCSetUp() line 924 in
/home/rlchen/soft/petsc-3.8.4/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSPSetUp() line 381 in
/home/rlchen/soft/petsc-3.8.4/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #7 KSPSolve() line 612 in
[0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in
/home/rlchen/soft/petsc-3.8.4/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #9 SNESSolve() line 4131 in
/home/rlchen/soft/petsc-3.8.4/src/snes/interface/snes.c
[0]PETSC ERROR: #10 TimeStep() line 1751 in
/home/rlchen/soft/3D_fluid/3DBloodFlow/Cerebral/Twolevel-3.8/HiBflow.c
[0]PETSC ERROR: #11 SolveTimeDependent() line 1315 in
[0]PETSC ERROR: #12 JoabCtxSolve() line 263 in
[0]PETSC ERROR: #13 main() line 158 in
