[petsc-users] How to copy vectors to/from petsc?
Karl Rupp
rupp at iue.tuwien.ac.at
Thu Sep 28 15:46:45 CDT 2017
Hi Klaus,
there are several options, e.g.:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecCreateSeqWithArray.html
(sequential)
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecSetValues.html
(use with multiple MPI ranks if you cannot easily determine the local parts)
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArray.html
(get a pointer to the data and assign values yourself)
Best regards,
Karli
On 09/28/2017 02:43 PM, Klaus Burkart wrote:
> Hello,
> I want to solve a physics problem with support of petsc i.e. solve the
> linear system using petsc. So far I have been using another linear
> algebra library. I am using c++. Now I am struggling to load the rhs
> vector/array from the physics application to petsc and copying the
> result x back to the physics application. I found information about how
> to load data from binaries or from files but both is not the case here.
> The computation will take place on a multi core CPU using MPI.
> This is how far I am and includes my questions:
> #include <petscvec.h>
> // vector x, rhs size n; "matrix" is the matrix from the physics application
> PetscMPIInt n = matrix.diag().size();
> Vec rhs; // Question 1: How to set the value type to double?
> VecSetSizes(rhs, n, PETSC_DECIDE); // Question 2: What is "global size"?
> Vec x;
> VecSetSizes(x, n, PETSC_DECIDE);
> // Question 3:
> // How to load petsc rhs vector with data from vector (= pointer array)
> named rhs_source?
> // Current load/copy syntax is: fast_copy(rhs_source.begin(),
> rhs_source.end(), rhs.begin());
> // Question 4:
> // How to export petsc result vector x i.e. load the result x into array
> named x_result?
> // Current load/copy syntax is: fast_copy(x.begin(), x.end(),
> x_result.begin());
> // destroy petsc vectors
> VecDestroy(&rhs);
> VecDestroy(&x);
> PetscFinalize();
> // What's the best way to copy rhs to petsc and to copy the result x
> back to the physics application?
