[petsc-users] MatMult for block matrix
    Xiangdong
    epscodes at gmail.com
    Mon Sep 11 15:22:15 CDT 2017
Hello everyone,
I have a block matrix B and vec x, and need to compute y=Bx many times. I
found that each time before I call MatMult(B,x,y,ierr), I need to call
VecSet(y,0.0,ierr). Otherwise, the result y is not correct (sometimes, but
not always). I have this puzzle even if x and y are created by
MatCreateVecs. I am using petsc 3.7.6 fortran api.
If I create the same B in non-block format, it works fine without the extra
vecset. It seems that I cannot reuse the allocation of vec y for block
matrix without a reset.
Is there any clue to explain this behavior?
Thank you.
Best,
Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170911/4f199077/attachment.html>
