[petsc-users] A number of questions about DMDA with SNES and Quasi-Newton methods
zakaryah . zakaryah at gmail.com
Mon Oct 30 21:32:26 CDT 2017
You were right, of course.  I fixed the problem with the function
evaluation and the code seems to be working now, at least on small test
problems.
Is there a way to setup preallocation of the Jacobian matrix, with the
entire first row and column non-zero?  I set the preallocation error flag
to false, as you suggested several messages ago, and this was great for
testing, but now the first assembly of the Jacobian is terribly slow due to
allocating on the fly.
Thanks!
On Sun, Oct 29, 2017 at 7:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Oct 29, 2017 at 5:15 PM, zakaryah . <zakaryah at gmail.com> wrote:
>> Good point, Jed - I feel silly for missing this.
>> Can I use -snes_type test -snes_test_display with the Jacobian generated
>> from a DMComposite?  When I try, it looks like the finite difference
>> Jacobian is missing all the elements in the row corresponding to the
>> redundant variable, except the diagonal, which is wrong.
> Well, this leads me to believe the residual function is wrong. What the FD
> Jacobian does is just call the residual
> twice with different solutions. Thus if the residual is different when you
> perturb the redundant variable, you should
> have Jacobian entries there.
>> I'm not sure my code for setting the submatrices is correct.  I'm
>> especially uncertain about the submatrix J_bh, where b is the redundant
>> variable and h is the displacements.  This submatrix has only one row, and
>> all of its columns are non-zero.  Can its values be set with
>> MatSetValuesLocal, on all processors?
>> Is there an example of manually coding a Jacobian with a DMRedundant?
> I don't think so. We welcome contributions.
>   Matt
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/6b063730/attachment.html>
