[petsc-users] Elemental support is outdated?
Karl Rupp rupp at iue.tuwien.ac.at
Tue Sep 5 08:10:05 CDT 2017
Hi Denis,
> I just tried compiling PETSc with Elemental 0.87.7 and got compiler
> errors (see below) which suggests that the interface in PETSc is outdated.
> Looking at the “elemental.py”
> https://bitbucket.org/petsc/petsc/src/90564b43f6b05485163c147b464b5d6d28cde3ef/config/BuildSystem/config/packages/elemental.py?at=hongzh%2Fswe&fileviewer=file-view-default
> <https://bitbucket.org/petsc/petsc/src/90564b43f6b05485163c147b464b5d6d28cde3ef/config/BuildSystem/config/packages/elemental.py?at=hongzh/swe&fileviewer=file-view-default>
> I see that the suggested Elemental's commit is from Nov 2015
> https://github.com/elemental/Elemental/commit/e81005dc3af9b331d43e16e4d221e889378e2c49
> whereas 0.87.7 is from Feb. 2017; There are 8 releases in between.
the master branch of PETSc uses version 0.87.4 from November 2016:
https://bitbucket.org/petsc/petsc/src/743f4829774bac6ed514af01aa0f24f18a42afc0/config/BuildSystem/config/packages/elemental.py?at=master&fileviewer=file-view-default
Best regards,
Karli
