[petsc-users] Distributing already assembled stiffness matrix
    Jaganathan, Srikrishna
    srikrishna.jaganathan at fau.de
    Sat Oct 21 05:18:10 CDT 2017
On 2017-10-21 00:42, Barry Smith wrote:
>> On Oct 18, 2017, at 4:14 AM, Jaganathan, Srikrishna
>> <srikrishna.jaganathan at fau.de> wrote:
>> Hello,
>> I have been trying to distribute a already existing stiffness matrix
>> in my FEM code to petsc parallel matrix object , but I am unable to
>> find any documentation regarding it.
>    I really really don't recommend doing this. If you code is
> sequential and you want to speed up the linear solves then use some
> linear solver library that uses OpenMP for parallelism and be done
> with it. Mix sequential finite element assembly with MPI parallel
> solvers is just not worth going within 100 meters of.
>    Barry
Yeah, it makes sense to not mix both. We are trying to have an MPI
parallel Finite element assembly, but it is a quite big overhaul of the
existing code so as a first step we are trying to incorporate the solver
and then proceed from that.
>> It was quite straightforward to create a sequential petsc matrix
>> object and everything was working as intended.I have read some of the
>> user comments in the mailing lists regarding similar situation and
>> most of the times the solution suggested is to create stiffness matrix
>> from the the mesh in distributed format. Since its a little difficult
>> in my case to pass the mesh data in the code , is there anyway to
>> distribute already existing stiffness matrix ?
>> Thanks and Regards
>> Srikrishna Jaganathan
