[petsc-users] A bad commit affects MOOSE
Stefano Zampini
stefano.zampini at gmail.com
Tue Apr 3 10:12:04 CDT 2018
> On Apr 3, 2018, at 4:58 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Apr 2018, Kong, Fande wrote:
>> On Tue, Apr 3, 2018 at 1:17 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>> Each external package definitely needs its own duplicated communicator;
>>> cannot share between packages.
>>> The only problem with the dups below is if they are in a loop and get
>>> called many times.
>> The "standard test" that has this issue actually has 1K fields. MOOSE
>> creates its own field-split preconditioner (not based on the PETSc
>> fieldsplit), and each filed is associated with one PC HYPRE. If PETSc
>> duplicates communicators, we should easily reach the limit 2048.
>> I also want to confirm what extra communicators are introduced in the bad
>> commit.
> To me it looks like there is 1 extra comm created [for MATHYPRE] for each PCHYPRE that is created [which also creates one comm for this object].
You’re right; however, it was the same before the commit.
I don’t understand how this specific commit is related with this issue, being the error not in the MPI_Comm_Dup which is inside MatCreate_MATHYPRE. Actually, the error comes from MPI_Comm_create
frame #5: 0x00000001068defd4 libmpi.12.dylib`MPI_Comm_create + 3492
frame #6: 0x00000001061345d9 libpetsc.3.07.dylib`hypre_GenerateSubComm(comm=-1006627852, participate=<unavailable>, new_comm_ptr=<unavailable>) + 409 at gen_redcs_mat.c:531 [opt]
frame #7: 0x000000010618f8ba libpetsc.3.07.dylib`hypre_GaussElimSetup(amg_data=0x00007fe7ff857a00, level=<unavailable>, relax_type=9) + 74 at par_relax.c:4209 [opt]
frame #8: 0x0000000106140e93 libpetsc.3.07.dylib`hypre_BoomerAMGSetup(amg_vdata=<unavailable>, A=0x00007fe80842aff0, f=0x00007fe80842a980, u=0x00007fe80842a510) + 17699 at par_amg_setup.c:2108 [opt]
frame #9: 0x0000000105ec773c libpetsc.3.07.dylib`PCSetUp_HYPRE(pc=<unavailable>) + 2540 at hypre.c:226 [opt
How did you perform the bisection? make clean + make all ? Which version of HYPRE are you using?
> But you might want to verify [by linking with mpi trace library?]
> There are some debugging hints at https://lists.mpich.org/pipermail/discuss/2012-December/000148.html [wrt mpich] - which I haven't checked..
> Satish
>> Fande,
>>> To debug the hypre/duplication issue in MOOSE I would run in the
>>> debugger with a break point in MPI_Comm_dup() and see
>>> who keeps calling it an unreasonable amount of times. (My guess is this is
>>> a new "feature" in hypre that they will need to fix but only debugging will
>>> tell)
>>> Barry
>>>> On Apr 2, 2018, at 7:44 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>>> We do a MPI_Comm_dup() for objects related to externalpackages.
>>>> Looks like we added a new mat type MATHYPRE - in 3.8 that PCHYPRE is
>>>> using. Previously there was one MPI_Comm_dup() PCHYPRE - now I think
>>>> is one more for MATHYPRE - so more calls to MPI_Comm_dup in 3.8 vs 3.7
>>>> src/dm/impls/da/hypre/mhyp.c: ierr = MPI_Comm_dup(PetscObjectComm((
>>> PetscObject)B),&(ex->hcomm));CHKERRQ(ierr);
>>>> src/dm/impls/swarm/data_ex.c: ierr = MPI_Comm_dup(comm,&d->comm);
>>> CHKERRQ(ierr);
>>>> src/ksp/pc/impls/hypre/hypre.c: ierr = MPI_Comm_dup(PetscObjectComm((
>>> PetscObject)pc),&(jac->comm_hypre));CHKERRQ(ierr);
>>> PetscObject)pc),&(ex->hcomm));CHKERRQ(ierr);
>>>> src/ksp/pc/impls/spai/ispai.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)pc),&(ispai->comm_
>>> spai));CHKERRQ(ierr);
>>>> src/mat/examples/tests/ex152.c: ierr = MPI_Comm_dup(MPI_COMM_WORLD,
>>> &comm);CHKERRQ(ierr);
>>>> src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mat_mkl_
>>> cpardiso->comm_mkl_cpardiso));CHKERRQ(ierr);
>>>> src/mat/impls/aij/mpi/mumps/mumps.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mumps->comm_
>>> mumps));CHKERRQ(ierr);
>>>> src/mat/impls/aij/mpi/pastix/pastix.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->pastix_
>>>> src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->comm_
>>> superlu));CHKERRQ(ierr);
>>>> src/mat/impls/hypre/mhypre.c: ierr = MPI_Comm_dup(PetscObjectComm((
>>> PetscObject)B),&hB->comm);CHKERRQ(ierr);
>>>> src/mat/partition/impls/pmetis/pmetis.c: ierr =
>>> MPI_Comm_dup(pcomm,&comm);CHKERRQ(ierr);
>>>> src/sys/mpiuni/mpi.c: MPI_COMM_SELF, MPI_COMM_WORLD, and a
>>> MPI_Comm_dup() of each of these (duplicates of duplicates return the same
>>> communictor)
>>>> src/sys/mpiuni/mpi.c:int MPI_Comm_dup(MPI_Comm comm,MPI_Comm *out)
>>>> src/sys/objects/pinit.c: ierr = MPI_Comm_dup(MPI_COMM_WORLD,&
>>> local_comm);CHKERRQ(ierr);
>>>> src/sys/objects/tagm.c: ierr = MPI_Comm_dup(comm_in,comm_out)
>>> ;CHKERRQ(ierr);
>>>> src/sys/utils/mpiu.c: ierr = MPI_Comm_dup(comm,&local_comm)
>>> ;CHKERRQ(ierr);
>>>> src/ts/impls/implicit/sundials/sundials.c: ierr =
>>> MPI_Comm_dup(PetscObjectComm((PetscObject)ts),&(cvode->comm_
>>> sundials));CHKERRQ(ierr);
>>>> Perhaps we need a PetscCommDuplicateExternalPkg() to somehow avoid
>>> these MPI_Comm_dup() calls?
>>>> Satish
>>>> On Tue, 3 Apr 2018, Smith, Barry F. wrote:
>>>>> Are we sure this is a PETSc comm issue and not a hypre comm
>>> duplication issue
>>>>> Looks like hypre is needed to generate subcomms, perhaps it generates
>>> too many?
>>>>> Barry
>>>>>> On Apr 2, 2018, at 7:07 PM, Derek Gaston <friedmud at gmail.com> wrote:
>>>>>> I’m working with Fande on this and I would like to add a bit more.
>>> There are many circumstances where we aren’t working on COMM_WORLD at all
>>> (e.g. working on a sub-communicator) but PETSc was initialized using
>>> MPI_COMM_WORLD (think multi-level solves)… and we need to create
>>> arbitrarily many PETSc vecs/mats/solvers/preconditioners and solve. We
>>> definitely can’t rely on using PETSC_COMM_WORLD to avoid triggering
>>> duplication.
>>>>>> Can you explain why PETSc needs to duplicate the communicator so much?
>>>>>> Thanks for your help in tracking this down!
>>>>>> Derek
>>>>>> On Mon, Apr 2, 2018 at 5:44 PM Kong, Fande <fande.kong at inl.gov> wrote:
>>>>>> Why we do not use user-level MPI communicators directly? What are
>>> potential risks here?
>>>>>> Fande,
>>>>>> On Mon, Apr 2, 2018 at 5:08 PM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>>>>> PETSC_COMM_WORLD [via PetscCommDuplicate()] attempts to minimize calls
>>> to MPI_Comm_dup() - thus potentially avoiding such errors
>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.
>>> anl.gov_petsc_petsc-2Dcurrent_docs_manualpages_Sys_
>>> PetscCommDuplicate.html&d=DwIBAg&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
>>> _aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmi
>>> CY&m=jgv7gpZ3K52d_FWMgkK9yEScbLA7pkrWydFuJnYflsU&s=_
>>> zpWRcyk3kHuEHoq02NDqYExnXIohXpNnjyabYnnDjU&e=
>>>>>> Satish
>>>>>> On Mon, 2 Apr 2018, Kong, Fande wrote:
>>>>>>> On Mon, Apr 2, 2018 at 4:23 PM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>>>>>>> Does this 'standard test' use MPI_COMM_WORLD' to crate PETSc objects?
>>>>>>>> If so - you could try changing to PETSC_COMM_WORLD
>>>>>>> I do not think we are using PETSC_COMM_WORLD when creating PETSc
>>> objects.
>>>>>>> Why we can not use MPI_COMM_WORLD?
>>>>>>> Fande,
>>>>>>>> Satish
>>>>>>>>> Hi All,
>>>>>>>>> I am trying to upgrade PETSc from 3.7.6 to 3.8.3 for MOOSE and its
>>>>>>>>> applications. I have a error message for a standard test:
>>>>>>>>> *preconditioners/pbp.lots_of_variables: MPI had an
>>>>>>>>> errorpreconditioners/pbp.lots_of_variables:
>>>>>>>>> Other MPI error, error stack:preconditioners/pbp.lots_of_variables:
>>>>>>>>> PMPI_Comm_dup(177)..................: MPI_Comm_dup(comm=0x84000001,
>>>>>>>>> new_comm=0x97d1068) failedpreconditioners/pbp.lots_of_variables:
>>>>>>>>> PMPI_Comm_dup(162)..................:
>>>>>>>>> MPIR_Comm_dup_impl(57)..............:
>>>>>>>>> MPIR_Comm_copy(739).................:
>>>>>>>>> MPIR_Get_contextid_sparse_group(614): Too many communicators
>>> (0/2048
>>>>>>>> free
>>>>>>>>> on this process; ignore_id=0)*
>>>>>>>>> I did "git bisect', and the following commit introduces this issue:
>>>>>>>>> *commit 49a781f5cee36db85e8d5b951eec29f10ac13593Author: Stefano
>>> Zampini
>>>>>>>>> <stefano.zampini at gmail.com <stefano.zampini at gmail.com>>Date: Sat
>>> Nov 5
>>>>>>>>> 20:15:19 2016 +0300 PCHYPRE: use internal Mat of type MatHYPRE
>>>>>>>>> hpmat already stores two HYPRE vectors*
>>>>>>>>> Before I debug line-by-line, anyone has a clue on this?
>>>>>>>>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/f022b348/attachment-0001.html>
