[petsc-users] Incorrect Eigenvalues when Setting KSP and PC types
    Hong
    hzhang at mcs.anl.gov
    Fri Sep 29 10:19:27 CDT 2017
Thanks for all the input. I can do following:
1) Move test to MatGetFactor()
    - If there is sufficient requests from user, we are able to add
Hermitian support to petsc sequential Cholesky.
2) Tests:
a) complex build && ftype==CHOLESKY:
  if (mat->hermitian) throw an "not supported" error
b) all builds:
  if (!sbaij && (CHOLESKY || ICC))
    if (!mat->symmetric)
      call  MatIsSymmetric(mat,0.0,&symm)
      if (!symm) throw an error
Hong
On Fri, Sep 29, 2017 at 9:55 AM, Greg Meyer <gregory.meyer at gmail.com> wrote:
> FYI my perspective as a user--something that really tricked me was that
> after setting the solver to Hermitian problem, the algorithm returned real
> eigenvalues so they seemed OK. When I turned off Hermitian as I was trying
> to debug, the eigenvalues were not at all just real, and thus it was clear
> that they were wrong. So I think the check at least when Hermitian is set
> is very important, since by construction real eigenvalues are returned.
> On Fri, Sep 29, 2017, 7:37 AM Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   1) The test is definitely in the wrong place. If we are testing and
>> erroring if using Cholesky and mat is not marked as symmetric or hermitian
>> the test should be in MatGetFactor() not in a particular implementation.
>>  2) It is a tough call if we should do this check or not.  There are good
>> arguments in both directions.
>>    One thing we could do is if the matrix is not marked as
>> symmetric/hermitian is we could just check at that point (but expensive) or
>> we could just check in debug mode.
>>  But I think we should require the user to set the flag (note for SBAIJ
>> the flag for symmetric (or hermitian? which one) should be automatically
>> set at creation).
>>   Hong can you move the test up to the MatGetFactor() level?
>>   Thanks
>>     Barry
>> > On Sep 28, 2017, at 11:35 PM, Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>> > Hong,
>> > I personally believe that commit https://bitbucket.org/petsc/
>> petsc/commits/966c94c9cf4fa13d455726ec36800a577e00b171 should be
>> reverted.
>> > I agree on the fact that when the user sets an option (the hermitian
>> one in this case) and that feature is not supported we should throw an
>> error (https://bitbucket.org/petsc/petsc/commits/
>> 8f21f52c465b775a76cda90fe9c51d0c742078c7) , but I don't like the fact
>> that the user is forced to set on option to use a feature that he already
>> requested (as in https://bitbucket.org/petsc/petsc/commits/
>> 966c94c9cf4fa13d455726ec36800a577e00b171).
>> > Barry, what do you think?
>> > 2017-09-29 5:28 GMT+03:00 Hong <hzhang at mcs.anl.gov>:
>> > Greg:
>> > Thanks so much for the detailed response. I am glad to know the reason
>> behind it--hopefully we eventually figure out why the solvers have this
>> behavior! Hong, I really appreciate you working on a patch to throw an
>> error in this case. It definitely bit me and some people using my code...
>> Hopefully it doesn't happen to anyone else! :)
>> > I added an error flag for using MUMPS Cholesky factorization on
>> Hermitian matrix. See branch hzhang/mumps-HermitianCholesky-errflag
>> > Jose,
>> > PETSc does not support Cholesky for Hermitian matrix.
>> > The linear solver table probably needs to be updated. I have tried
>> several Cholesky solvers. With mkl_pardiso I get an explicit error message
>> that it does not support Cholesky with complex scalars. The rest (PETSc,
>> MUMPS, CHOLMOD) give a wrong answer (without error message). The problem is
>> not related to your matrix, nor to shift-and-invert in SLEPc. I tried with
>> ex1.c under PETSC_DIR/src/ksp/ksp/examples/tutorials. The example works
>> in complex scalars, but the matrix is real. As soon as you add complex
>> entries Cholesky fails, for instance adding this:
>> >   ierr = MatSetValue(A,0,1,1.0+PETSC_i,INSERT_VALUES);CHKERRQ(ierr);
>> >   ierr = MatSetValue(A,1,0,1.0-PETSC_i,INSERT_VALUES);CHKERRQ(ierr);
>> > In this case, you must call
>> > MatSetOption(A,MAT_HERMITIAN,PETSC_TRUE);
>> > Then, petsc will throw an error for '-pc_type cholesky'.
>> > I don't know if it is a bug or that the algorithm cannot support
>> complex Hermitian matrices. Maybe Hong can confirm any of these. In the
>> latter case, I agree that all packages should give an error message, as
>> mkl_pardiso does.
>> > I also add an error flag for Cholesky/ICC if user does not set
>> > MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE) for aij matrix.
>> > See https://bitbucket.org/petsc/petsc/commits/
>> > Let me know if you have any comments about this fix.
>> > Hong
>> > > El 25 sept 2017, a las 7:17, Greg Meyer <gregory.meyer at gmail.com>
>> escribió:
>> > > Hi all,
>> > > Hong--looking at your link, there may be no special algorithm for
>> Hermitian matrices in MUMPS, but that doesn't mean it can't solve them like
>> it would any matrix. Furthermore it appears that Cholesky of complex
>> matrices is supported from this link: https://www.mcs.anl.gov/petsc/
>> documentation/linearsolvertable.html
>> > > So do you or anyone have any idea why I get incorrect eigenvalues?
>> > > Thanks,
>> > > Greg
>> > > On Thu, Sep 21, 2017 at 5:51 PM Greg Meyer <gregory.meyer at gmail.com>
>> wrote:
>> > > Ok, thanks. It seems that PETSc clearly should throw an error in this
>> case instead of just giving incorrect answers? I am surprised that it does
>> not throw an error...
>> > > On Thu, Sep 21, 2017 at 5:24 PM Hong <hzhang at mcs.anl.gov> wrote:
>> > > Greg :
>> > > Yes, they are Hermitian.
>> > > PETSc does not support  Cholesky factorization for Hermitian.
>> > > It seems mumps does not support Hermitian either
>> > > https://lists.mcs.anl.gov/mailman/htdig/petsc-users/
>> 2015-November/027541.html
>> > > Hong
>> > > On Thu, Sep 21, 2017 at 3:43 PM Hong <hzhang at mcs.anl.gov> wrote:
>> > > Greg:
>> > > OK, the difference is whether LU or Cholesky factorization is used.
>> But I would hope that neither one should give incorrect eigenvalues, and
>> when I run with the latter it does!
>> > > Are your matrices symmetric/Hermitian?
>> > > Hong
>> > > On Thu, Sep 21, 2017 at 2:05 PM Hong <hzhang at mcs.anl.gov> wrote:
>> > > Gregory :
>> > > Use '-eps_view' for both runs to check the algorithms being used.
>> > > Hong
>> > > Hi all,
>> > > I'm using shift-invert with EPS to solve for eigenvalues. I find that
>> if I do only
>> > >   ierr = EPSGetST(eps,&st);CHKERRQ(ierr);
>> > >   ierr = STSetType(st,STSINVERT);CHKERRQ(ierr);
>> > > in my code I get correct eigenvalues. But if I do
>> > >   ierr = STGetKSP(st,&ksp);CHKERRQ(ierr);
>> > >   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>> > >   ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
>> > >   ierr = PCSetType(pc,PCCHOLESKY);CHKERRQ(ierr);
>> > > the eigenvalues found by EPS are completely wrong! Somehow I thought
>> I was supposed to do the latter, from the examples etc, but I guess that
>> was not correct? I attach the full piece of test code and a test matrix.
>> > > Best,
>> > > Greg
>> > Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170929/67d432ec/attachment.html>
