[petsc-users] A bad commit affects MOOSE
Stefano Zampini stefano.zampini at gmail.com
Tue Apr 3 10:50:09 CDT 2018
> On Apr 3, 2018, at 5:43 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> On Tue, Apr 3, 2018 at 9:12 AM, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
>> On Apr 3, 2018, at 4:58 PM, Satish Balay <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>> wrote:
>> On Tue, 3 Apr 2018, Kong, Fande wrote:
>>> On Tue, Apr 3, 2018 at 1:17 AM, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>   Each external package definitely needs its own duplicated communicator;
>>>> cannot share between packages.
>>>>   The only problem with the dups below is if they are in a loop and get
>>>> called many times.
>>> The "standard test" that has this issue actually has 1K fields. MOOSE
>>> creates its own field-split preconditioner (not based on the PETSc
>>> fieldsplit), and each filed is associated with one PC HYPRE.  If PETSc
>>> duplicates communicators, we should easily reach the limit 2048.
>>> I also want to confirm what extra communicators are introduced in the bad
>>> commit.
>> To me it looks like there is 1 extra comm created [for MATHYPRE] for each PCHYPRE that is created [which also creates one comm for this object].
> You’re right; however, it was the same before the commit.
> I don’t understand how this specific commit is related with this issue, being the error not in the MPI_Comm_Dup which is inside MatCreate_MATHYPRE. Actually, the error comes from MPI_Comm_create
>     frame #5: 0x00000001068defd4 libmpi.12.dylib`MPI_Comm_create + 3492
>     frame #6: 0x00000001061345d9 libpetsc.3.07.dylib`hypre_GenerateSubComm(comm=-1006627852, participate=<unavailable>, new_comm_ptr=<unavailable>) + 409 at gen_redcs_mat.c:531 [opt]
>     frame #7: 0x000000010618f8ba libpetsc.3.07.dylib`hypre_GaussElimSetup(amg_data=0x00007fe7ff857a00, level=<unavailable>, relax_type=9) + 74 at par_relax.c:4209 [opt]
>     frame #8: 0x0000000106140e93 libpetsc.3.07.dylib`hypre_BoomerAMGSetup(amg_vdata=<unavailable>, A=0x00007fe80842aff0, f=0x00007fe80842a980, u=0x00007fe80842a510) + 17699 at par_amg_setup.c:2108 [opt]
>     frame #9: 0x0000000105ec773c libpetsc.3.07.dylib`PCSetUp_HYPRE(pc=<unavailable>) + 2540 at hypre.c:226 [opt
> How did you perform the bisection? make clean + make all ? Which version of HYPRE are you using?
> I did more aggressively.
> "rm -rf  arch-darwin-c-opt-bisect   "
> "./configure  --optionsModule=config.compilerOptions -with-debugging=no --with-shared-libraries=1 --with-mpi=1 --download-fblaslapack=1 --download-metis=1 --download-parmetis=1 --download-superlu_dist=1 --download-hypre=1 --download-mumps=1 --download-scalapack=1 PETSC_ARCH=arch-darwin-c-opt-bisect"
Good, so this removes some possible sources of errors
> HYPRE verison:
>     self.gitcommit = 'v2.11.1-55-g2ea0e43'
>     self.download  = ['git://https://github.com/LLNL/hypre <https://github.com/LLNL/hypre>','https://github.com/LLNL/hypre/archive/'+self.gitcommit+'.tar.gz <https://github.com/LLNL/hypre/archive/'+self.gitcommit+'.tar.gz>']
When reconfiguring, the  HYPRE version can be different too (that commit is from 11/2016, so the HYPRE version used by the PETSc configure can have been upgraded too)
> I do not think this is caused by HYPRE.
> Fande,
>> But you might want to verify [by linking with mpi trace library?]
>> There are some debugging hints at https://lists.mpich.org/pipermail/discuss/2012-December/000148.html <https://lists.mpich.org/pipermail/discuss/2012-December/000148.html> [wrt mpich] - which I haven't checked..
>> Satish
>>> Fande,
>>>>    To debug the hypre/duplication issue in MOOSE I would run in the
>>>> debugger with a break point in MPI_Comm_dup() and see
>>>> who keeps calling it an unreasonable amount of times. (My guess is this is
>>>> a new "feature" in hypre that they will need to fix but only debugging will
>>>> tell)
>>>>   Barry
>>>>> On Apr 2, 2018, at 7:44 PM, Balay, Satish <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>> wrote:
>>>>> We do a MPI_Comm_dup() for objects related to externalpackages.
>>>>> Looks like we added a new mat type MATHYPRE - in 3.8 that PCHYPRE is
>>>>> using. Previously there was one MPI_Comm_dup() PCHYPRE - now I think
>>>>> is one more for MATHYPRE - so more calls to MPI_Comm_dup in 3.8 vs 3.7
>>>>> src/dm/impls/da/hypre/mhyp.c:  ierr = MPI_Comm_dup(PetscObjectComm((
>>>> PetscObject)B),&(ex->hcomm));CHKERRQ(ierr);
>>>>> src/dm/impls/swarm/data_ex.c:  ierr = MPI_Comm_dup(comm,&d->comm);
>>>> CHKERRQ(ierr);
>>>>> src/ksp/pc/impls/hypre/hypre.c:  ierr = MPI_Comm_dup(PetscObjectComm((
>>>> PetscObject)pc),&(jac->comm_hypre));CHKERRQ(ierr);
>>>> PetscObject)pc),&(ex->hcomm));CHKERRQ(ierr);
>>>>> src/ksp/pc/impls/spai/ispai.c:  ierr      =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)pc),&(ispai->comm_
>>>> spai));CHKERRQ(ierr);
>>>>> src/mat/examples/tests/ex152.c:  ierr   = MPI_Comm_dup(MPI_COMM_WORLD,
>>>> &comm);CHKERRQ(ierr);
>>>>> src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c:  ierr =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mat_mkl_
>>>> cpardiso->comm_mkl_cpardiso));CHKERRQ(ierr);
>>>>> src/mat/impls/aij/mpi/mumps/mumps.c:  ierr =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mumps->comm_
>>>> mumps));CHKERRQ(ierr);
>>>>> src/mat/impls/aij/mpi/pastix/pastix.c:    ierr =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->pastix_
>>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:  ierr =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->comm_
>>>> superlu));CHKERRQ(ierr);
>>>>> src/mat/impls/hypre/mhypre.c:  ierr = MPI_Comm_dup(PetscObjectComm((
>>>> PetscObject)B),&hB->comm);CHKERRQ(ierr);
>>>>> src/mat/partition/impls/pmetis/pmetis.c:    ierr   =
>>>> MPI_Comm_dup(pcomm,&comm);CHKERRQ(ierr);
>>>>> src/sys/mpiuni/mpi.c:    MPI_COMM_SELF, MPI_COMM_WORLD, and a
>>>> MPI_Comm_dup() of each of these (duplicates of duplicates return the same
>>>> communictor)
>>>>> src/sys/mpiuni/mpi.c:int MPI_Comm_dup(MPI_Comm comm,MPI_Comm *out)
>>>>> src/sys/objects/pinit.c:      ierr = MPI_Comm_dup(MPI_COMM_WORLD,&
>>>> local_comm);CHKERRQ(ierr);
>>>>> src/sys/objects/tagm.c:      ierr = MPI_Comm_dup(comm_in,comm_out)
>>>> ;CHKERRQ(ierr);
>>>>> src/sys/utils/mpiu.c:  ierr = MPI_Comm_dup(comm,&local_comm)
>>>> ;CHKERRQ(ierr);
>>>>> src/ts/impls/implicit/sundials/sundials.c:  ierr =
>>>> MPI_Comm_dup(PetscObjectComm((PetscObject)ts),&(cvode->comm_
>>>> sundials));CHKERRQ(ierr);
>>>>> Perhaps we need a PetscCommDuplicateExternalPkg() to somehow avoid
>>>> these MPI_Comm_dup() calls?
>>>>> Satish
>>>>> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
>>>>>> Are we sure this is a PETSc comm issue and not a hypre comm
>>>> duplication issue
>>>>>> Looks like hypre is needed to generate subcomms, perhaps it generates
>>>> too many?
>>>>>>  Barry
>>>>>>> On Apr 2, 2018, at 7:07 PM, Derek Gaston <friedmud at gmail.com <mailto:friedmud at gmail.com>> wrote:
>>>>>>> I’m working with Fande on this and I would like to add a bit more.
>>>> There are many circumstances where we aren’t working on COMM_WORLD at all
>>>> (e.g. working on a sub-communicator) but PETSc was initialized using
>>>> MPI_COMM_WORLD (think multi-level solves)… and we need to create
>>>> arbitrarily many PETSc vecs/mats/solvers/preconditioners and solve.  We
>>>> definitely can’t rely on using PETSC_COMM_WORLD to avoid triggering
>>>> duplication.
>>>>>>> Can you explain why PETSc needs to duplicate the communicator so much?
>>>>>>> Thanks for your help in tracking this down!
>>>>>>> Derek
>>>>>>> On Mon, Apr 2, 2018 at 5:44 PM Kong, Fande <fande.kong at inl.gov <mailto:fande.kong at inl.gov>> wrote:
>>>>>>> Why we do not use user-level MPI communicators directly? What are
>>>> potential risks here?
>>>>>>> Fande,
>>>>>>> On Mon, Apr 2, 2018 at 5:08 PM, Satish Balay <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>
>>>> wrote:
>>>>>>> PETSC_COMM_WORLD [via PetscCommDuplicate()] attempts to minimize calls
>>>> to MPI_Comm_dup() - thus potentially avoiding such errors
>>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs>.
>>>> anl.gov_petsc_petsc-2Dcurrent_docs_manualpages_Sys_
>>>> PetscCommDuplicate.html&d=DwIBAg&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
>>>> _aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmi
>>>> CY&m=jgv7gpZ3K52d_FWMgkK9yEScbLA7pkrWydFuJnYflsU&s=_
>>>> zpWRcyk3kHuEHoq02NDqYExnXIohXpNnjyabYnnDjU&e=
>>>>>>> Satish
>>>>>>> On Mon, 2 Apr 2018, Kong, Fande wrote:
>>>>>>>> On Mon, Apr 2, 2018 at 4:23 PM, Satish Balay <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>
>>>> wrote:
>>>>>>>>> Does this 'standard test' use MPI_COMM_WORLD' to crate PETSc objects?
>>>>>>>>> If so - you could try changing to PETSC_COMM_WORLD
>>>>>>>> I do not think we are using PETSC_COMM_WORLD when creating PETSc
>>>> objects.
>>>>>>>> Why we can not use MPI_COMM_WORLD?
>>>>>>>> Fande,
>>>>>>>>> Satish
>>>>>>>>>> Hi All,
>>>>>>>>>> I am trying to upgrade PETSc from 3.7.6 to 3.8.3 for MOOSE and its
>>>>>>>>>> applications. I have a error message for a standard test:
>>>>>>>>>> *preconditioners/pbp.lots_of_variables: MPI had an
>>>>>>>>>> errorpreconditioners/pbp.lots_of_variables:
>>>>>>>>>> Other MPI error, error stack:preconditioners/pbp.lots_of_variables:
>>>>>>>>>> PMPI_Comm_dup(177)..................: MPI_Comm_dup(comm=0x84000001,
>>>>>>>>>> new_comm=0x97d1068) failedpreconditioners/pbp.lots_of_variables:
>>>>>>>>>> PMPI_Comm_dup(162)..................:
>>>>>>>>>> MPIR_Comm_dup_impl(57)..............:
>>>>>>>>>> MPIR_Comm_copy(739).................:
>>>>>>>>>> MPIR_Get_contextid_sparse_group(614): Too many communicators
>>>> (0/2048
>>>>>>>>> free
>>>>>>>>>> on this process; ignore_id=0)*
>>>>>>>>>> I did "git bisect', and the following commit introduces this issue:
>>>>>>>>>> *commit 49a781f5cee36db85e8d5b951eec29f10ac13593Author: Stefano
>>>> Zampini
>>>>>>>>>> <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com> <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>>>Date:   Sat
>>>> Nov 5
>>>>>>>>>> 20:15:19 2016 +0300    PCHYPRE: use internal Mat of type MatHYPRE
>>>>>>>>>> hpmat already stores two HYPRE vectors*
>>>>>>>>>> Before I debug line-by-line, anyone has a clue on this?
>>>>>>>>>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/799f2f01/attachment-0001.html>
