[petsc-users] DMForestTransferVec with -petscspace_order 0
yann JOBIC yann.jobic at univ-amu.fr
Mon Apr 2 09:42:29 CDT 2018
I'm using DMForestTransferVec, as in "dm/impls/forest/examples/tests/ex2.c".
I would like to use it with a space approximation order at zero
(-petscspace_order 0). However, in this case, it's not working (valgrind
output of ex2.c from forest test) :
==8604== Conditional jump or move depends on uninitialised value(s)
==8604==    at 0x47D74F: DMPlexVecGetClosure (plex.c:4035)
==8604==    by 0x557612: DMPlexLocatePoint_General_3D_Internal
(plexgeometry.c:153)
==8604==    by 0x559B85: DMPlexLocatePoint_Internal (plexgeometry.c:383)
==8604==    by 0x611EED: DMPlexComputeInjectorReferenceTree
(plextree.c:3247)
==8604==    by 0x6148DB: DMPlexReferenceTreeGetInjector (plextree.c:3454)
==8604==    by 0x61EAD8: DMPlexTransferVecTree_Inject (plextree.c:4319)
==8604==    by 0x620CC1: DMPlexTransferVecTree (plextree.c:4527)
==8604==    by 0x7F23D8: DMForestTransferVec_p8est (pforest.c:4239)
==8604==    by 0x429B48: DMForestTransferVec (forest.c:985)
==8604==    by 0x40BB8A: main (transf_test.c:136)
With the error message :
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
It's working fine in 2D (p4est). The problem arise in 3D (p8est).
Is it an expected behavior ? Am i doing something wrong ?
Thanks in advance,
Yann
