[petsc-users] Incorrect Eigenvalues when Setting KSP and PC types
Greg Meyer gregory.meyer at gmail.com
Thu Sep 21 16:11:28 CDT 2017
OK, the difference is whether LU or Cholesky factorization is used. But I
would hope that neither one should give incorrect eigenvalues, and when I
run with the latter it does!
On Thu, Sep 21, 2017 at 2:05 PM Hong <hzhang at mcs.anl.gov> wrote:
> Gregory :
> Use '-eps_view' for both runs to check the algorithms being used.
> Hong
> Hi all,
>> I'm using shift-invert with EPS to solve for eigenvalues. I find that if
>> I do only
>>   ierr = EPSGetST(eps,&st);CHKERRQ(ierr);
>>   ierr = STSetType(st,STSINVERT);CHKERRQ(ierr);
>> in my code I get correct eigenvalues. But if I do
>>   ierr = STGetKSP(st,&ksp);CHKERRQ(ierr);
>>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>   ierr = KSPSetType(ksp,KSPPREONLY);CHKERRQ(ierr);
>>   ierr = PCSetType(pc,PCCHOLESKY);CHKERRQ(ierr);
>> the eigenvalues found by EPS are completely wrong! Somehow I thought I
>> was supposed to do the latter, from the examples etc, but I guess that was
>> not correct? I attach the full piece of test code and a test matrix.
>> Best,
>> Greg
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170921/88588348/attachment.html>
