[petsc-users] A bad commit affects MOOSE
Kong, Fande
fande.kong at inl.gov
Tue Apr 3 09:46:41 CDT 2018
On Tue, Apr 3, 2018 at 1:17 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Each external package definitely needs its own duplicated communicator;
> cannot share between packages.
> The only problem with the dups below is if they are in a loop and get
> called many times.
The "standard test" that has this issue actually has 1K fields. MOOSE
creates its own field-split preconditioner (not based on the PETSc
fieldsplit), and each filed is associated with one PC HYPRE. If PETSc
duplicates communicators, we should easily reach the limit 2048.
I also want to confirm what extra communicators are introduced in the bad
commit.
Fande,
> To debug the hypre/duplication issue in MOOSE I would run in the
> debugger with a break point in MPI_Comm_dup() and see
> who keeps calling it an unreasonable amount of times. (My guess is this is
> a new "feature" in hypre that they will need to fix but only debugging will
> tell)
> Barry
> > On Apr 2, 2018, at 7:44 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > We do a MPI_Comm_dup() for objects related to externalpackages.
> > Looks like we added a new mat type MATHYPRE - in 3.8 that PCHYPRE is
> > using. Previously there was one MPI_Comm_dup() PCHYPRE - now I think
> > is one more for MATHYPRE - so more calls to MPI_Comm_dup in 3.8 vs 3.7
> > src/dm/impls/da/hypre/mhyp.c: ierr = MPI_Comm_dup(PetscObjectComm((
> PetscObject)B),&(ex->hcomm));CHKERRQ(ierr);
> > src/dm/impls/swarm/data_ex.c: ierr = MPI_Comm_dup(comm,&d->comm);
> CHKERRQ(ierr);
> > src/ksp/pc/impls/hypre/hypre.c: ierr = MPI_Comm_dup(PetscObjectComm((
> PetscObject)pc),&(jac->comm_hypre));CHKERRQ(ierr);
> PetscObject)pc),&(ex->hcomm));CHKERRQ(ierr);
> > src/ksp/pc/impls/spai/ispai.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)pc),&(ispai->comm_
> spai));CHKERRQ(ierr);
> > src/mat/examples/tests/ex152.c: ierr = MPI_Comm_dup(MPI_COMM_WORLD,
> &comm);CHKERRQ(ierr);
> > src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mat_mkl_
> cpardiso->comm_mkl_cpardiso));CHKERRQ(ierr);
> > src/mat/impls/aij/mpi/mumps/mumps.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(mumps->comm_
> mumps));CHKERRQ(ierr);
> > src/mat/impls/aij/mpi/pastix/pastix.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->pastix_
> > src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)A),&(lu->comm_
> superlu));CHKERRQ(ierr);
> > src/mat/impls/hypre/mhypre.c: ierr = MPI_Comm_dup(PetscObjectComm((
> PetscObject)B),&hB->comm);CHKERRQ(ierr);
> > src/mat/partition/impls/pmetis/pmetis.c: ierr =
> MPI_Comm_dup(pcomm,&comm);CHKERRQ(ierr);
> > src/sys/mpiuni/mpi.c: MPI_COMM_SELF, MPI_COMM_WORLD, and a
> MPI_Comm_dup() of each of these (duplicates of duplicates return the same
> communictor)
> > src/sys/mpiuni/mpi.c:int MPI_Comm_dup(MPI_Comm comm,MPI_Comm *out)
> > src/sys/objects/pinit.c: ierr = MPI_Comm_dup(MPI_COMM_WORLD,&
> local_comm);CHKERRQ(ierr);
> > src/sys/objects/tagm.c: ierr = MPI_Comm_dup(comm_in,comm_out)
> ;CHKERRQ(ierr);
> > src/sys/utils/mpiu.c: ierr = MPI_Comm_dup(comm,&local_comm)
> ;CHKERRQ(ierr);
> > src/ts/impls/implicit/sundials/sundials.c: ierr =
> MPI_Comm_dup(PetscObjectComm((PetscObject)ts),&(cvode->comm_
> sundials));CHKERRQ(ierr);
> > Perhaps we need a PetscCommDuplicateExternalPkg() to somehow avoid
> these MPI_Comm_dup() calls?
> > Satish
> > On Tue, 3 Apr 2018, Smith, Barry F. wrote:
> >> Are we sure this is a PETSc comm issue and not a hypre comm
> duplication issue
> >> frame #6: 0x00000001061345d9 libpetsc.3.07.dylib`hypre_
> GenerateSubComm(comm=-1006627852, participate=<unavailable>,
> new_comm_ptr=<unavailable>) + 409 at gen_redcs_mat.c:531 [opt]
> >> Looks like hypre is needed to generate subcomms, perhaps it generates
> too many?
> >> Barry
> >>> On Apr 2, 2018, at 7:07 PM, Derek Gaston <friedmud at gmail.com> wrote:
> >>> I’m working with Fande on this and I would like to add a bit more.
> There are many circumstances where we aren’t working on COMM_WORLD at all
> (e.g. working on a sub-communicator) but PETSc was initialized using
> MPI_COMM_WORLD (think multi-level solves)… and we need to create
> arbitrarily many PETSc vecs/mats/solvers/preconditioners and solve. We
> definitely can’t rely on using PETSC_COMM_WORLD to avoid triggering
> duplication.
> >>> Can you explain why PETSc needs to duplicate the communicator so much?
> >>> Thanks for your help in tracking this down!
> >>> Derek
> >>> On Mon, Apr 2, 2018 at 5:44 PM Kong, Fande <fande.kong at inl.gov> wrote:
> >>> Why we do not use user-level MPI communicators directly? What are
> potential risks here?
> >>> Fande,
> >>> On Mon, Apr 2, 2018 at 5:08 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> >>> PETSC_COMM_WORLD [via PetscCommDuplicate()] attempts to minimize calls
> to MPI_Comm_dup() - thus potentially avoiding such errors
> >>> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.
> anl.gov_petsc_petsc-2Dcurrent_docs_manualpages_Sys_
> PetscCommDuplicate.html&d=DwIBAg&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB_
> _aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmi
> CY&m=jgv7gpZ3K52d_FWMgkK9yEScbLA7pkrWydFuJnYflsU&s=_
> zpWRcyk3kHuEHoq02NDqYExnXIohXpNnjyabYnnDjU&e=
> >>> Satish
> >>> On Mon, 2 Apr 2018, Kong, Fande wrote:
> >>>> On Mon, Apr 2, 2018 at 4:23 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> >>>>> Does this 'standard test' use MPI_COMM_WORLD' to crate PETSc objects?
> >>>>> If so - you could try changing to PETSC_COMM_WORLD
> >>>> I do not think we are using PETSC_COMM_WORLD when creating PETSc
> objects.
> >>>> Why we can not use MPI_COMM_WORLD?
> >>>> Fande,
> >>>>> Satish
> >>>>>> Hi All,
> >>>>>> I am trying to upgrade PETSc from 3.7.6 to 3.8.3 for MOOSE and its
> >>>>>> applications. I have a error message for a standard test:
> >>>>>> *preconditioners/pbp.lots_of_variables: MPI had an
> >>>>>> errorpreconditioners/pbp.lots_of_variables:
> >>>>>> Other MPI error, error stack:preconditioners/pbp.lots_of_variables:
> >>>>>> PMPI_Comm_dup(177)..................: MPI_Comm_dup(comm=0x84000001,
> >>>>>> new_comm=0x97d1068) failedpreconditioners/pbp.lots_of_variables:
> >>>>>> PMPI_Comm_dup(162)..................:
> >>>>>> MPIR_Comm_dup_impl(57)..............:
> >>>>>> MPIR_Comm_copy(739).................:
> >>>>>> MPIR_Get_contextid_sparse_group(614): Too many communicators
> (0/2048
> >>>>> free
> >>>>>> on this process; ignore_id=0)*
> >>>>>> I did "git bisect', and the following commit introduces this issue:
> >>>>>> *commit 49a781f5cee36db85e8d5b951eec29f10ac13593Author: Stefano
> Zampini
> >>>>>> <stefano.zampini at gmail.com <stefano.zampini at gmail.com>>Date: Sat
> Nov 5
> >>>>>> 20:15:19 2016 +0300 PCHYPRE: use internal Mat of type MatHYPRE
> >>>>>> hpmat already stores two HYPRE vectors*
> >>>>>> Before I debug line-by-line, anyone has a clue on this?
> >>>>>> Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180403/67c0f0d5/attachment-0001.html>
