[petsc-users] New nonzero caused a malloc
Luca Verzeroli l.verzeroli at studenti.unibg.it
Thu Oct 5 01:59:28 CDT 2017
Good mornig,
I'm new to PETSc and i'm wondering about this problem.
When i run my code with 2 processes I have no problem. When i use more
than 2 processes I receive this message:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: New nonzero at (0,43) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
This means that a process is trying to write in cell (0,43)?
Then I try with MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR,
PETSC_FALSE) and I
check with MatView if there's an element in (0,43) but nothing is
written there.
Otherwise, I have checked the index I use to insert element in the
matrix but no (0,43) is present.
Could you give me some advices about the possible solution of this problem?
Luca
