[petsc-users] Can not configure PETSc-master with clang-3.9
Kong, Fande fande.kong at inl.gov
Mon Oct 16 12:02:43 CDT 2017
Now it is working. It turns out I need to do something like "xcode-select
--install" after upgrading OS, and of course we need to agree the license.
Fande,
On Mon, Oct 16, 2017 at 10:58 AM, Richard Tran Mills <rtmills at anl.gov>
wrote:
> Fande,
> Did you remember to agree to the XCode license after your upgrade, if you
> did an XCode upgrade? You have to do the license agreement again, otherwise
> the compilers don't work at all. Apologies if this seems like a silly thing
> to ask, but this has caused me a few minutes of confusion before.
> --Richard
> On Mon, Oct 16, 2017 at 9:52 AM, Jed Brown <jed at jedbrown.org> wrote:
>> "Kong, Fande" <fande.kong at inl.gov> writes:
>> > Hi All,
>> > I just upgraded  MAC OS, and also updated all other related packages.
>> Now
>> > I can not configure PETSc-master any more.
>> Your compiler paths are broken.
>> /var/folders/6q/y12qpzw12dg5qx5x96dd5_bhtzr4_y/T/petsc-
>> mFgio7/config.setCompilers/conftest.c:3:10: fatal error: 'stdlib.h' file
>> not found
>> #include <stdlib.h>
>> 1 error generated.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171016/10d5c863/attachment.html>
