[petsc-users] Using factored complex matrices from MUMPS as a preconditioner in PETSC
Hong hzhang at mcs.anl.gov
Wed Oct 11 11:26:33 CDT 2017
On Wed, Oct 11, 2017 at 11:14 AM, Evan Um <evanum at gmail.com> wrote:
> Hi Hong,
> Thanks for your kind email. I write another email to make sure I
> understand it correctly. Does the zipped file from
> https://www.mcs.anl.gov/petsc/developers/index.html#browsing have the
> updated feature?
> Best,
> Evan
>    - https://bitbucket.org/petsc/petsc/get/master.tar.gz
> I do not see it :-(
Get petsc-dev by
   - git clone https://bitbucket.org/petsc/petsc
Then do following:
git checkout master
git pull
Check file
src/mat/impls/aij/mpi/mumps/mumps.c to see if  ICNTL(35) is there or not.
Hong
> On Wed, Oct 11, 2017 at 7:56 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> Evan:
>> The branch is already merged to master. Just use petsc master branch.
>> Hong
>> Hi Matt,
>>> Still unclear to me. I go to https://bitbucket.org/petsc
>>> /petsc/addon/pipelines/home#!/ and then https://bitbucket.org/pet
>>> sc/petsc/branches/. I don't see any tarred file or directory named "update-mumps-5.1.1-cntl".
>>> Could you explain how to download the modified version from the site a
>>> little bit in detail? Thank you very much for your help.
>>> Evan
>>> On Wed, Oct 11, 2017 at 1:54 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Oct 10, 2017 at 10:30 PM, Evan Um <evanum at gmail.com> wrote:
>>>>> Dear Hong,
>>>>> I just tried to check PETSC develeoper website but couldn't find the
>>>>> updated dev version with name of hzang/update-mumps-5.1.1-cntl.
>>>> Hong means a branch. You get the dev repository and checkout that branch
>>>>   git checkout  hzang/update-mumps-5.1.1-cntl
>>>>   Thanks,
>>>>    Matt
>>>>> . Could you please let me know the location of the updated dev
>>>>> version? Where do I need to visit to check out the dev version with the new
>>>>> control switches? Thank you very much for your help.
>>>>> Best,
>>>>> Evan
>>>>> On Tue, Oct 3, 2017 at 8:34 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>> Evan,
>>>>>> ICNTL(35) and CNTL(7) are added to petsc-mumps interface in branch
>>>>>> hzhang/update-mumps-5.1.1-cntl
>>>>>> You may give it a try. Once it passes our regression tests, I'll
>>>>>> merge it to petsc master branch.
>>>>>> Hong
>>>>>> On Sun, Sep 24, 2017 at 8:08 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>> I'll check it.
>>>>>>> Hong
>>>>>>> On Sun, Sep 24, 2017 at 3:42 PM, Evan Um <evanum at gmail.com> wrote:
>>>>>>>> Hi Barry,
>>>>>>>> Thanks for your comments. To activate block low rank (BLR)
>>>>>>>> approximation in MUMPS version 5.1.1, a user needs to turn on the
>>>>>>>> functionality (i.e. ICNTL(35)=1) and specify the tolerance value (e.g.
>>>>>>>> CNTL(7)=1e-4). In PETSC, I think that we can set up ICNTL and CNTL
>>>>>>>> parameters for MUMPS. I was wondering if we can still use BLR approximation
>>>>>>>> for a preconditioner for Krylov solvers.
>>>>>>>> Best,
>>>>>>>> Evan
>>>>>>>> On Sat, Sep 23, 2017 at 6:45 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>> > On Sep 23, 2017, at 8:38 PM, Evan Um <evanum at gmail.com> wrote:
>>>>>>>>> > Dear PETSC Users,
>>>>>>>>> > My system matrix comes from finite element modeling and is
>>>>>>>>> complex and unstructured. Its typical size is a few millions-by a few
>>>>>>>>> millions. I wondering if I can use MUMPS parallel direct solver as a
>>>>>>>>> preconditioner in PETSC. For example, I want to pass factored matrices to
>>>>>>>>> Krylov iterative solvers such as QMR. Is there any PETSC+MUMPS example code
>>>>>>>>> for the purpose?
>>>>>>>>>   You don't pass factored matrices you just pass the original
>>>>>>>>> matrix and use -pc_type lu -pc_factor_mat_solver_package mumps
>>>>>>>>> > Can PETSC call the latest MUMPS that supports block low rank
>>>>>>>>> approximation?
>>>>>>>>>   No, send us info on it and we'll see if we can add an interface
>>>>>>>>> > In advance, thank you very much for your comments.
>>>>>>>>> > Best,
>>>>>>>>> > Evan
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171011/af975f10/attachment.html>
