[petsc-users] GAMG advice
David Nolte
dnolte at dim.uchile.cl
Fri Oct 20 13:32:21 CDT 2017
Dear all,
I have some problems using GAMG as a preconditioner for (F)GMRES.
Background: I am solving the incompressible, unsteady Navier-Stokes
equations with a coupled mixed FEM approach, using P1/P1 elements for
velocity and pressure on an unstructured tetrahedron mesh with about
2mio DOFs (and up to 15mio). The method is stabilized with SUPG/PSPG,
hence, no zeros on the diagonal of the pressure block. Time
discretization with semi-implicit backward Euler. The flow is a
convection dominated flow through a nozzle.
So far, for this setup, I have been quite happy with a simple FGMRES/ML
solver for the full system (rather bruteforce, I admit, but much faster
than any block/Schur preconditioners I tried):
-ksp_converged_reason
-ksp_monitor_true_residual
-ksp_type fgmres
-ksp_rtol 1.0e-6
-ksp_initial_guess_nonzero
-pc_type ml
-pc_ml_Threshold 0.03
-pc_ml_maxNlevels 3
This setup converges in ~100 iterations (see below the ksp_view output)
to rtol:
119 KSP unpreconditioned resid norm 4.004030812027e-05 true resid norm
4.004030812037e-05 ||r(i)||/||b|| 1.621791251517e-06
120 KSP unpreconditioned resid norm 3.256863709982e-05 true resid norm
3.256863709982e-05 ||r(i)||/||b|| 1.319158947617e-06
121 KSP unpreconditioned resid norm 2.751959681502e-05 true resid norm
2.751959681503e-05 ||r(i)||/||b|| 1.114652795021e-06
122 KSP unpreconditioned resid norm 2.420611122789e-05 true resid norm
2.420611122788e-05 ||r(i)||/||b|| 9.804434897105e-07
Now I'd like to try GAMG instead of ML. However, I don't know how to set
it up to get similar performance.
The obvious/naive
-pc_type gamg
-pc_gamg_type agg
# with and without
-pc_gamg_threshold 0.03
-pc_mg_levels 3
converges very slowly on 1 proc and much worse on 8 (~200k dofs per
proc), for instance:
np = 1:
980 KSP unpreconditioned resid norm 1.065009356215e-02 true resid norm
1.065009356215e-02 ||r(i)||/||b|| 4.532259705508e-04
981 KSP unpreconditioned resid norm 1.064978578182e-02 true resid norm
1.064978578182e-02 ||r(i)||/||b|| 4.532128726342e-04
982 KSP unpreconditioned resid norm 1.064956706598e-02 true resid norm
1.064956706598e-02 ||r(i)||/||b|| 4.532035649508e-04
np = 8:
980 KSP unpreconditioned resid norm 3.179946748495e-02 true resid norm
3.179946748495e-02 ||r(i)||/||b|| 1.353259896710e-03
981 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
3.179946748317e-02 ||r(i)||/||b|| 1.353259896634e-03
982 KSP unpreconditioned resid norm 3.179946748317e-02 true resid norm
A very high threshold seems to improve the GAMG PC, for instance with
0.75 I get convergence to rtol=1e-6 after 744 iterations.
What else should I try?
I would very much appreciate any advice on configuring GAMG and
differences w.r.t ML to be taken into account (not a multigrid expert
though).
Thanks, best wishes
David
ksp_view for -pc_type gamg -pc_gamg_threshold 0.75 -pc_mg_levels 3
KSP Object: 1 MPI processes
type: fgmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000
tolerances: relative=1e-06, absolute=1e-50, divergence=10000.
right preconditioning
using nonzero initial guess
using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=1 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
GAMG specific options
Threshold for dropping small values from graph 0.75
AGG specific options
Symmetric graph false
Coarse grid solver -- level -------------------------------
KSP Object: (mg_levels_0_) 1 MPI processes
type: preonly
maximum iterations=2, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: (mg_levels_0_) 1 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations =
1, omega = 1.
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: seqaij
rows=1745224, cols=1745224
total: nonzeros=99452608, allocated nonzeros=99452608
total number of mallocs used during MatSetValues calls =0
using I-node routines: found 1037847 nodes, limit used is 5
type: seqaij
ksp_view for -pc_type ml:
KSP Object: 8 MPI processes
type: fgmres
PC Object: 8 MPI processes
type: ml
MG: type is MULTIPLICATIVE, levels=3 cycles=v
KSP Object: (mg_coarse_) 8 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
PC Object: (mg_coarse_) 8 MPI processes
type: redundant
Redundant preconditioner: First (color=0) of 8 PCs follows
KSP Object: (mg_coarse_redundant_) 1 MPI processes
type: preonly
PC Object: (mg_coarse_redundant_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: nd
factor fill ratio given 5., needed 10.4795
Factored matrix follows:
type: seqaij
rows=6822, cols=6822
package used to perform factorization: petsc
total: nonzeros=9575688, allocated nonzeros=9575688
not using I-node routines
type: seqaij
total: nonzeros=913758, allocated nonzeros=913758
Mat Object: 8 MPI processes
type: mpiaij
not using I-node (on process 0) routines
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (mg_levels_1_) 8 MPI processes
type: richardson
Richardson: damping factor=1.
PC Object: (mg_levels_1_) 8 MPI processes
type: sor
1, omega = 1.
type: mpiaij
rows=67087, cols=67087
total: nonzeros=9722749, allocated nonzeros=9722749
Up solver (post-smoother) same as down solver (pre-smoother)
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (mg_levels_2_) 8 MPI processes
type: richardson
PC Object: (mg_levels_2_) 8 MPI processes
type: sor
1, omega = 1.
type: mpiaij
using I-node (on process 0) routines: found 126690 nodes,
limit used is 5
type: mpiaij
using I-node (on process 0) routines: found 126690 nodes, limit
used is 5
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171020/5ab7677b/attachment.sig>
