[petsc-users] preconditioning matrix-free newton-krylov
Mark Lohry mlohry at gmail.com
Mon Oct 30 13:58:50 CDT 2017
> Hmm, metis doesn't really have anything to do with the sparsity of the
> Jacobian does it?
No, I just mean I'm doing initial partitioning and parallel communication
for the residual evaluations independently of petsc, and then doing a
1-to-1 mapping to the petsc solution vector. Along with manually setting
the non-zero structure of the MPIAIJ system as in the user manual. I don't
think there's anything wrong with the system structure as it gives the same
correct answer as the un-preconditioned matrix-free approach.
The exact system those MatColoring times came from has size (100x100)
blocks on the diagonals corresponding to the tetrahedral cells, with those
having 4 neighbor blocks on the same row (or fewer for elements on
boundaries.)
On Mon, Oct 30, 2017 at 1:55 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Oct 30, 2017, at 12:39 PM, Mark Lohry <mlohry at gmail.com> wrote:
> > > 3) Are there any hooks analogous to KSPSetPreSolve/PostSolve for the
> FD computation of the jacobians, or for the computation of the
> preconditioner? I'd like to get a handle on the relative costs of these.
> >   No, do you just want the time? You can get that from the logging; for
> example -log_view
> > Yes, was just thinking in regards to your suggestion of recomputing when
> the number of linear iterations gets too high; I assume it's the ratio of
> preconditioner cost vs linear solver cost at runtime that's the metric of
> interest, and not the absolute value of either. But I'll cross that bridge
> when I come to it.
> > When I had asked, I was looking to see where a long pause was happening
> thinking it was the FD jacobian; turned out to be before that in
> MatColoringApply which seems surprisingly expensive. MATCOLORINGJP took ~15
> minutes on 32 cores on a small 153,000^2 system, with MATCOLORINGGREEDY
> taking 30 seconds. Any guidance there, or is this expected? I'm not using
> DM, just manually entering the sparsity resulting from a metis
> decomposition of a tetrahedral mesh.
> Jacobian does it?
>   Matt,
>    These times are huge. What is going on?
>    Barry
> > Thanks for the info on the lag logic, I'll play with the TS pre/post
> calls for the time-accurate problems and only use LagJacobian.
> > On Mon, Oct 30, 2017 at 11:29 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On Oct 29, 2017, at 11:50 AM, Mark Lohry <mlohry at gmail.com> wrote:
> > > Thanks again Barry, I've got the preconditioners hooked up with
> -snes_mf_operator and at least AMG looks to be working great on a high
> order unstructured DG problem.
> > > Couple questions on the SNESSetLagJacobian + SNESSetLagPreconditioner
> code flow:
> > > 1) With -snes_mf_operator, and given SNESSetLagJacobian(snes, 1)
> (default)  and SNESSetLagPreconditioner(snes, 2), after the first KSP solve
> in a newton iteration, will it do the finite different jacobian
> calculation? Or will the Jacobian only be computed when the preconditioner
> lag setting demands it on the 3rd newton step? I suspect it's the latter
> based on where I see the code pause.
> >    SNES with -snes_mf_operator will ALWAYS use the matrix-free finite
> difference f(x+h) - f(x) to apply the matrix vector product.
> >    The LagJacobian and LagPreconditioner are not coordinated. The first
> determines how often the Jacobian used for preconditioning is recomputed
> and the second determines how often the preconditioner is recomputed.
> >    If you are using -snes_mf_operator then it never makes sense to have
> lagJacobian < lagPreconditioner since it would recompute the Jacobian but
> not actually use it. It also makes no sense for lagPreconditioner <
> lagJacobian because you'd be recomputing the preconditioner on the same
> Jacobian.
> > But actually if you don't change the Jacobian used in building the
> preconditioner then when it tries to recompute the preconditioner it
> determines the matrix has not changed so skips rebuilding the
> preconditioner. So when using -snes_mf_operator there is really no reason
> generally to set the preconditioner lag.
> > > 2) How do implicit TS and SNESSetLagPreconditioner/Persists interact?
> Does the counter since-last-preconditioner-compute reset with time steps,
> or does that lag counter just increment with every SNES solve regardless of
> how many nonlinear solves might have happened in a given timestep? Say lag
> preconditioner is 2, and a time stepper uses 3, 2, and 3 nonlinear solves
> on 3 steps, is the flow
> > > (time step 1)->(update preconditioner)->(snes solve)->(snes
> solve)->(update preconditioner)->(snes solve)
> > > (time step 2)->(snes solve)->(update preconditioner)->(snes solve)
> > > (time step 3)->(snes solve)->(update preconditioner)->(snes
> solve)->(snes solve)
> > > or
> > > (time step 2)->(update preconditioner)->(snes solve)->(snes solve)
> > > (time step 3)->(update preconditioner)->(snes solve)->(snes
> > > I think for implicit time stepping I'd probably want the
> preconditioner to be recomputed just once at the beginning of each time
> step, or some multiple of that. Does that sound reasonable?
> >   Yes, what you want to do is completely reasonable.
> >   You can use SNESSetLagJacobian() and   SNESSetLagJacobianPersists() in
> combination to have the Jacobian recomputed ever fixed number of times; if
> you set the persists flag and set LagJacobian to 10 it will recompute the
> Jacobian used in the preconditioner every 10th time a new Jacobian is
> needed.
> >    If you want to compute the new Jacobian used to build the
> preconditioner once at the beginning of each new TS stage you can set
> SNESSetLagJacobian() to negative -2 in the TS prestage call. There are
> possibly other tricks you can do by setting the two flags at different
> locations.
> >    An alternative to hardwiring how often the Jacobian used to build the
> preconditioner is rebuilt is to rebuild based on when the preconditioner
> starts "working less well". Here you could put an additional KSPMonitor or
> SNESMonitor that detects if the number of linear iterations is above a
> certain amount and then sets the recompute Jacobian flag to -2 so that for
> the next solve it recreates the Jacobian used in building the
> preconditioner.
> example -log_view
> > > Best,
> > > Mark
> > > On Sat, Sep 23, 2017 at 3:28 PM, Mark Lohry <mlohry at gmail.com> wrote:
> > > Great, thanks Barry.
> > > On Sat, Sep 23, 2017 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Sep 23, 2017, at 12:48 PM, Mark W. Lohry <mlohry at princeton.edu>
> wrote:
> > > > I'm currently using JFNK in an application where I don't have a
> hand-coded jacobian, and it's working well enough but as expected the
> scaling isn't great.
> > > > What is the general process for using PC with
> MatMFFDComputeJacobian? Does it make sense to occasionally have petsc
> re-compute the jacobian via finite differences, and then recompute the
> preconditioner? Any that just need the sparsity structure?
> > >  Mark
> > >    Yes, this is a common approach. SNESSetLagJacobian
> -snes_lag_jacobian
> > >     The normal approach in SNES to use matrix-free for the operator
> and use finite differences to compute an approximate Jacobian used to
> construct preconditioners is to to create a sparse matrix with the sparsity
> of the approximate Jacobian (yes you need a way to figure out the sparsity,
> if you use DMDA it will figure out the sparsity for you). Then you use
> > >    SNESSetJacobian(snes,J,J, SNESComputeJacobianDefaultColor, NULL);
> > > and use the options database option -snes_mf_operator
> > > > Are there any PCs that don't work in the matrix-free context?
> > >   If you do the above you can use almost all the PC since you are
> providing an explicit matrix from which to build the preconditioner
> > > > Are there any example codes I overlooked?
> > > > Last but not least... can the Boomer-AMG preconditioner work with
> JFNK? To really show my ignorance of AMG, can it actually be written as a
> matrix P^-1(Ax-b)=0, , or is it just a linear operator?
> > >   Again, if you provide an approximate Jacobian like above you can use
> it with BoomerAMG, if you provide NO explicit matrix you cannot use
> BoomerAMG or almost any other preconditioner.
> > >    Barry
> > > > Thanks,
> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171030/3b3bae75/attachment.html>
