[petsc-users] Using factored complex matrices from MUMPS as a preconditioner in PETSC
Hong hzhang at mcs.anl.gov
Tue Oct 10 15:00:47 CDT 2017
Hmm, I have never used petsc-strumpack interface.
I'll take a look and try to add this support.
Hong
On Tue, Oct 10, 2017 at 2:23 PM, Evan Um <evanum at gmail.com> wrote:
> Hi Hong,
> Thanks for your help. I am testing if I can use MUMPS block low rank
> factors as a preconditioner for QMR in MUMPS framework. I would like to ask
> one more question. STRUMPACK (http://portal.nersc.gov/
> project/sparse/strumpack/) also supports low rank approximation. Can
> PETSC also allow users to use the approximate factors as a preconditioner
> in PETSC-QMR?
> Best,
> Evan
> On Tue, Oct 3, 2017 at 8:34 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> Evan,
>> ICNTL(35) and CNTL(7) are added to petsc-mumps interface in branch
>> hzhang/update-mumps-5.1.1-cntl
>> You may give it a try. Once it passes our regression tests, I'll merge it
>> to petsc master branch.
>> Hong
>> On Sun, Sep 24, 2017 at 8:08 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>> I'll check it.
>>> Hong
>>> On Sun, Sep 24, 2017 at 3:42 PM, Evan Um <evanum at gmail.com> wrote:
>>>> Hi Barry,
>>>> Thanks for your comments. To activate block low rank (BLR)
>>>> approximation in MUMPS version 5.1.1, a user needs to turn on the
>>>> functionality (i.e. ICNTL(35)=1) and specify the tolerance value (e.g.
>>>> CNTL(7)=1e-4). In PETSC, I think that we can set up ICNTL and CNTL
>>>> parameters for MUMPS. I was wondering if we can still use BLR approximation
>>>> for a preconditioner for Krylov solvers.
>>>> Best,
>>>> Evan
>>>> On Sat, Sep 23, 2017 at 6:45 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>> > On Sep 23, 2017, at 8:38 PM, Evan Um <evanum at gmail.com> wrote:
>>>>> > Dear PETSC Users,
>>>>> > My system matrix comes from finite element modeling and is complex
>>>>> and unstructured. Its typical size is a few millions-by a few millions. I
>>>>> wondering if I can use MUMPS parallel direct solver as a preconditioner in
>>>>> PETSC. For example, I want to pass factored matrices to Krylov iterative
>>>>> solvers such as QMR. Is there any PETSC+MUMPS example code for the purpose?
>>>>>   You don't pass factored matrices you just pass the original matrix
>>>>> and use -pc_type lu -pc_factor_mat_solver_package mumps
>>>>> > Can PETSC call the latest MUMPS that supports block low rank
>>>>> approximation?
>>>>>   No, send us info on it and we'll see if we can add an interface
>>>>> > In advance, thank you very much for your comments.
>>>>> > Best,
>>>>> > Evan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171010/56bfc644/attachment-0001.html>
