[petsc-users] Parallelizing a matrix-free code
Wed Oct 18 12:09:20 CDT 2017
On Wed, Oct 18, 2017 at 6:01 AM, Michael Werner <michael.werner at dlr.de>
wrote:
> Thank your for this explanation, it makes sense. And after I updated my
> code, the external CFD code runs without problems in parallel.
> However, now I'm back to the problem with the creation of the
> vectors/domains. By using the application ordering, I can assign the
> correct points from PETSc to the corresponding points in my external code.
> At least, as long as both use the same subdomain size. But sometimes they
> differ, and then the KSP breaks down, because the solution Vector it
> receives has a different size than what it expects.
> An example:
> I have an unstructured grid with 800,000 datapoints.
> If I decompose this to run  on 2 processors, PETSc delegates exactly
> 400,000 points to each process. However, the external code might assign
> 400,100 points to the first and 399,900 process. As a result, PETSc expects
> a solution vector of size 400,000 on each process, but receives one of
> 400,100 and one of 399,900, leading to a breakdown.
> I suppose I could use VecScatterCreateToAll to collect all the values from
> the solution vectors of my external code, and then create from those a
> temporary vector that only contains the expected 400,000 values to hand
> over to the KSP. But this would create a lot of communication between the
> different processes and seems quite clunky.
> Is there a more elegant way? Is it maybe possible to manually assign the
> size of the PETSc subdomains?
Yes, you can always assign the domain size in PETSc. For example,
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecSetSizes.html
    Matt
> Kind regards,
> Michael Werner
> Am 17.10.2017 um 12:31 schrieb Matthew Knepley:
> On Tue, Oct 17, 2017 at 6:08 AM, Michael Werner <michael.werner at dlr.de>
> wrote:
>> Because usally this code is called just once. It runs one multiple
>> processes, but there it's still always processing the whole domain. I can't
>> run it on only one subdomain. As I understand it now, when I call it from
>> PETSc, this call is issued once per process, so I would end up running
>> several contesting instances of the computation on the whole domain.
>> But maybe that's only because I haven't completly understood how MPI
>> really works in such cases...
> No, it makes one call in which all processes participate. So you would
> call your external CFD routine once from all processes, passing in the MPI
> communicator.
>    Matt
>> Kind regards,
>> Michael
>> Am 17.10.2017 um 11:50 schrieb Matthew Knepley:
>> On Tue, Oct 17, 2017 at 5:46 AM, Michael Werner <michael.werner at dlr.de>
>> wrote:
>>> I'm not sure what you mean with this question?
>>> The external CFD code, if that was what you referred to, can be run in
>>> parallel.
>> Then why is it a problem that "in a parallel case, this call obviously
>> gets called once per process"?
>>    Matt
>>> Am 17.10.2017 um 11:11 schrieb Matthew Knepley:
>>> On Tue, Oct 17, 2017 at 4:21 AM, Michael Werner <michael.werner at dlr.de>
>>> wrote:
>>>> That's something I'm still struggling with. In the serial case, I can
>>>> simply extract the values from the original grid, and since the ordering of
>>>> the Jacobian is the same there is no problem. In the parallel case this is
>>>> still a more or less open question. That's why I thought about reordering
>>>> the Jacobian. As long as the position of the individual IDs is the same for
>>>> both, I don't have to care about their absolute position.
>>>> I also wanted to thank you for your previous answer, it seems that the
>>>> application ordering might be what I'm looking for. However, in the
>>>> meantime I stumbled about another problem, that I have to solve first. My
>>>> new problem is, that I call the external code within the shell matrix'
>>>> multiply call. But in a parallel case, this call obviously gets called once
>>>> per process. So right now I'm trying to circumvent this, so it might take a
>>>> while before I'm able to come back to the original problem...
>>> I am not understanding. Is your original code parallel?
>>>   Thanks,
>>>      Matt
>>>> Kind regards,
>>>> Michael
>>>> Am 16.10.2017 um 17:25 schrieb Praveen C:
>>>> I am interested to learn more about how this works. How are the vectors
>>>> created if the ids are not contiguous in a partition ?
>>>> Thanks
>>>> praveen
>>>> On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini <
>>>> stefano.zampini at gmail.com> wrote:
>>>>> 2017-10-16 10:26 GMT+03:00 Michael Werner <michael.werner at dlr.de>:
>>>>>> Hello,
>>>>>> I'm having trouble with parallelizing a matrix-free code with PETSc.
>>>>>> In this code, I use an external CFD code to provide the matrix-vector
>>>>>> product for an iterative solver in PETSc. To increase convergence rate, I'm
>>>>>> using an explicitly stored Jacobian matrix to precondition the solver. This
>>>>>> works fine for serial runs. However, when I try to use multiple processes,
>>>>>> I face the problem that PETSc decomposes the preconditioner matrix, and
>>>>>> probably also the shell matrix, in a different way than the external CFD
>>>>>> code decomposes the grid.
>>>>>> The Jacobian matrix is built in a way, that its rows and columns
>>>>>> correspond to the global IDs of the individual points in my CFD mesh
>>>>>> The CFD code decomposes the domain based on the proximity of points
>>>>>> to each other, so that the resulting subgrids are coherent. However, since
>>>>>> its an unstructured grid, those subgrids are not necessarily made up of
>>>>>> points with successive global IDs. This is a problem, since PETSc seems to
>>>>>> partition the matrix in  coherent slices.
>>>>>> I'm not sure what the best approach to this problem might be. Is it
>>>>>> maybe possible to exactly tell PETSc, which rows/columns it should assign
>>>>>> to the individual processes?
>>>>> If you are explicitly setting the values in your Jacobians via
>>>>> MatSetValues(), you can create a ISLocalToGlobalMapping
>>>>> IS/ISLocalToGlobalMappingCreate.html
>>>>> that maps the numbering you use for the Jacobians to their counterpart
>>>>> in the CFD ordering, then call MatSetLocalToGlobalMapping and then use
>>>>> MatSetValuesLocal with the same arguments you are calling MatSetValues now.
>>>>> Otherwise, you can play with the application ordering
>>>>> AO/index.html
>>>>> Stefano
>>>> ____________________________________________________
>>>> Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>>>> Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073 Göttingen <https://maps.google.com/?q=Bunsenstr.+10+%7C+37073+G%C3%B6ttingen&entry=gmail&source=g>
>>>> Michael Werner
>>>> Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
>>>> DLR.de
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.caam.rice.edu/%7Emk51/>
>>> Michael Werner
>>> DLR.de
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
>> Michael Werner
>> DLR.de
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171018/526d59ab/attachment-0001.html>
