[petsc-users] Scatter scipy Sparse matrix to petsc local processor
    Yongxiang Wu
    yongxiang27 at gmail.com
    Fri Apr  6 08:17:47 CDT 2018
Hello Matt,
thanks for your quick reply. My situation is a bit different. What I am
solving is a generalized eigenvalue problem. I only recently switched from
scipy.eigs to slepc, because slepc support parallel eigenvalue problem. In
other word, I am adapting my old code to utilizing slepc/petsc parallel
support. To have a first test, I saved the matrix from eigenvalue problem
with old code. Then read in this matrix for slepc/petsc validation. That's
why I need to scatter it to processors.  Do you have any idea how can I
achieve this?
with regards
Yongxiang
On 6 April 2018 at 15:00, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Apr 6, 2018 at 8:44 AM, Yongxiang Wu <yongxiang27 at gmail.com>
> wrote:
>> Hello, everyone,
>> I already have a scipy sparse square matrix L0 . Since my problem is
>> large, parallel run is preferred. My Question is, how can I scatter my L0
>>  to each of the processors? In the following code, I can get the indices
>> of the localized part of the matrix. In the tutorial, the matrix element
>> are directly assign with value, but in my case, the matrix are so large,
>> assign each element in loop (commented code) is not efficient. So if any
>> function would do the mpi scatter work?
> Hi Yongxiang,
> It would be really anomalous for what you propose to results in any
> speedup at all. If the matrix is large,
> it will not fit on one process. Any speedup from using more processes will
> be eaten up by the time to
> communicate the matrix. I would focus on generating the matrix in parallel.
>   Thanks,
>      Matt
>> With regards and Thanks.
>>     import sys, slepc4py
>>     slepc4py.init(sys.argv)
>>     from petsc4py import PETSc
>>     from slepc4py import SLEPc
>>     opts = PETSc.Options()
>>     opts.setValue('-st_pc_factor_mat_solver_package','mumps')
>>     A = PETSc.Mat().createAIJ(size=L0.shape,comm=PETSc.COMM_WORLD)
>>     A.setUp()
>>     Istart, Iend = A.getOwnershipRange()#    for I in range(Istart,Iend):#        for J in range(0,L0.shape[0]):#            A[I,J] = L0[I,J]
>> The flowing code, would make the assignment from the scipy sparse matrix
>> L0 to PETSc matrix A. But this would only work for one process.
>>                                    csr=(L0.indptr, L0.indices,
>>                                         L0.data), comm=PETSc.COMM_WORLD)
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180406/21909d6d/attachment-0001.html>
