[petsc-users] A bad commit affects MOOSE
Kong, Fande fande.kong at inl.gov
Tue Apr 3 10:38:02 CDT 2018
On Tue, Apr 3, 2018 at 9:32 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Apr 2018, Stefano Zampini wrote:
> > > On Apr 3, 2018, at 4:58 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > On Tue, 3 Apr 2018, Kong, Fande wrote:
> > >> On Tue, Apr 3, 2018 at 1:17 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > >>>   Each external package definitely needs its own duplicated
> communicator;
> > >>> cannot share between packages.
> > >>>   The only problem with the dups below is if they are in a loop and
> get
> > >>> called many times.
> > >> The "standard test" that has this issue actually has 1K fields. MOOSE
> > >> creates its own field-split preconditioner (not based on the PETSc
> > >> fieldsplit), and each filed is associated with one PC HYPRE.  If PETSc
> > >> duplicates communicators, we should easily reach the limit 2048.
> > >> I also want to confirm what extra communicators are introduced in the
> bad
> > >> commit.
> > > To me it looks like there is 1 extra comm created [for MATHYPRE] for
> each PCHYPRE that is created [which also creates one comm for this object].
> > You’re right; however, it was the same before the commit.
> https://urldefense.proofpoint.com/v2/url?u=https-3A__
> bitbucket.org_petsc_petsc_commits_49a781f5cee36db85e8d5b951eec29
> f10ac13593&d=DwIDaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
> _aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmi
> CY&m=6_ukwovpDrK5BL_94S4ezasw2a3S15SM59R41rSY-Yw&s=
> r8xHYLKF9LtJHReR6Jmfeei3OfwkQNiGrKXAgeqPVQ8&e=
> Before the commit - PCHYPRE was not calling MatConvert(MATHYPRE) [this
> results in an additional call to MPI_Comm_dup() for hypre calls] PCHYPRE
> was calling MatHYPRE_IJMatrixCreate() directly [which I presume reusing the
> comm created by the call to MPI_Comm_dup() in PCHYPRE - for hypre calls]
> > I don’t understand how this specific commit is related with this issue,
> being the error not in the MPI_Comm_Dup which is inside MatCreate_MATHYPRE.
> Actually, the error comes from MPI_Comm_create
> >     frame #5: 0x00000001068defd4 libmpi.12.dylib`MPI_Comm_create + 3492
> >     frame #6: 0x00000001061345d9 libpetsc.3.07.dylib`hypre_
> GenerateSubComm(comm=-1006627852, participate=<unavailable>,
> new_comm_ptr=<unavailable>) + 409 at gen_redcs_mat.c:531 [opt]
> >     frame #7: 0x000000010618f8ba libpetsc.3.07.dylib`hypre_
> GaussElimSetup(amg_data=0x00007fe7ff857a00, level=<unavailable>,
> relax_type=9) + 74 at par_relax.c:4209 [opt]
> >     frame #8: 0x0000000106140e93 libpetsc.3.07.dylib`hypre_
> BoomerAMGSetup(amg_vdata=<unavailable>, A=0x00007fe80842aff0,
> f=0x00007fe80842a980, u=0x00007fe80842a510) + 17699 at par_amg_setup.c:2108
> [opt]
> >     frame #9: 0x0000000105ec773c libpetsc.3.07.dylib`PCSetUp_HYPRE(pc=<unavailable>)
> + 2540 at hypre.c:226 [opt
> I thought this trace comes up after applying your patch
This trace comes from Mac
> -    ierr = MatDestroy(&jac->hpmat);CHKERRQ(ierr);
> -    ierr = MatConvert(pc->pmat,MATHYPRE,MAT_INITIAL_MATRIX,&jac->
> +    ierr = MatConvert(pc->pmat,MATHYPRE,jac->hpmat ? MAT_REUSE_MATRIX :
> MAT_INITIAL_MATRIX,&jac->hpmat);CHKERRQ(ierr);
> The stack before this patch was: [its a different format - so it was
> obtained in a different way than the above method?]
> preconditioners/pbp.lots_of_variables: Other MPI error, error stack:
> preconditioners/pbp.lots_of_variables: PMPI_Comm_dup(177)..................:
> MPI_Comm_dup(comm=0x84000001, new_comm=0x97d1068) failed
> preconditioners/pbp.lots_of_variables: PMPI_Comm_dup(162)............
> preconditioners/pbp.lots_of_variables: MPIR_Comm_dup_impl(57)........
> preconditioners/pbp.lots_of_variables: MPIR_Comm_copy(739)...........
> preconditioners/pbp.lots_of_variables: MPIR_Get_contextid_sparse_group(614):
> Too many communicators (0/2048 free on this process; ignore_id=0)
This comes from a Linux (it is a test box), and I do not have access to it.
Fande,
> Satish
> > How did you perform the bisection? make clean + make all ? Which version
> of HYPRE are you using?
> > > But you might want to verify [by linking with mpi trace library?]
> > > There are some debugging hints at https://urldefense.proofpoint.
> com/v2/url?u=https-3A__lists.mpich.org_pipermail_discuss_
> 2012-2DDecember_000148.html&d=DwIDaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
> s=XUy9n2kmdq262Gwrn_RMXYR-bIyiKViCvp4fRfGCP9w&e= [wrt mpich] - which I
> haven't checked..
> > > Satish
> > >> Fande,
> > >>>    To debug the hypre/duplication issue in MOOSE I would run in the
> > >>> debugger with a break point in MPI_Comm_dup() and see
> > >>> who keeps calling it an unreasonable amount of times. (My guess is
> this is
> > >>> a new "feature" in hypre that they will need to fix but only
> debugging will
> > >>> tell)
> > >>>   Barry
> > >>>> On Apr 2, 2018, at 7:44 PM, Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > >>>> We do a MPI_Comm_dup() for objects related to externalpackages.
> > >>>> Looks like we added a new mat type MATHYPRE - in 3.8 that PCHYPRE is
> > >>>> using. Previously there was one MPI_Comm_dup() PCHYPRE - now I think
> > >>>> is one more for MATHYPRE - so more calls to MPI_Comm_dup in 3.8 vs
> 3.7
> > >>>> src/dm/impls/da/hypre/mhyp.c:  ierr = MPI_Comm_dup(PetscObjectComm((
> > >>> PetscObject)B),&(ex->hcomm));CHKERRQ(ierr);
> > >>>> src/dm/impls/swarm/data_ex.c:  ierr = MPI_Comm_dup(comm,&d->comm);
> > >>> CHKERRQ(ierr);
> > >>>> src/ksp/pc/impls/hypre/hypre.c:  ierr =
> > >>> PetscObject)pc),&(jac->comm_hypre));CHKERRQ(ierr);
> > >>> PetscObject)pc),&(ex->hcomm));CHKERRQ(ierr);
> > >>>> src/ksp/pc/impls/spai/ispai.c:  ierr      =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)pc),&(ispai->comm_
> > >>> spai));CHKERRQ(ierr);
> > >>>> src/mat/examples/tests/ex152.c:  ierr   =
> MPI_Comm_dup(MPI_COMM_WORLD,
> > >>> &comm);CHKERRQ(ierr);
> > >>>> src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c:  ierr =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mat_mkl_
> > >>> cpardiso->comm_mkl_cpardiso));CHKERRQ(ierr);
> > >>>> src/mat/impls/aij/mpi/mumps/mumps.c:  ierr =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mumps->comm_
> > >>> mumps));CHKERRQ(ierr);
> > >>>> src/mat/impls/aij/mpi/pastix/pastix.c:    ierr =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->pastix_
> > >>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:  ierr =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->comm_
> > >>> superlu));CHKERRQ(ierr);
> > >>>> src/mat/impls/hypre/mhypre.c:  ierr = MPI_Comm_dup(PetscObjectComm((
> > >>> PetscObject)B),&hB->comm);CHKERRQ(ierr);
> > >>>> src/mat/partition/impls/pmetis/pmetis.c:    ierr   =
> > >>> MPI_Comm_dup(pcomm,&comm);CHKERRQ(ierr);
> > >>>> src/sys/mpiuni/mpi.c:    MPI_COMM_SELF, MPI_COMM_WORLD, and a
> > >>> MPI_Comm_dup() of each of these (duplicates of duplicates return the
> same
> > >>> communictor)
> > >>>> src/sys/mpiuni/mpi.c:int MPI_Comm_dup(MPI_Comm comm,MPI_Comm *out)
> > >>>> src/sys/objects/pinit.c:      ierr = MPI_Comm_dup(MPI_COMM_WORLD,&
> > >>> local_comm);CHKERRQ(ierr);
> > >>>> src/sys/objects/tagm.c:      ierr = MPI_Comm_dup(comm_in,comm_out)
> > >>> ;CHKERRQ(ierr);
> > >>>> src/sys/utils/mpiu.c:  ierr = MPI_Comm_dup(comm,&local_comm)
> > >>> ;CHKERRQ(ierr);
> > >>>> src/ts/impls/implicit/sundials/sundials.c:  ierr =
> > >>> MPI_Comm_dup(PetscObjectComm((PetscObject)ts),&(cvode->comm_
> > >>> sundials));CHKERRQ(ierr);
> > >>>> Perhaps we need a PetscCommDuplicateExternalPkg() to somehow avoid
> > >>> these MPI_Comm_dup() calls?
> > >>>> Satish
> > >>>> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
> > >>>>> Are we sure this is a PETSc comm issue and not a hypre comm
> > >>> duplication issue
> > >>>>> Looks like hypre is needed to generate subcomms, perhaps it
> generates
> > >>> too many?
> > >>>>>  Barry
> > >>>>>> On Apr 2, 2018, at 7:07 PM, Derek Gaston <friedmud at gmail.com>
> wrote:
> > >>>>>> I’m working with Fande on this and I would like to add a bit more.
> > >>> There are many circumstances where we aren’t working on COMM_WORLD
> at all
> > >>> (e.g. working on a sub-communicator) but PETSc was initialized using
> > >>> MPI_COMM_WORLD (think multi-level solves)… and we need to create
> > >>> arbitrarily many PETSc vecs/mats/solvers/preconditioners and
> solve.  We
> > >>> definitely can’t rely on using PETSC_COMM_WORLD to avoid triggering
> > >>> duplication.
> > >>>>>> Can you explain why PETSc needs to duplicate the communicator so
> much?
> > >>>>>> Thanks for your help in tracking this down!
> > >>>>>> Derek
> > >>>>>> On Mon, Apr 2, 2018 at 5:44 PM Kong, Fande <fande.kong at inl.gov>
> wrote:
> > >>>>>> Why we do not use user-level MPI communicators directly? What are
> > >>> potential risks here?
> > >>>>>> Fande,
> > >>>>>> On Mon, Apr 2, 2018 at 5:08 PM, Satish Balay <balay at mcs.anl.gov>
> > >>> wrote:
> > >>>>>> PETSC_COMM_WORLD [via PetscCommDuplicate()] attempts to minimize
> calls
> > >>> to MPI_Comm_dup() - thus potentially avoiding such errors
> > >>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.
> > >>> anl.gov_petsc_petsc-2Dcurrent_docs_manualpages_Sys_
> > >>> PetscCommDuplicate.html&d=DwIBAg&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
> > >>> CY&m=jgv7gpZ3K52d_FWMgkK9yEScbLA7pkrWydFuJnYflsU&s=_
> > >>> zpWRcyk3kHuEHoq02NDqYExnXIohXpNnjyabYnnDjU&e=
> > >>>>>> Satish
> > >>>>>> On Mon, 2 Apr 2018, Kong, Fande wrote:
> > >>>>>>> On Mon, Apr 2, 2018 at 4:23 PM, Satish Balay <balay at mcs.anl.gov>
> > >>> wrote:
> > >>>>>>>> Does this 'standard test' use MPI_COMM_WORLD' to crate PETSc
> objects?
> > >>>>>>>> If so - you could try changing to PETSC_COMM_WORLD
> > >>>>>>> I do not think we are using PETSC_COMM_WORLD when creating PETSc
> > >>> objects.
> > >>>>>>> Why we can not use MPI_COMM_WORLD?
> > >>>>>>> Fande,
> > >>>>>>>> Satish
> > >>>>>>>>> Hi All,
> > >>>>>>>>> I am trying to upgrade PETSc from 3.7.6 to 3.8.3 for MOOSE and
> its
> > >>>>>>>>> applications. I have a error message for a standard test:
> > >>>>>>>>> *preconditioners/pbp.lots_of_variables: MPI had an
> > >>>>>>>>> errorpreconditioners/pbp.lots_of_variables:
> > >>>>>>>>> Other MPI error, error stack:preconditioners/pbp.
> lots_of_variables:
> > >>>>>>>>> new_comm=0x97d1068) failedpreconditioners/pbp.
> lots_of_variables:
> > >>>>>>>>> PMPI_Comm_dup(162)..................:
> > >>>>>>>>> MPIR_Comm_dup_impl(57)..............:
> > >>>>>>>>> MPIR_Comm_copy(739).................:
> > >>>>>>>>> MPIR_Get_contextid_sparse_group(614): Too many communicators
> > >>> (0/2048
> > >>>>>>>> free
> > >>>>>>>>> on this process; ignore_id=0)*
> > >>>>>>>>> I did "git bisect', and the following commit introduces this
> issue:
> > >>>>>>>>> *commit 49a781f5cee36db85e8d5b951eec29f10ac13593Author:
> Stefano
> > >>> Zampini
> > >>>>>>>>> <stefano.zampini at gmail.com <stefano.zampini at gmail.com>>Date:
>  Sat
> > >>> Nov 5
> > >>>>>>>>> 20:15:19 2016 +0300    PCHYPRE: use internal Mat of type
> MatHYPRE
> > >>>>>>>>> hpmat already stores two HYPRE vectors*
> > >>>>>>>>> Before I debug line-by-line, anyone has a clue on this?
> > >>>>>>>>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/8584cab5/attachment-0001.html>
