[petsc-users] A bad commit affects MOOSE
Kong, Fande
fande.kong at inl.gov
Tue Apr 3 12:21:06 CDT 2018
Figured out:
The reason is that in MatCreate_HYPRE(Mat B), we call MPI_Comm_dup
instead of PetscCommDuplicate. The PetscCommDuplicate is better, and it
does not actually create a communicator if the communicator is already
known to PETSc.
Furthermore, I do not think we should a comm in
*typedef struct { HYPRE_IJMatrix ij; HYPRE_IJVector x; HYPRE_IJVector
b; MPI_Comm comm;} Mat_HYPRE;*
It is an inner data of Mat, and it should already the same comm as the Mat.
I do not understand why the internal data has its own comm.
The following patch fixed the issue (just deleted this extra comm).
diff --git a/src/mat/impls/hypre/mhypre.c b/src/mat/impls/hypre/mhypre.c
index dc19892..d8cfe3d 100644
--- a/src/mat/impls/hypre/mhypre.c
+++ b/src/mat/impls/hypre/mhypre.c
@@ -74,7 +74,7 @@ static PetscErrorCode MatHYPRE_CreateFromMat(Mat A,
Mat_HYPRE *hA)
rend = A->rmap->rend;
cstart = A->cmap->rstart;
cend = A->cmap->rend;
PetscStackCallStandard(HYPRE_IJMatrixCreate,(hA->comm,rstart,rend-1,cstart,cend-1,&hA->ij));
PetscStackCallStandard(HYPRE_IJMatrixCreate,(PetscObjectComm((PetscObject)A),rstart,rend-1,cstart,cend-1,&hA->ij));
PetscStackCallStandard(HYPRE_IJMatrixSetObjectType,(hA->ij,HYPRE_PARCSR));
PetscBool same;
@@ -434,7 +434,7 @@ PetscErrorCode MatDestroy_HYPRE(Mat A)
if (hA->x) PetscStackCallStandard(HYPRE_IJVectorDestroy,(hA->x));
if (hA->b) PetscStackCallStandard(HYPRE_IJVectorDestroy,(hA->b));
if (hA->ij) PetscStackCallStandard(HYPRE_IJMatrixDestroy,(hA->ij));
- if (hA->comm) { ierr = MPI_Comm_free(&hA->comm);CHKERRQ(ierr);}
+ /*if (hA->comm) { ierr = MPI_Comm_free(&hA->comm);CHKERRQ(ierr);}*/
ierr =
PetscObjectComposeFunction((PetscObject)A,"MatConvert_hypre_aij_C",NULL);CHKERRQ(ierr);
ierr = PetscFree(A->data);CHKERRQ(ierr);
PetscFunctionReturn(0);
@@ -500,7 +500,8 @@ PETSC_EXTERN PetscErrorCode MatCreate_HYPRE(Mat B)
B->ops->destroy = MatDestroy_HYPRE;
B->ops->assemblyend = MatAssemblyEnd_HYPRE;
- ierr =
MPI_Comm_dup(PetscObjectComm((PetscObject)B),&hB->comm);CHKERRQ(ierr);
+ /*ierr =
MPI_Comm_dup(PetscObjectComm((PetscObject)B),&hB->comm);CHKERRQ(ierr); */
+ /*ierr =
PetscCommDuplicate(PetscObjectComm((PetscObject)B),&hB->comm,NULL);CHKERRQ(ierr);*/
ierr = PetscObjectChangeTypeName((PetscObject)B,MATHYPRE);CHKERRQ(ierr);
ierr =
PetscObjectComposeFunction((PetscObject)B,"MatConvert_hypre_aij_C",MatConvert_HYPRE_AIJ);CHKERRQ(ierr);
diff --git a/src/mat/impls/hypre/mhypre.h b/src/mat/impls/hypre/mhypre.h
index 3d9ddd2..1189020 100644
--- a/src/mat/impls/hypre/mhypre.h
+++ b/src/mat/impls/hypre/mhypre.h
@@ -10,7 +10,7 @@ typedef struct {
HYPRE_IJMatrix ij;
HYPRE_IJVector x;
HYPRE_IJVector b;
- MPI_Comm comm;
+ /*MPI_Comm comm;*/
} Mat_HYPRE;
Fande,
On Tue, Apr 3, 2018 at 10:35 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Apr 2018, Satish Balay wrote:
> > On Tue, 3 Apr 2018, Derek Gaston wrote:
> > > One thing I want to be clear of here: is that we're not trying to solve
> > > this particular problem (where we're creating 1000 instances of Hypre
> to
> > > precondition each variable independently)... this particular problem is
> > > just a test (that we've had in our test suite for a long time) to
> stress
> > > test some of this capability.
> > > We really do have needs for thousands (tens of thousands) of
> simultaneous
> > > solves (each with their own Hypre instances). That's not what this
> > > particular problem is doing - but it is representative of a class of
> our
> > > problems we need to solve.
> > > Which does bring up a point: I have been able to do solves before with
> > > ~50,000 separate PETSc solves without issue. Is it because I was
> working
> > > with MVAPICH on a cluster? Does it just have a higher limit?
> > Don't know - but thats easy to find out with a simple test code..
> > $ cat comm_dup_test.c
> > #include <mpi.h>
> > #include <stdio.h>
> > int main(int argc, char** argv) {
> > MPI_Comm newcomm;
> > int i, err;
> > MPI_Init(NULL, NULL);
> > for (i=0; i<100000; i++) {
> > err = MPI_Comm_dup(MPI_COMM_WORLD, &newcomm);
> > if (err) {
> > printf("%5d - fail\n",i);fflush(stdout);
> > break;
> > } else {
> > printf("%5d - success\n",i);fflush(stdout);
> > MPI_Finalize();
> > OpenMPI fails after '65531' and mpich after '2044'. MVAPICH is derived
> > off MPICH - but its possible they have a different limit than MPICH.
> BTW: the above is with: openmpi-2.1.2 and mpich-3.3b1
> mvapich2-1.9.5 - and I get error after '2044' comm dupes
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/69ad0f7f/attachment.html>
