[petsc-users] Parallelizing a matrix-free code
Praveen C cpraveen at gmail.com
Mon Oct 16 10:25:39 CDT 2017
I am interested to learn more about how this works. How are the vectors
created if the ids are not contiguous in a partition ?
Thanks
praveen
On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> 2017-10-16 10:26 GMT+03:00 Michael Werner <michael.werner at dlr.de>:
>> Hello,
>> I'm having trouble with parallelizing a matrix-free code with PETSc. In
>> this code, I use an external CFD code to provide the matrix-vector product
>> for an iterative solver in PETSc. To increase convergence rate, I'm using
>> an explicitly stored Jacobian matrix to precondition the solver. This works
>> fine for serial runs. However, when I try to use multiple processes, I face
>> the problem that PETSc decomposes the preconditioner matrix, and probably
>> also the shell matrix, in a different way than the external CFD code
>> decomposes the grid.
>> The Jacobian matrix is built in a way, that its rows and columns
>> correspond to the global IDs of the individual points in my CFD mesh
>> The CFD code decomposes the domain based on the proximity of points to
>> each other, so that the resulting subgrids are coherent. However, since its
>> an unstructured grid, those subgrids are not necessarily made up of points
>> with successive global IDs. This is a problem, since PETSc seems to
>> partition the matrix in  coherent slices.
>> I'm not sure what the best approach to this problem might be. Is it maybe
>> possible to exactly tell PETSc, which rows/columns it should assign to the
>> individual processes?
> If you are explicitly setting the values in your Jacobians via
> MatSetValues(), you can create a ISLocalToGlobalMapping
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/
> ISLocalToGlobalMappingCreate.html
> that maps the numbering you use for the Jacobians to their counterpart in
> the CFD ordering, then call MatSetLocalToGlobalMapping and then use
> MatSetValuesLocal with the same arguments you are calling MatSetValues now.
> Otherwise, you can play with the application ordering
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/index.html
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171016/0bc64df3/attachment.html>
