[petsc-users] A number of questions about DMDA with SNES and Quasi-Newton methods
zakaryah . zakaryah at gmail.com
Sun Oct 8 01:05:58 CDT 2017
I'm more confused than ever.  I don't understand the output of -snes_type
test -snes_test_display.
For the user-defined state of the vector (where I'd like to test the
Jacobian), the finite difference Jacobian at row 0 evaluates as:
row 0: (0, 10768.6)  (1, 2715.33)  (2, -1422.41)  (3, -6121.71)  (4,
287.797)  (5, 744.695)  (9, -1454.66)  (10, 6.08793)  (11, 148.172)  (12,
13.1089)  (13, -36.5783)  (14, -9.99399)  (27, -3423.49)  (28, -2175.34)  (29,
548.662)  (30, 145.753)  (31, 17.6603)  (32, -15.1079)  (36, 76.8575)  (37,
16.325)  (38, 4.83918)
But the hand-coded Jacobian at row 0 evaluates as:
287.797)  (5, 744.695)  (33, -1454.66)  (34, 6.08792)  (35, 148.172)  (36,
13.1089)  (37, -36.5783)  (38, -9.99399)  (231, -3423.49)  (232, -2175.34)
(233, 548.662)  (234, 145.753)  (235, 17.6603)  (236, -15.1079)  (264,
76.8575)  (265, 16.325)  (266, 4.83917)  (267, 0.)  (268, 0.)  (269, 0.)
and the difference between the Jacobians at row 0 evaluates as:
row 0: (0, 0.000189908)  (1, 7.17315e-05)  (2, 9.31778e-05)  (3,
0.000514947)  (4, 0.000178659)  (5, 0.000178217)  (9, -2.25457e-05)  (10,
-6.34278e-06)  (11, -5.93241e-07)  (12, 9.48544e-06)  (13, 4.79709e-06)  (14,
2.40016e-06)  (27, -0.000335696)  (28, -0.000106734)  (29, -0.000106653)  (30,
2.73119e-06)  (31, -7.93382e-07)  (32, 1.24048e-07)  (36, -4.0302e-06)  (37,
3.67494e-06)  (38, -2.70115e-06)  (39, 0.)  (40, 0.)  (41, 0.)
The difference between the column numbering between the finite difference
and the hand-coded Jacobians looks like a serious problem to me, but I'm
probably missing something.
I am trying to use a 3D DMDA with 3 dof, a box stencil of width 1, and for
this test problem the grid dimensions are 11x7x6.  For a grid point x,y,z,
and dof c, is the index calculated as c + 3*x + 3*11*y + 3*11*7*z?  If so,
then the column numbers of the hand-coded Jacobian match those of the 27
point stencil I have in mind.  However, I am then at a loss to explain the
column numbers in the finite difference Jacobian.
On Sat, Oct 7, 2017 at 1:49 PM, zakaryah . <zakaryah at gmail.com> wrote:
> OK - I ran with -snes_monitor -snes_converged_reason
> -snes_linesearch_monitor -ksp_monitor -ksp_monitor_true_residual
> -ksp_converged_reason -pc_type svd -pc_svd_monitor -snes_type newtonls
> -snes_compare_explicit
> and here is the full error message, output immediately after
> Finite difference Jacobian
> Mat Object: 24 MPI processes
>   type: mpiaij
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Matrix not generated from a DMDA
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [0]PETSC ERROR: ./CalculateOpticalFlow on a arch-linux2-c-opt named
> node046.hpc.rockefeller.internal by zfrentz Sat Oct  7 13:44:44 2017
> [0]PETSC ERROR: Configure options --prefix=/ru-auth/local/home/zfrentz/PETSc-3.7.6
> --download-fblaslapack -with-debugging=0
> [0]PETSC ERROR: #1 MatView_MPI_DA() line 551 in /rugpfs/fs0/home/zfrentz/
> PETSc/build/petsc-3.7.6/src/dm/impls/da/fdda.c
> [0]PETSC ERROR: #2 MatView() line 901 in /rugpfs/fs0/home/zfrentz/
> PETSc/build/petsc-3.7.6/src/mat/interface/matrix.c
> [0]PETSC ERROR: #3 SNESComputeJacobian() line 2371 in
> /rugpfs/fs0/home/zfrentz/PETSc/build/petsc-3.7.6/src/snes/interface/snes.c
> [0]PETSC ERROR: #4 SNESSolve_NEWTONLS() line 228 in
> /rugpfs/fs0/home/zfrentz/PETSc/build/petsc-3.7.6/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #5 SNESSolve() line 4005 in /rugpfs/fs0/home/zfrentz/
> [0]PETSC ERROR: #6 solveWarp3D() line 659 in /ru-auth/local/home/zfrentz/
> Code/OpticalFlow/working/October6_2017/mshs.c
> On Tue, Oct 3, 2017 at 5:37 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Always always always send the whole error message.
>> "zakaryah ." <zakaryah at gmail.com> writes:
>> > I tried -snes_compare_explicit, and got the following error:
>> > What am I doing wrong?
>> > On Tue, Oct 3, 2017 at 10:08 AM, Jed Brown <jed at jedbrown.org> wrote:
>> >> Barry Smith <bsmith at mcs.anl.gov> writes:
>> >> >> On Oct 3, 2017, at 5:54 AM, zakaryah . <zakaryah at gmail.com> wrote:
>> >> >> I'm still working on this.  I've made some progress, and it looks
>> like
>> >> the issue is with the KSP, at least for now.  The Jacobian may be
>> >> ill-conditioned.  Is it possible to use -snes_test_display during an
>> >> intermediate step of the analysis?  I would like to inspect the
>> Jacobian
>> >> after several solves have already completed,
>> >> >    No, our currently code for testing Jacobians is poor quality and
>> >> poorly organized. Needs a major refactoring to do things properly.
>> Sorry
>> >> You can use -snes_compare_explicit or -snes_compare_coloring to output
>> >> differences on each Newton step.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171008/c048f569/attachment.html>
