[petsc-users] Issue with -log_view
Stefano Zampini
stefano.zampini at gmail.com
Sat Oct 14 08:36:52 CDT 2017
cutting and paste a message I sent a couple of days ago on the mailing
list. I suspect you have a memory leak on some PetscViewer object. Try
running with -malloc -malloc_dump -malloc_debug and without -log_view and
see if you PETSc reports a memory leak. You can also try running under
valgrind with the --leak-check=full option
Instead of reporting a leak, the below code, when run with -log_view,
triggers an error
#include <petscviewer.h>
int main(int argc,char **args)
PetscErrorCode ierr;
PetscViewer view;
ierr = PetscInitialize(&argc,&args,(char*)0,help);CHKERRQ(ierr);
ierr = PetscViewerASCIIGetStdout(PETSC_COMM_WORLD,&view);CHKERRQ(ierr);
ierr = PetscViewerCreate(PETSC_COMM_WORLD,&view);CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Corrupt argument: http://www.mcs.anl.gov/petsc/
documentation/faq.html#valgrind
[0]PETSC ERROR: Invalid type of object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-4792-gbbfd41f GIT
Date: 2017-07-30 13:35:30 +0300
[0]PETSC ERROR: ./ex1 on a arch-debug named localhost.localdomain by
szampini Thu Oct 12 15:24:19 2017
[0]PETSC ERROR: Configure options --download-chaco --download-ctetgen
--download-hypre --download-metis --download-mumps --download-p4est
--download-parmetis --download-suitesparse --download-triangle
--with-scalapack CFLAGS="-Wall -g -O0" CXXFLAGS="-Wall -g -O0" FCFLAGS="-g
-O0" PETSC_ARCH=arch-debug
[0]PETSC ERROR: #1 PetscObjectReference() line 510 in
/home/szampini/src/petsc/src/sys/objects/inherit.c
[0]PETSC ERROR: #2 PetscOptionsGetViewer() line 259 in
/home/szampini/src/petsc/src/sys/classes/viewer/interface/viewreg.c
[0]PETSC ERROR: #3 PetscLogViewFromOptions() line 1753 in
/home/szampini/src/petsc/src/sys/logging/plog.c
[0]PETSC ERROR: #4 PetscFinalize() line 1227 in
/home/szampini/src/petsc/src/sys/objects/pinit.c
The problem is with the MPIAttribute Petsc_Viewer_Stdout_keyval attached to
PETSC_COMM_WORLD. PETSC_VIEWER_STDOUT_WORLD gets destroyed in the first
call to PetscObjectRegisterDestroyAll(); Then PetscLogViewFromOptions()
call PetscViewerASCIIGetStdout that checks for the presence of the
attribute on the communicator, which is still there, since we never called
MPI_Comm_free on that communicator.
What would be a solution for this issue? At least, we should print a nice
error message in PetscViewerASCIIGetStdout.
2017-10-14 16:10 GMT+03:00 Barry Smith <bsmith at mcs.anl.gov>:
> Please cut and paste all the output and send it to
> petsc-maint at mcs.anl.gov
> Barry
> > On Oct 14, 2017, at 2:31 AM, Tina Patel <tinap89 at yahoo.com> wrote:
> > Hi,
> > I'm using -log_view option from the command line, but it gives me
> "corrupt argument" and "invalid argument". However, PETSc doesn't throw
> errors when running without -log_view.
> > Am I using it correctly? Or does this hint at another problem? I'm using
> petsc-master 3.7.6.
> > Thanks for your time,
> > Tina
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171014/6bf4b0c7/attachment.html>
