[petsc-users] preconditioning matrix-free newton-krylov
Mark Adams
mfadams at lbl.gov
Tue Oct 31 07:48:56 CDT 2017
On Mon, Oct 30, 2017 at 7:38 PM, Mark Lohry <mlohry at gmail.com> wrote:
> Sparsity pattern binary AIJ gzipped here, should have 100^2 blocks of all
> 1's indicating the non-zero positions:
> https://github.com/mlohry/petsc_miscellany/blob/master/
> jacobian_sparsity.dat.gz
View Raw
<https://github.com/mlohry/petsc_miscellany/blob/master/jacobian_sparsity.dat.gz?raw=true>
(Sorry about that, but we can’t show files that are this big right now.)
> Using 32 processes on 2x16-core AMD 6274, timing for MatColoringApply is
> ~877 seconds/~15 minutes for MATCOLORINGJP, ~30 seconds for
> MATCOLORINGGREEDY. Let me know if you can't reproduce this and I'll put
> together a MWE.
> MATCOLORINGID and MATCOLORINGSL both seem to work in 9 seconds, though
> documentation says they're both serial?
> Regarding BAIJ, neither JP nor GREEDY work, throwing "Matrix must be AIJ
> for greedy coloring", so am I out of luck for using MPIBAIJ?
> On Mon, Oct 30, 2017 at 3:28 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> > On Oct 30, 2017, at 2:23 PM, Mark Lohry <mlohry at gmail.com> wrote:
>> > Hmm, are those blocks dense? If so you could benefit enormously from
>> using BAIJ format.
>> > Yes they're dense blocks. Usually coupled compressible 3D NS with DG
>> elements, 5 equations x order (N+1)*(N+2)*(N+3)/3 block size. So block
>> sizes of 50^2 to 175^2 are typical. I'll try BAIJ; I initially set it up
>> with AIJ as it seemed better supported in parallel on the linear solver
>> table, but I suppose these are rather large blocks... still surprising
>> performance as this was overall a pretty small system (1,536
>> elements/diagonal 100^2 blocks).
>> Something is really wrong to get those huge times.
>> > Could you run with -ksp_view_mat binary and send the resulting file
>> called binaryoutput and we can run the coloring codes local to performance
>> debug.
>> > Will send this evening.
>> Thanks but send for the AIJ case, not BAIJ
>> > On Mon, Oct 30, 2017 at 3:02 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> > > On Oct 30, 2017, at 1:58 PM, Mark Lohry <mlohry at gmail.com> wrote:
>> > > Hmm, metis doesn't really have anything to do with the sparsity of
>> the Jacobian does it?
>> > > No, I just mean I'm doing initial partitioning and parallel
>> communication for the residual evaluations independently of petsc, and then
>> doing a 1-to-1 mapping to the petsc solution vector. Along with manually
>> setting the non-zero structure of the MPIAIJ system as in the user manual.
>> I don't think there's anything wrong with the system structure as it gives
>> the same correct answer as the un-preconditioned matrix-free approach.
>> > > The exact system those MatColoring times came from has size (100x100)
>> blocks on the diagonals corresponding to the tetrahedral cells, with those
>> having 4 neighbor blocks on the same row (or fewer for elements on
>> boundaries.)
>> using BAIJ format.
>> > Matt,
>> > Sounds like performance bugs for the parallel coloring apply
>> algorithms with big "diagonal blocks"
>> > Mark,
>> file called binaryoutput and we can run the coloring codes local to
>> performance debug.
>> > Barry
>> > > On Mon, Oct 30, 2017 at 1:55 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> > > > On Oct 30, 2017, at 12:39 PM, Mark Lohry <mlohry at gmail.com> wrote:
>> > > > > 3) Are there any hooks analogous to KSPSetPreSolve/PostSolve for
>> the FD computation of the jacobians, or for the computation of the
>> preconditioner? I'd like to get a handle on the relative costs of these.
>> > > > No, do you just want the time? You can get that from the logging;
>> for example -log_view
>> > > > Yes, was just thinking in regards to your suggestion of recomputing
>> when the number of linear iterations gets too high; I assume it's the ratio
>> of preconditioner cost vs linear solver cost at runtime that's the metric
>> of interest, and not the absolute value of either. But I'll cross that
>> bridge when I come to it.
>> > > > When I had asked, I was looking to see where a long pause was
>> happening thinking it was the FD jacobian; turned out to be before that in
>> MatColoringApply which seems surprisingly expensive. MATCOLORINGJP took ~15
>> minutes on 32 cores on a small 153,000^2 system, with MATCOLORINGGREEDY
>> taking 30 seconds. Any guidance there, or is this expected? I'm not using
>> DM, just manually entering the sparsity resulting from a metis
>> decomposition of a tetrahedral mesh.
>> > > Matt,
>> > > These times are huge. What is going on?
>> > > Barry
>> > > > Thanks for the info on the lag logic, I'll play with the TS
>> pre/post calls for the time-accurate problems and only use LagJacobian.
>> > > > On Mon, Oct 30, 2017 at 11:29 AM, Smith, Barry F. <
>> bsmith at mcs.anl.gov> wrote:
>> > > > > On Oct 29, 2017, at 11:50 AM, Mark Lohry <mlohry at gmail.com>
>> wrote:
>> > > > > Thanks again Barry, I've got the preconditioners hooked up with
>> -snes_mf_operator and at least AMG looks to be working great on a high
>> order unstructured DG problem.
>> > > > > Couple questions on the SNESSetLagJacobian +
>> SNESSetLagPreconditioner code flow:
>> > > > > 1) With -snes_mf_operator, and given SNESSetLagJacobian(snes, 1)
>> (default) and SNESSetLagPreconditioner(snes, 2), after the first KSP solve
>> in a newton iteration, will it do the finite different jacobian
>> calculation? Or will the Jacobian only be computed when the preconditioner
>> lag setting demands it on the 3rd newton step? I suspect it's the latter
>> based on where I see the code pause.
>> > > > SNES with -snes_mf_operator will ALWAYS use the matrix-free
>> finite difference f(x+h) - f(x) to apply the matrix vector product.
>> > > > The LagJacobian and LagPreconditioner are not coordinated. The
>> first determines how often the Jacobian used for preconditioning is
>> recomputed and the second determines how often the preconditioner is
>> recomputed.
>> > > > If you are using -snes_mf_operator then it never makes sense to
>> have lagJacobian < lagPreconditioner since it would recompute the Jacobian
>> but not actually use it. It also makes no sense for lagPreconditioner <
>> lagJacobian because you'd be recomputing the preconditioner on the same
>> Jacobian.
>> > > > But actually if you don't change the Jacobian used in building the
>> preconditioner then when it tries to recompute the preconditioner it
>> determines the matrix has not changed so skips rebuilding the
>> preconditioner. So when using -snes_mf_operator there is really no reason
>> generally to set the preconditioner lag.
>> > > > > 2) How do implicit TS and SNESSetLagPreconditioner/Persists
>> interact? Does the counter since-last-preconditioner-compute reset with
>> time steps, or does that lag counter just increment with every SNES solve
>> regardless of how many nonlinear solves might have happened in a given
>> timestep? Say lag preconditioner is 2, and a time stepper uses 3, 2, and 3
>> nonlinear solves on 3 steps, is the flow
>> > > > > (time step 1)->(update preconditioner)->(snes solve)->(snes
>> solve)->(update preconditioner)->(snes solve)
>> > > > > (time step 2)->(snes solve)->(update preconditioner)->(snes solve)
>> > > > > (time step 3)->(snes solve)->(update preconditioner)->(snes
>> solve)->(snes solve)
>> > > > > or
>> > > > > (time step 2)->(update preconditioner)->(snes solve)->(snes solve)
>> > > > > (time step 3)->(update preconditioner)->(snes solve)->(snes
>> > > > > I think for implicit time stepping I'd probably want the
>> preconditioner to be recomputed just once at the beginning of each time
>> step, or some multiple of that. Does that sound reasonable?
>> > > > Yes, what you want to do is completely reasonable.
>> > > > You can use SNESSetLagJacobian() and
>> SNESSetLagJacobianPersists() in combination to have the Jacobian
>> recomputed ever fixed number of times; if you set the persists flag and set
>> LagJacobian to 10 it will recompute the Jacobian used in the preconditioner
>> every 10th time a new Jacobian is needed.
>> > > > If you want to compute the new Jacobian used to build the
>> preconditioner once at the beginning of each new TS stage you can set
>> SNESSetLagJacobian() to negative -2 in the TS prestage call. There are
>> possibly other tricks you can do by setting the two flags at different
>> locations.
>> > > > An alternative to hardwiring how often the Jacobian used to
>> build the preconditioner is rebuilt is to rebuild based on when the
>> preconditioner starts "working less well". Here you could put an additional
>> KSPMonitor or SNESMonitor that detects if the number of linear iterations
>> is above a certain amount and then sets the recompute Jacobian flag to -2
>> so that for the next solve it recreates the Jacobian used in building the
>> preconditioner.
>> > > > > Best,
>> > > > > Mark
>> > > > > On Sat, Sep 23, 2017 at 3:28 PM, Mark Lohry <mlohry at gmail.com>
>> wrote:
>> > > > > Great, thanks Barry.
>> > > > > On Sat, Sep 23, 2017 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > > > > On Sep 23, 2017, at 12:48 PM, Mark W. Lohry <
>> mlohry at princeton.edu> wrote:
>> > > > > > I'm currently using JFNK in an application where I don't have a
>> hand-coded jacobian, and it's working well enough but as expected the
>> scaling isn't great.
>> > > > > > What is the general process for using PC with
>> MatMFFDComputeJacobian? Does it make sense to occasionally have petsc
>> re-compute the jacobian via finite differences, and then recompute the
>> preconditioner? Any that just need the sparsity structure?
>> > > > > Mark
>> > > > > Yes, this is a common approach. SNESSetLagJacobian
>> -snes_lag_jacobian
>> > > > > The normal approach in SNES to use matrix-free for the
>> operator and use finite differences to compute an approximate Jacobian used
>> to construct preconditioners is to to create a sparse matrix with the
>> sparsity of the approximate Jacobian (yes you need a way to figure out the
>> sparsity, if you use DMDA it will figure out the sparsity for you). Then
>> you use
>> > > > > SNESSetJacobian(snes,J,J, SNESComputeJacobianDefaultColor,
>> NULL);
>> > > > > and use the options database option -snes_mf_operator
>> > > > > > Are there any PCs that don't work in the matrix-free context?
>> > > > > If you do the above you can use almost all the PC since you are
>> providing an explicit matrix from which to build the preconditioner
>> > > > > > Are there any example codes I overlooked?
>> > > > > > Last but not least... can the Boomer-AMG preconditioner work
>> with JFNK? To really show my ignorance of AMG, can it actually be written
>> as a matrix P^-1(Ax-b)=0, , or is it just a linear operator?
>> > > > > Again, if you provide an approximate Jacobian like above you
>> can use it with BoomerAMG, if you provide NO explicit matrix you cannot use
>> BoomerAMG or almost any other preconditioner.
>> > > > > Barry
>> > > > > > Thanks,
>> > > > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171031/ec1f6ec0/attachment-0001.html>
