[petsc-users] PETSc KSPBCGSL with HYPRE boomeramg preconditioner ksp_monitor in poisson function
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Sep 17 00:12:28 CDT 2017
  Should work in the code also. Call KSPSetTolerances() and then call KSPView() to see what it is set to
> On Sep 17, 2017, at 12:11 AM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> Yes. but only works via command line option.before was set up in the code.
> On Sun, Sep 17, 2017 at 12:44 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 16, 2017, at 11:33 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> > thanks.
> > Yes. KSPSetTolerances is used.
> > tolerance is set to be 1.e-14
>    There is the rtol and atol are you sure you set the atol to 1e-14?
> > I was thinking if there is a debug option I could use from PETSc to get some insight?  GDB was used.
>    You can use the command line option -start_in_debugger
> > On Sun, Sep 17, 2017 at 12:25 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Sep 16, 2017, at 10:39 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> > > hi,
> > > I am using KSPBCGSL method and HYPRE boomeramg precondtioner passed into KSPsolve for poisson equation as part of incompressible NS.
> > > I have two questions
> > > Q1 is number of iterations for the same solver. max_iter = 20 for the same poisson function
> > > KSPGetIterationNumber() is used to set up max_iter = 20
> >   What do you mean, KSPGetIterationNumber() tells you the current number of iterations. You cannot use it to set the maximum number of iterations. Use KSPSetTolerances() or -ksp_max_it <its> to set the number
> > >  0 KSP Residual norm 4.512245447770e-04
> > >   2 KSP Residual norm 6.396709069731e-07
> > >   4 KSP Residual norm 1.757784220489e-10
> > >   6 KSP Residual norm 1.501464709144e-14
> > >   8 KSP Residual norm 1.376381429122e-18
> > >  10 KSP Residual norm 1.072650548945e-19
> > > In poisson_func(): num_iter = 10, rel_residual = 1.072651e-19
> > > and the very same function at the next time step gives: remind you guys max_iter = 20. I assume the number of iterations should stop at num_iter = 2.
> >    Why would it stop at num_iter 2. The number of iterations allowed is the same for each solve, it does not accumulate over all solves.
> > >  but the solver seems to keep iterating util hitting the max_iter.
> > >  0 KSP Residual norm 5.107005838093e-16
> > >   2 KSP Residual norm 3.353634821198e-20
> > >   4 KSP Residual norm 1.835096039266e-23
> > >   6 KSP Residual norm 1.645496102409e-23
> > >   8 KSP Residual norm 1.645496099837e-23
> > >  10 KSP Residual norm 1.645496099836e-23
> > >  12 KSP Residual norm 1.645496099530e-23
> > >  14 KSP Residual norm 1.645496034473e-23
> > >  16 KSP Residual norm 1.645461130961e-23
> > >  18 KSP Residual norm 1.645460451075e-23
> > > In poisson_func(): num_iter = 18, rel_residual = 1.645460e-23
> >    But the way it is almost never realistic to try to get residual norms to be this small. You might consider using something like -ksp_atol 1.e-16 or something
> > > Q2 is: it seems HYPRE with KSPsolve works with coarse mesh but when I double the mesh size. the solve halted indefinitely. ksp_monitor didn't produce any results.
> > > is there a way to understand what's happening?
> >    You could run in the debugger and use control c to interrupt the code when it is "hanging" and type bt to see the stack trace for the hanging.
> > > Hao Zhang
> > > Dept. of Applid Mathematics and Statistics,
> > > Stony Brook University,
> > > Stony Brook, New York, 11790
> > Hao Zhang
> Hao Zhang
