[petsc-users] Using higher order ILU preconditioner
    Kong, Fande
    fande.kong at inl.gov
    Thu Sep 28 16:13:32 CDT 2017
Calling PCFactorSetMatOrderingType() (or command line option:
-pc_factor_mat_ordering_type) to use RCM or 1WD usually helps me a lot. My
application is based on highly-unstructured meshes.
Fande,
On Thu, Sep 28, 2017 at 2:53 PM, Rachit Prasad <rachitp at vt.edu> wrote:
> Hi,
> I am trying to solve a highly ill-conditioned matrix and am unable to get
> convergence when using ILU(0) or Jacobi and SOR preconditioners. I tried to
> implement a higher order ILU by increasing the level of fill-in to 1 by
> calling
> call PCFactorSetLevels(pc,1,ierr)
> However, when I do that I get the following memory error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated -2147483648 Memory used by process
> -2147483648
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
> [0]PETSC ERROR: Memory requested 18446744071863943168!
> While I do understand that increasing the level of fill-in will require
> higher memory, the memory requested seems to be way too high. Am I
> implementing the higher order ILU correctly? Is there any other subroutine
> which I need to call?
> Regards,
> Rachit
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170928/f6494794/attachment-0001.html>
