[petsc-users] Trouble installing petsc4py in Anaconda environment
William T Jones w.t.jones at nasa.gov
Wed Oct 11 16:29:47 CDT 2017
I have created an Anaconda Pytyoh 2.7 environment on an SGI-ICE machine
and included cython, numpy=1.12, scipy, and mpi4py (based SGI-MPT).
While petsc installs fine with:
% PETSC_CONFIGURE_OPTIONS="--download-fblaslapack=1" pip install
https://bitbucket.org/petsc/petsc/get/maint.tar.gz
I cannot get petsc4py to build/install.  I am attempting with:
% export PETSC_DIR=${PREFIX}/envs/myenv/lib/python2.7/site-packages/petsc
% pip install --no-dependencies petsc4py
Note, I am using "--no-dependencies" because I want to leave numpy at
1.12 and do not want it to be upgraded.  Either way I get the output
below.  It appears that the link command has been corrupted with the
addition of the "gcc" command in the middle of the link command.
Any help is appreciated,
Collecting petsc4py
   Using cached petsc4py-3.8.0.tar.gz
Building wheels for collected packages: petsc4py
   Running setup.py bdist_wheel for petsc4py ... error
   Complete output from command
/home/login/anaconda2/envs/myenv/bin/python -u -c "import setuptools,
tokenize;__file__='/tmp/pip-build-v6lDIk/petsc4py/setup.py';f=getattr(tokenize,
'open', open)(__file__);code=f.read().replace('\r\n',
'\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d
/tmp/tmpD2KqLjpip-wheel- --python-tag cp27:
   running bdist_wheel
   running build
   running build_src
   running build_py
   creating build
   creating build/lib.linux-x86_64-2.7
   creating build/lib.linux-x86_64-2.7/petsc4py
   copying src/PETSc.py -> build/lib.linux-x86_64-2.7/petsc4py
   copying src/__init__.py -> build/lib.linux-x86_64-2.7/petsc4py
   copying src/__main__.py -> build/lib.linux-x86_64-2.7/petsc4py
   creating build/lib.linux-x86_64-2.7/petsc4py/lib
   copying src/lib/__init__.py ->
   creating build/lib.linux-x86_64-2.7/petsc4py/include
   creating build/lib.linux-x86_64-2.7/petsc4py/include/petsc4py
   copying src/include/petsc4py/petsc4py.PETSc.h ->
   copying src/include/petsc4py/numpy.h ->
   copying src/include/petsc4py/petsc4py.PETSc_api.h ->
   copying src/include/petsc4py/petsc4py.h ->
   copying src/include/petsc4py/petsc4py.i ->
   copying src/include/petsc4py/__init__.pxd ->
   copying src/include/petsc4py/PETSc.pxd ->
   copying src/include/petsc4py/__init__.pyx ->
   copying src/PETSc.pxd -> build/lib.linux-x86_64-2.7/petsc4py
   copying src/lib/petsc.cfg -> build/lib.linux-x86_64-2.7/petsc4py/lib
   running build_ext
   PETSC_DIR:
/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/petsc
   PETSC_ARCH:
   version:      3.8.0 release
   integer-size: 32-bit
   scalar-type:  real
   precision:    double
   language:     CONLY
   compiler:     /vendor/sgi/mpt/2.14r19/bin/mpicc
   linker:       /vendor/sgi/mpt/2.14r19/bin/mpicc
   building 'PETSc' extension
   creating build/temp.linux-x86_64-2.7
   creating build/temp.linux-x86_64-2.7/src
   /vendor/sgi/mpt/2.14r19/bin/mpicc -pthread -B
/home/login/anaconda2/envs/myenv/compiler_compat -fPIC -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -g -O -fPIC -fno-strict-aliasing -g -O2 -DNDEBUG -g
-fwrapv -O3 -Wall
-DPETSC_DIR=/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/petsc
-I/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/petsc/include
-Isrc/include
-I/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/numpy/core/include
-I/home/login/anaconda2/envs/myenv/include/python2.7 -c src/PETSc.c -o
build/temp.linux-x86_64-2.7/src/PETSc.o
   In file included from
/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/numpy/core/include/numpy/ndarraytypes.h:1788:0,
                    from
/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/numpy/core/include/numpy/ndarrayobject.h:18,
                    from
/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/numpy/core/include/numpy/arrayobject.h:4,
                    from src/include/petsc4py/numpy.h:11,
                    from src/petsc4py.PETSc.c:519,
                    from src/PETSc.c:3:
/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:15:2:
warning: #warning "Using deprecated NumPy API, disable it by "
"#defining NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION" [-Wcpp]
    #warning "Using deprecated NumPy API, disable it by " \
-fwrapv -O3 -Wall
-Isrc/include
src/libpetsc4py.c -o build/temp.linux-x86_64-2.7/src/libpetsc4py.o
-fstack-protector -g -O gcc -pthread -shared -B
/home/login/anaconda2/envs/myenv/compiler_compat -fno-strict-aliasing -g
-O2 -DNDEBUG -g -fwrapv -O3 -Wall -L/home/login/anaconda2/envs/myenv/lib
-Wl,-rpath=/home/login/anaconda2/envs/myenv/lib -Wl,--no-as-needed
-Wl,--sysroot=/ build/temp.linux-x86_64-2.7/src/PETSc.o
-L/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/petsc/lib
-Wl,-rpath,/home/login/anaconda2/envs/myenv/lib/python2.7/site-packages/petsc/lib
-Wl,-rpath,/home/login/anaconda2/envs/myenv/lib -lpetsc -lpython2.7 -o
build/lib.linux-x86_64-2.7/petsc4py/lib/PETSc.so
   gcc: error: gcc: No such file or directory
   error: command '/vendor/sgi/mpt/2.14r19/bin/mpicc' failed with exit
status 1
   Failed building wheel for petsc4py
   Running setup.py clean for petsc4py
Failed to build petsc4py
Installing collected packages: petsc4py
   Running setup.py install for petsc4py ... error
'\n');f.close();exec(compile(code, __file__, 'exec'))" install --record
/tmp/pip-d6NYW8-record/install-record.txt
--single-version-externally-managed --compile:
     running install
     running build
     running build_src
     running build_py
     creating build
     running build_ext
     PETSC_DIR:
     PETSC_ARCH:
     scalar-type:  real
     precision:    double
     language:     CONLY
-fwrapv -O3 -Wall
-Isrc/include
                      from
                      from
                      from src/PETSc.c:3:
-fwrapv -O3 -Wall
-Isrc/include
status 1
Command "/home/login/anaconda2/envs/myenv/bin/python -u -c "import
setuptools,
--single-version-externally-managed --compile" failed with error code 1
in /tmp/pip-build-v6lDIk/petsc4py/
     Bill Jones                                       W.T.JONES at NASA.GOV
     Mail Stop 128                     Computational AeroSciences Branch
     15 Langley Boulevard                           Research Directorate
     NASA Langley Research Center               Building 1268, Room 1044
     Hampton, VA  23681-2199                       Phone +1 757 864-5318
                                                     Fax +1 757 864-8816
                                              http://fun3d.larc.nasa.gov
