[petsc-users] GAMG advice
Fri Oct 20 22:10:02 CDT 2017
  David,
   GAMG picks the number of levels based on how the coarsening process etc proceeds. You cannot hardwire it to a particular value. You can run with -info to get more info potentially on the decisions GAMG is making.
  Barry
> On Oct 20, 2017, at 2:06 PM, David Nolte <dnolte at dim.uchile.cl> wrote:
> PS: I didn't realize at first, it looks as if the -pc_mg_levels 3 option
> was not taken into account:
> type: gamg
>     MG: type is MULTIPLICATIVE, levels=1 cycles=v
> On 10/20/2017 03:32 PM, David Nolte wrote:
>> Dear all,
>> I have some problems using GAMG as a preconditioner for (F)GMRES.
>> Background: I am solving the incompressible, unsteady Navier-Stokes
>> equations with a coupled mixed FEM approach, using P1/P1 elements for
>> velocity and pressure on an unstructured tetrahedron mesh with about
>> 2mio DOFs (and up to 15mio). The method is stabilized with SUPG/PSPG,
>> hence, no zeros on the diagonal of the pressure block. Time
>> discretization with semi-implicit backward Euler. The flow is a
>> convection dominated flow through a nozzle.
>> So far, for this setup, I have been quite happy with a simple FGMRES/ML
>> solver for the full system (rather bruteforce, I admit, but much faster
>> than any block/Schur preconditioners I tried):
>>     -ksp_converged_reason
>>     -ksp_monitor_true_residual
>>     -ksp_type fgmres
>>     -ksp_rtol 1.0e-6
>>     -ksp_initial_guess_nonzero
>>     -pc_type ml
>>     -pc_ml_Threshold 0.03
>>     -pc_ml_maxNlevels 3
>> This setup converges in ~100 iterations (see below the ksp_view output)
>> to rtol:
>> 119 KSP unpreconditioned resid norm 4.004030812027e-05 true resid norm
>> 4.004030812037e-05 ||r(i)||/||b|| 1.621791251517e-06
>> 120 KSP unpreconditioned resid norm 3.256863709982e-05 true resid norm
>> 3.256863709982e-05 ||r(i)||/||b|| 1.319158947617e-06
>> 121 KSP unpreconditioned resid norm 2.751959681502e-05 true resid norm
>> 2.751959681503e-05 ||r(i)||/||b|| 1.114652795021e-06
>> 122 KSP unpreconditioned resid norm 2.420611122789e-05 true resid norm
>> 2.420611122788e-05 ||r(i)||/||b|| 9.804434897105e-07
>> Now I'd like to try GAMG instead of ML. However, I don't know how to set
>> it up to get similar performance.
>> The obvious/naive
>>     -pc_type gamg
>>     -pc_gamg_type agg
>> # with and without
>>     -pc_gamg_threshold 0.03
>>     -pc_mg_levels 3
>> converges very slowly on 1 proc and much worse on 8 (~200k dofs per
>> proc), for instance:
>> np = 1:
>> 980 KSP unpreconditioned resid norm 1.065009356215e-02 true resid norm
>> 1.065009356215e-02 ||r(i)||/||b|| 4.532259705508e-04
>> 981 KSP unpreconditioned resid norm 1.064978578182e-02 true resid norm
>> 1.064978578182e-02 ||r(i)||/||b|| 4.532128726342e-04
>> 982 KSP unpreconditioned resid norm 1.064956706598e-02 true resid norm
>> 1.064956706598e-02 ||r(i)||/||b|| 4.532035649508e-04
>> np = 8:
>> 980 KSP unpreconditioned resid norm 3.179946748495e-02 true resid norm
>> 3.179946748495e-02 ||r(i)||/||b|| 1.353259896710e-03
>> 981 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
>> 3.179946748317e-02 ||r(i)||/||b|| 1.353259896634e-03
>> 982 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
>> A very high threshold seems to improve the GAMG PC, for instance with
>> 0.75 I get convergence to rtol=1e-6 after 744 iterations.
>> What else should I try?
>> I would very much appreciate any advice on configuring GAMG and
>> differences w.r.t ML to be taken into account (not a multigrid expert
>> though).
>> Thanks, best wishes
>> David
>> ksp_view for -pc_type gamg      -pc_gamg_threshold 0.75 -pc_mg_levels 3
>> KSP Object: 1 MPI processes
>>   type: fgmres
>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>     GMRES: happy breakdown tolerance 1e-30
>>   maximum iterations=10000
>>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
>>   right preconditioning
>>   using nonzero initial guess
>>   using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: gamg
>>       Cycles per PCApply=1
>>       Using Galerkin computed coarse grid matrices
>>       GAMG specific options
>>         Threshold for dropping small values from graph 0.75
>>         AGG specific options
>>           Symmetric graph false
>>   Coarse grid solver -- level -------------------------------
>>     KSP Object:    (mg_levels_0_)     1 MPI processes
>>       type: preonly
>>       maximum iterations=2, initial guess is zero
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>       left preconditioning
>>       using NONE norm type for convergence test
>>     PC Object:    (mg_levels_0_)     1 MPI processes
>>       type: sor
>>         SOR: type = local_symmetric, iterations = 1, local iterations =
>> 1, omega = 1.
>>       linear system matrix = precond matrix:
>>       Mat Object:       1 MPI processes
>>         type: seqaij
>>         rows=1745224, cols=1745224
>>         total: nonzeros=99452608, allocated nonzeros=99452608
>>         total number of mallocs used during MatSetValues calls =0
>>           using I-node routines: found 1037847 nodes, limit used is 5
>>     type: seqaij
>> ksp_view for -pc_type ml:
>> KSP Object: 8 MPI processes
>>   type: fgmres
>> PC Object: 8 MPI processes
>>   type: ml
>>     MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>     KSP Object:    (mg_coarse_)     8 MPI processes
>>       type: preonly
>>       maximum iterations=10000, initial guess is zero
>>     PC Object:    (mg_coarse_)     8 MPI processes
>>       type: redundant
>>         Redundant preconditioner: First (color=0) of 8 PCs follows
>>         KSP Object:        (mg_coarse_redundant_)         1 MPI processes
>>           type: preonly
>>         PC Object:        (mg_coarse_redundant_)         1 MPI processes
>>           type: lu
>>             LU: out-of-place factorization
>>             tolerance for zero pivot 2.22045e-14
>>             using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>             matrix ordering: nd
>>             factor fill ratio given 5., needed 10.4795
>>               Factored matrix follows:
>>                   type: seqaij
>>                   rows=6822, cols=6822
>>                   package used to perform factorization: petsc
>>                   total: nonzeros=9575688, allocated nonzeros=9575688
>>                     not using I-node routines
>>             type: seqaij
>>             total: nonzeros=913758, allocated nonzeros=913758
>>       Mat Object:       8 MPI processes
>>         type: mpiaij
>>           not using I-node (on process 0) routines
>>   Down solver (pre-smoother) on level 1 -------------------------------
>>     KSP Object:    (mg_levels_1_)     8 MPI processes
>>       type: richardson
>>         Richardson: damping factor=1.
>>     PC Object:    (mg_levels_1_)     8 MPI processes
>>       type: sor
>> 1, omega = 1.
>>         type: mpiaij
>>         rows=67087, cols=67087
>>         total: nonzeros=9722749, allocated nonzeros=9722749
>>   Up solver (post-smoother) same as down solver (pre-smoother)
>>   Down solver (pre-smoother) on level 2 -------------------------------
>>     KSP Object:    (mg_levels_2_)     8 MPI processes
>>       type: richardson
>>     PC Object:    (mg_levels_2_)     8 MPI processes
>>       type: sor
>> 1, omega = 1.
>>         type: mpiaij
>>           using I-node (on process 0) routines: found 126690 nodes,
>> limit used is 5
>>     type: mpiaij
>>       using I-node (on process 0) routines: found 126690 nodes, limit
>> used is 5
