[petsc-users] HYPRE hanging or slow? from observation
Sat Oct 21 16:25:02 CDT 2017
On Sat, Oct 21, 2017 at 5:21 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>   ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>   ierr = VecAssemblyBegin(x);
>   ierr = VecAssemblyEnd(x);
This is probably unnecessary
>   ierr = VecAssemblyBegin(b);
>   ierr = VecAssemblyEnd(b);
> ierr = MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,PETSC_NULL,
> &nullsp);
>         ierr = MatSetNullSpace(A,nullsp); // Petsc-3.8
Is your rhs consistent with this nullspace?
>         // KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
>         KSPSetOperators(ksp,A,A);
> KSPSetType(ksp,KSPBCGS);
>         KSPSetComputeSingularValues(ksp, PETSC_TRUE);
> #if defined(__HYPRE__)
> KSPGetPC(ksp, &pc);
> PCSetType(pc, PCHYPRE);
>     PCHYPRESetType(pc,"boomeramg");
This is terribly unnecessary. You just use
   -pc_type hypre -pc_hypre_type boomeramg
or
  -pc_type gamg
> #else
> KSPSetType(ksp,KSPBCGSL);
> KSPBCGSLSetEll(ksp,2);
> #endif /* defined(__HYPRE__) */
>         KSPSetFromOptions(ksp);
>         KSPSetUp(ksp);
>         ierr = KSPSolve(ksp,b,x);
> command line
You did not provide any of what I asked for the in the eprevious mail.
   Matt
> On Sat, Oct 21, 2017 at 5:16 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sat, Oct 21, 2017 at 5:04 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
>>> hi,
>>> I implemented HYPRE preconditioner for my study due to the fact that
>>> without preconditioner, PETSc solver will take thousands of iterations to
>>> converge for fine grid simulation.
>>> with HYPRE, depending on the parallel partition, it will take HYPRE
>>> forever to do anything. observation of output file is that the simulation
>>> is hanging with no output.
>>> Any idea what happened? will post snippet of code.
>> 1) For any question about convergence, we need to see the output of
>>   -ksp_view_pre -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
>> 2) Hypre has many preconditioners, which one are you talking about
>> 3) PETSc has some preconditioners in common with Hypre, like AMG
>>   Thanks,
>>      Matt
>>> Hao Zhang
>>> Dept. of Applid Mathematics and Statistics,
>>> Stony Brook University,
>>> Stony Brook, New York, 11790
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> Hao Zhang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171021/c9bcd0a0/attachment-0001.html>
