[petsc-users] Mat/Vec with empty ranks
Florian Lindner mailinglists at xgm.de
Wed Oct 4 23:39:31 CDT 2017
Am 04.10.2017 um 18:08 schrieb Matthew Knepley:
> I don't know if that is right. However, the sequential and parallel algorithms agree on both the initial residual (so
> that parallel
> matrix and rhs appear correct) and the first iterate. Divergence of the second iterate could still be a bug in our code,
> but it
> was harder for me to see how.
> The real thing to do, which should not be that much work but I don't have time for now unfortunately, is to step through the
> algorithm in serial and parallel and see what number changes. The algorithm only has 20 or so steps per iterate, so this
> would probably take one day to do right.
Ok, I try to dig a bit into petsc.
I worked on the cleaned up code you gave me, ran it on 4 MPI ranks and compared output with and without using -load.
Other options were:
-ksp_max_it 10 -ksp_view -ksp_monitor_true_residual -ksp_lsqr_monitor -ksp_view_pre -vecscatter_view"
All on the maint branch.
Starting from lsqr.c, I identified values to start differing after KSP_MatMultTranspose(ksp,Amat,U1,V1);
With -load (converging), V1 has the value:
Vec Object: 4 MPI processes
  type: mpi
Process [0]
-0.544245
Process [1]
1.11245
Process [2]
-1.25846
Process [3]
Without -load:
  type: mpi
Process [0]
0.316288
Process [1]
2.85233
Process [2]
-0.776467
Process [3]
Other input values are same.
I tracked it further down to MatMultTranspose_MPIDense in mpidense.c where the value of yy starts to differ after the
VecScatterBegin/End. At this place, a->lvec, the scatter source also differes, whereas Mat A is identical (by looking at
MatView output).
However, no idea where a->lvec (which is A->data->lvec) is filled.
I hope that helps a bit.
Best,
Florian
