[petsc-users] unsorted local columns in 3.8?
    Randy Michael Churchill
    rchurchi at pppl.gov
    Mon Oct 30 23:58:59 CDT 2017
I'm running a Fortran code that was just changed over to using petsc 3.8
(previously petsc 3.7.6). An error was thrown during a KSPSetUp() call. The
error is "unsorted iscol_local is not implemented yet" (see full error
below). I tried to trace down the difference in the source files, but where
the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist()) doesn't seem to
have existed in v3.7.6, so I'm unsure how to compare. It seems the error is
that the order of the columns locally are unsorted, though I don't think I
specify a column order in the creation of the matrix:
     call MatCreate(this%comm,AA,ierr)
     call MatSetSizes(AA,npetscloc,npetscloc,nreal,nreal,ierr)
     call MatSetType(AA,MATAIJ,ierr)
     call MatSetup(AA,ierr)
     call MatGetOwnershipRange(AA,low,high,ierr)
     allocate(d_nnz(npetscloc),o_nnz(npetscloc))
     call
getNNZ(grid,npetscloc,low,high,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
     call MatSeqAIJSetPreallocation(AA,PETSC_NULL_INTEGER,d_nnz,ierr)
     call
MatMPIAIJSetPreallocation(AA,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
     deallocate(d_nnz,o_nnz)
     call MatSetOption(AA,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE,ierr)
     call MatSetOption(AA,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE,ierr)
[62]PETSC ERROR: --------------------- Error Message
[62]PETSC ERROR: No support for this operation for this object type
[62]PETSC ERROR: unsorted iscol_local is not implemented yet
[62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[62]PETSC ERROR: Petsc Release Version 3.8.0, unknown[62]PETSC ERROR: #1
MatCreateSubMatrix_MPIAIJ_SameRowDist() line 3418 in
/global/u1/r/rchurchi/petsc/3.8.0/src/mat/impls/aij/mpi/mpiaij.c
[62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line 3247 in
[62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
/global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
[62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
/global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/impls/gamg/gamg.c
[62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
[62]PETSC ERROR: #6 PCSetUp() line 924 in
/global/u1/r/rchurchi/petsc/3.8.0/src/ksp/pc/interface/precon.c
[62]PETSC ERROR: #7 KSPSetUp() line 378 in
/global/u1/r/rchurchi/petsc/3.8.0/src/ksp/ksp/interface/itfunc.c
R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/aa470197/attachment.html>
