[petsc-users] DMForestTransferVec with -petscspace_order 0
Yann Jobic
yann.jobic at univ-amu.fr
Tue Apr 3 10:29:39 CDT 2018
Thanks for the fast answer ! And sorry for my late one...
As a test, i'm using ex2.c in test/forest directory.
I'm using 2 git depot (master), one from this week end, and one of
today. I see some different behaviors.
For the git from the week end : v3.8.4-1-g756c7f9
In 2D, everything is ok (petscspace_order = 0,1,2) : mpiexec -n 1 ./ex2
-petscspace_poly_tensor -petscspace_order 2 -dim 2
In 3D, only -petscspace_order 2 works. For the other ones, i put the
full message in a log file.
For the git from today : v3.8.4-2420-g8f4cb0b
In 2D, petscspace_order is ok for 2 and 1, but do not work for 0.
In 3D, same as 2D, it's working for petscspace_order 2 and 1, but not
for 0. (see log file)
Many thanks for the help !
Yann
Le 03/04/2018 à 03:33, Tobin Isaac a écrit :
> Hi Yann,
> Thanks for pointing this out to us. Matt and I are the two most
> actively developing in this area. We have been working on separate
> threads and this looks like an issue where we need to sync up. I
> think there is a simple fix, but it would be helpful to know which
> version petsc you're working from: I'm seeing different
> behavior. Could you please send along more complete output?
> Cheers,
> Toby
> On Mon, Apr 02, 2018 at 04:42:29PM +0200, yann JOBIC wrote:
>> Hi,
>> I'm using DMForestTransferVec, as in "dm/impls/forest/examples/tests/ex2.c".
>> I would like to use it with a space approximation order at zero
>> (-petscspace_order 0). However, in this case, it's not working (valgrind
>> output of ex2.c from forest test) :
>> ==8604== Conditional jump or move depends on uninitialised value(s)
>> ==8604== at 0x47D74F: DMPlexVecGetClosure (plex.c:4035)
>> ==8604== by 0x557612: DMPlexLocatePoint_General_3D_Internal
>> (plexgeometry.c:153)
>> ==8604== by 0x559B85: DMPlexLocatePoint_Internal (plexgeometry.c:383)
>> ==8604== by 0x611EED: DMPlexComputeInjectorReferenceTree
>> (plextree.c:3247)
>> ==8604== by 0x6148DB: DMPlexReferenceTreeGetInjector (plextree.c:3454)
>> ==8604== by 0x61EAD8: DMPlexTransferVecTree_Inject (plextree.c:4319)
>> ==8604== by 0x620CC1: DMPlexTransferVecTree (plextree.c:4527)
>> ==8604== by 0x7F23D8: DMForestTransferVec_p8est (pforest.c:4239)
>> ==8604== by 0x429B48: DMForestTransferVec (forest.c:985)
>> ==8604== by 0x40BB8A: main (transf_test.c:136)
>> With the error message :
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> It's working fine in 2D (p4est). The problem arise in 3D (p8est).
>> Is it an expected behavior ? Am i doing something wrong ?
>> Thanks in advance,
>> Yann
___________________________
Yann JOBIC
HPC engineer
IUSTI-CNRS UMR 7343 - Polytech Marseille
Technopôle de Château Gombert
5 rue Enrico Fermi
13453 Marseille cedex 13
Tel : (33) 4 91 10 69 43
Fax : (33) 4 91 10 69 69
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
yann at crabe:~/projet/AMR/moulinette$ mpiexec -n 1 ./ex2 -petscspace_poly_tensor -petscspace_order 0 -dim 3
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] DMPlexVecGetClosure line 4020 /home/yann/src/petsc-git/src/dm/impls/plex/plex.c
[0]PETSC ERROR: [0] DMPlexLocatePoint_General_3D_Internal line 150 /home/yann/src/petsc-git/src/dm/impls/plex/plexgeometry.c
[0]PETSC ERROR: [0] DMPlexLocatePoint_Internal line 361 /home/yann/src/petsc-git/src/dm/impls/plex/plexgeometry.c
[0]PETSC ERROR: [0] DMPlexComputeInjectorReferenceTree line 3008 /home/yann/src/petsc-git/src/dm/impls/plex/plextree.c
[0]PETSC ERROR: [0] DMPlexReferenceTreeGetInjector line 3449 /home/yann/src/petsc-git/src/dm/impls/plex/plextree.c
[0]PETSC ERROR: [0] DMPlexTransferVecTree_Inject line 4309 /home/yann/src/petsc-git/src/dm/impls/plex/plextree.c
[0]PETSC ERROR: [0] DMPlexTransferVecTree line 4486 /home/yann/src/petsc-git/src/dm/impls/plex/plextree.c
[0]PETSC ERROR: [0] DMForestTransferVec_p8est line 4213 /home/yann/src/petsc-git/src/dm/impls/forest/p4est/pforest.c
[0]PETSC ERROR: [0] DMForestTransferVec line 978 /home/yann/src/petsc-git/src/dm/impls/forest/forest.c
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.8.4, unknown
[0]PETSC ERROR: ./ex2 on a depot-git named crabe by yann Tue Apr 3 17:18:02 2018
[0]PETSC ERROR: Configure options --prefix=/local/lib/petsc/depot-git/gcc/openmpi_gcc_all --with-single-library=0 --with-debugging=1 --download-scalapack=1 --download-metis=1 --download-parmetis=1 --download-ptscotch=1 --download-mumps=1 --download-hypre=1 --download-superlu=1 --download-superlu_dist=1 --download-fblaslapack=1 --download-metis=1 --download-cmake=1 --download-ml=1 --download-p4est=1 --download-netcdf=1 --download-pragmatic=1 --download-eigen=1 --download-parms=1 --download-triangle=1 --download-hdf5=1 --with-zlib=1 --download-szlib=1 --download-chaco=1 --download-spai=1 --download-suitesparse=1 --with-shared-libraries=0 PETSC_ARCH=depot-git
[0]PETSC ERROR: #1 User provided function() line 0 in unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[36533,1],0]
Exit code: 59
jobic at stargate:~/projet/AMR/moulinette$ mpirun -np 1 ./ex2 -petscspace_poly_tensor -dim 3 -petscspace_order 0
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 2
[0]PETSC ERROR: Petsc Development GIT revision: v3.8.4-2420-g8f4cb0b GIT Date: 2018-04-02 16:00:52 -0500
[0]PETSC ERROR: ./ex2 on a named stargate by jobic Tue Apr 3 17:22:04 2018
[0]PETSC ERROR: Configure options --download-chaco=1 --download-cmake=1 --download-eigen=1 --download-fblaslapack=1 --download-hdf5=1 --download-hypre=1 --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1 --download-p4est=1 --download-parmetis=1 --download-parms=1 --download-pragmatic=1 --download-ptscotch=1 --download-scalapack=1 --download-spai=1 --download-suitesparse=1 --download-superlu=1 --download-superlu_dist=1 --download-szlib=1 --download-triangle=1 --prefix=/local/lib/petsc/git/gcc/openmpi_gcc_all --with-debugging=1 --with-shared-libraries=0 --with-single-library=0 --with-zlib=1 PETSC_ARCH=openmpi_gcc_all
[0]PETSC ERROR: #1 PetscFESetDualSpace() line 3615 in /home/devel/src_linux/git.petsc/petsc/src/dm/dt/interface/dtfe.c
[0]PETSC ERROR: #2 PetscFEGetHeightSubspace() line 6630 in /home/devel/src_linux/git.petsc/petsc/src/dm/dt/interface/dtfe.c
[0]PETSC ERROR: #3 PetscDSGetHeightSubspace() line 2880 in /home/devel/src_linux/git.petsc/petsc/src/dm/dt/interface/dtds.c
[0]PETSC ERROR: #4 DMProjectLocal_Generic_Plex() line 325 in /home/devel/src_linux/git.petsc/petsc/src/dm/impls/plex/plexproject.c
[0]PETSC ERROR: #5 DMProjectFunctionLocal_Plex() line 428 in /home/devel/src_linux/git.petsc/petsc/src/dm/impls/plex/plexproject.c
[0]PETSC ERROR: #6 DMProjectFunctionLocal() line 6265 in /home/devel/src_linux/git.petsc/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #7 DMProjectFunctionLocal_p8est() line 4385 in /home/devel/src_linux/git.petsc/petsc/src/dm/impls/forest/p4est/pforest.c
[0]PETSC ERROR: #8 DMProjectFunctionLocal() line 6265 in /home/devel/src_linux/git.petsc/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #9 DMProjectFunction() line 6250 in /home/devel/src_linux/git.petsc/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #10 main() line 161 in /home/jobic/projet/AMR/moulinette/ex2.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -dim 3
[0]PETSC ERROR: -petscspace_order 0
[0]PETSC ERROR: -petscspace_poly_tensor
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
with errorcode 85.
With valgrind :
jobic at stargate:~/projet/AMR/moulinette$ valgrind mpirun -np 1 ./ex2 -petscspace_poly_tensor -dim 3 -petscspace_order 0
==9730== Memcheck, a memory error detector
==9730== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==9730== Using Valgrind-3.12.0 and LibVEX; rerun with -h for copyright info
==9730== Command: mpirun -np 1 ./ex2 -petscspace_poly_tensor -dim 3 -petscspace_order 0
==9730==
==10212== Warning: invalid file descriptor 1024 in syscall close()
==10212== Warning: invalid file descriptor 1025 in syscall close()
==10212== Warning: invalid file descriptor 1026 in syscall close()
==10212== Warning: invalid file descriptor 1027 in syscall close()
==10212== Use --log-fd=<number> to select an alternative log fd.
==10212== Warning: invalid file descriptor 1028 in syscall close()
==10212== Warning: invalid file descriptor 1029 in syscall close()
[0]PETSC ERROR: ./ex2 on a named stargate by jobic Tue Apr 3 17:27:58 2018
with errorcode 85.
==9730==
==9730== HEAP SUMMARY:
==9730== in use at exit: 55,755 bytes in 116 blocks
==9730== total heap usage: 19,779 allocs, 19,663 frees, 6,633,193 bytes allocated
==9730==
==9730== LEAK SUMMARY:
==9730== definitely lost: 2,675 bytes in 11 blocks
==9730== indirectly lost: 48,765 bytes in 75 blocks
==9730== possibly lost: 200 bytes in 1 blocks
==9730== still reachable: 4,115 bytes in 29 blocks
==9730== suppressed: 0 bytes in 0 blocks
==9730== Rerun with --leak-check=full to see details of leaked memory
==9730==
==9730== For counts of detected and suppressed errors, rerun with: -v
==9730== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
