[petsc-users] --download-hdf5 and then compiling cgns
Klaij, Christiaan C.Klaij at marin.nl
Thu Apr 5 09:06:59 CDT 2018
That would be nice. The minimum for me would be
./configure \
    --prefix=/path/to/myprefix \
    --with-hdf5=/path/to/petsc/hdf5 \
    --with-fortran=yes
but I sure like to have their tools as well
./configure \
    --with-fortran=yes \
    --enable-cgnstools \
            --datarootdir=/path/to/myprefix/share
This is more tricky as it requires tcl and tk libs. Also
datarootdir is supposed to be PREFIX/share by default, but
there's a bug so I had to specify it explicitly.
Chris
dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-open-dag-in-Wageningen.htm
Sent: Thursday, April 05, 2018 3:31 PM
To: Klaij, Christiaan
Cc: Gaetan Kenway; petsc-users
Subject: Re: [petsc-users] --download-hdf5 and then compiling cgns
Glad it works..
Perhaps its is simple fix to add in --download-cgns option to petsc configure..
[I see its a direct dependency from PETSc sources - src/dm/impls/plex/plexcgns.c ]
Satish
On Thu, 5 Apr 2018, Klaij, Christiaan wrote:
> Satish, Gaetan, thanks for your suggestions. I've decided not to
> use cmake for cgns, and that works fine with petsc's build of
> hdf5.
> Chris
> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | www.marin.nl<http://www.marin.nl>
> [LinkedIn]<https://www.linkedin.com/company/marin> [YouTube] <http://www.youtube.com/marinmultimedia>  [Twitter] <https://twitter.com/MARIN_nieuws>  [Facebook] <https://www.facebook.com/marin.wageningen>
> MARIN news: Kom zaterdag 10 november naar de open dag in Wageningen!<http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-open-dag-in-Wageningen.htm>
> From: Gaetan Kenway <gaetank at gmail.com>
> Sent: Thursday, March 29, 2018 6:43 PM
> To: petsc-users
> Cc: Klaij, Christiaan
> I have compiled CGNS3.3 with hdf from PETSc but not using cmake from CGNS. Here is what I used:
> git clone  https://github.com/CGNS/CGNS.git
> cd CGNS/src
> export CC=mpicc
> export FC=mpif90
> export FCFLAGS='-fPIC -O3'
> export CFLAGS='-fPIC -O3'
> export LIBS='-lz -ldl'
> ./configure --with-hdf5=$PETSC_DIR/$PETSC_ARCH --enable-64bit --prefix=/u/wk/gkenway/.local  --enable-parallel --enable-cgnstools=yes --enable-shared
> make -j 10
> Hope that helps
> Gaetan
> On Thu, Mar 29, 2018 at 9:37 AM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
> --download-hdf5 uses 'autoconf' build of hdf5 - and not cmake
> build. [hdf5 provides both build tools].
> This must be the reason why hdf5Config.cmake and hdf5-config.cmake
> files might be missing.
> You might be able to install hdf5 manually with cmake - and then build
> cgns-3.3.1 with it.
> Satish
> On Thu, 29 Mar 2018, Klaij, Christiaan wrote:
> > Satish,
> > I've build petsc-3.8.3 with --download-hdf5 and this works
> > fine. Now, I'm trying to compile cgns-3.3.1 and have it use the
> > hdf5 library from petsc. Therefore, in the cmake configure I have
> > set this option
> > -D HDF5_DIR=/path/to/petsc/hdf5
> > but cmake gives this message:
> > CMake Warning at CMakeLists.txt:207 (find_package):
> >   Could not find a package configuration file provided by "HDF5" with any of
> >   the following names:
> >     hdf5Config.cmake
> >     hdf5-config.cmake
> > and then falls back to the system's hdf5. Indeed there are no
> > such files in /path/to/petsc/hdf5. Any idea on how to proceed
> > from here?
> > Chris
> > MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | http://www.marin.nl
> > MARIN news: http://www.marin.nl/web/News/News-items/Comfort-draft-for-semisubmersible-yachts.htm
