[petsc-users] A bad commit affects MOOSE
Satish Balay
balay at mcs.anl.gov
Mon Apr 2 19:48:14 CDT 2018
Sorry - I was going down the wrong path..
Sure MPI_COMM_WORLD vs PETSC_COMM_WORLD shouldn't make a difference
[except for a couple of extra mpi_comm_dup() calls.]
Satish
On Tue, 3 Apr 2018, Derek Gaston wrote:
> I’m working with Fande on this and I would like to add a bit more. There
> are many circumstances where we aren’t working on COMM_WORLD at all (e.g.
> working on a sub-communicator) but PETSc was initialized using
> MPI_COMM_WORLD (think multi-level solves)… and we need to create
> arbitrarily many PETSc vecs/mats/solvers/preconditioners and solve. We
> definitely can’t rely on using PETSC_COMM_WORLD to avoid triggering
> duplication.
> Can you explain why PETSc needs to duplicate the communicator so much?
> Thanks for your help in tracking this down!
> Derek
> On Mon, Apr 2, 2018 at 5:44 PM Kong, Fande <fande.kong at inl.gov> wrote:
> > Why we do not use user-level MPI communicators directly? What are
> > potential risks here?
> > Fande,
> > On Mon, Apr 2, 2018 at 5:08 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> PETSC_COMM_WORLD [via PetscCommDuplicate()] attempts to minimize calls to
> >> MPI_Comm_dup() - thus potentially avoiding such errors
> >> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.anl.gov_petsc_petsc-2Dcurrent_docs_manualpages_Sys_PetscCommDuplicate.html&d=DwIBAg&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=jgv7gpZ3K52d_FWMgkK9yEScbLA7pkrWydFuJnYflsU&s=_zpWRcyk3kHuEHoq02NDqYExnXIohXpNnjyabYnnDjU&e=
> >> Satish
> >> On Mon, 2 Apr 2018, Kong, Fande wrote:
> >> > On Mon, Apr 2, 2018 at 4:23 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> > > Does this 'standard test' use MPI_COMM_WORLD' to crate PETSc objects?
> >> > > If so - you could try changing to PETSC_COMM_WORLD
> >> > I do not think we are using PETSC_COMM_WORLD when creating PETSc
> >> objects.
> >> > Why we can not use MPI_COMM_WORLD?
> >> > Fande,
> >> > > Satish
> >> > > > Hi All,
> >> > > > I am trying to upgrade PETSc from 3.7.6 to 3.8.3 for MOOSE and its
> >> > > > applications. I have a error message for a standard test:
> >> > > > *preconditioners/pbp.lots_of_variables: MPI had an
> >> > > > errorpreconditioners/pbp.lots_of_variables:
> >> > > > Other MPI error, error stack:preconditioners/pbp.lots_of_variables:
> >> > > > PMPI_Comm_dup(177)..................: MPI_Comm_dup(comm=0x84000001,
> >> > > > new_comm=0x97d1068) failedpreconditioners/pbp.lots_of_variables:
> >> > > > PMPI_Comm_dup(162)..................:
> >> > > > MPIR_Comm_dup_impl(57)..............:
> >> > > > MPIR_Comm_copy(739).................:
> >> > > > MPIR_Get_contextid_sparse_group(614): Too many communicators (0/2048
> >> > > free
> >> > > > on this process; ignore_id=0)*
> >> > > > I did "git bisect', and the following commit introduces this issue:
> >> > > > *commit 49a781f5cee36db85e8d5b951eec29f10ac13593Author: Stefano
> >> Zampini
> >> > > > <stefano.zampini at gmail.com <stefano.zampini at gmail.com>>Date: Sat
> >> Nov 5
> >> > > > 20:15:19 2016 +0300 PCHYPRE: use internal Mat of type MatHYPRE
> >> > > > hpmat already stores two HYPRE vectors*
> >> > > > Before I debug line-by-line, anyone has a clue on this?
> >> > > > Fande,
