[petsc-users] Parallelizing a matrix-free code
Michael Werner michael.werner at dlr.de
Mon Oct 16 02:26:57 CDT 2017
Hello,
I'm having trouble with parallelizing a matrix-free code with PETSc. In
this code, I use an external CFD code to provide the matrix-vector
product for an iterative solver in PETSc. To increase convergence rate,
I'm using an explicitly stored Jacobian matrix to precondition the
solver. This works fine for serial runs. However, when I try to use
multiple processes, I face the problem that PETSc decomposes the
preconditioner matrix, and probably also the shell matrix, in a
different way than the external CFD code decomposes the grid.
The Jacobian matrix is built in a way, that its rows and columns
correspond to the global IDs of the individual points in my CFD mesh
The CFD code decomposes the domain based on the proximity of points to
each other, so that the resulting subgrids are coherent. However, since
its an unstructured grid, those subgrids are not necessarily made up of
points with successive global IDs. This is a problem, since PETSc seems
to partition the matrix in  coherent slices.
I'm not sure what the best approach to this problem might be. Is it
maybe possible to exactly tell PETSc, which rows/columns it should
assign to the individual processes?
